I'm getting "Software pack is not valid for this device" while attempting to upload 7926G firmware in the Phone Loads module. We have a UC540.CCA 3.2IOS 15.1(2) T4Attempting this load: cmterm-7926-sccp.1-4-2.zipAny tips would be appreciated. Thank yo...
Hi!Summarize the background because it is a bit long: DoA, temporary replacement, installation of new UC (updated with SW 8.2.0 & Italian locale pkg)!Now, I am with a phone out of six (same model) with the soft buttons in English, even after several ...
We have recently set up MeetMe conferencing and have encountered the following issue...The first participant to enter the MeetMe conference extension in greeted with dead air. It isn’t clear if you just got cut off, or if you are successfully entere...
HI,we are a small business and hence no full time IT support.We bought our UC560 with some 7900 phones for inhouse use and SPA525G2 for our remote sales people. SPA phones firmware 7.4.6 needs to be updated. I was told by a cisco expert that the new ...
HelloI have UC560 with 2 vic cards for 2 T1, and the configuration that I need is this:The long distance call has to go for the First T1Local calls for the second T1and also I need a failover, If one of the T1 fails used the another one.Any help plea...
Hi,Please could someone tell me if Cisco Mobile and Jabber are compatible with the UC560 ? and if so are there special requirements ?Any help will be much appreicated.Thank youJoshua Royle
I have a few SPA252G that connects via VPN, but everytime they make a call it only last about 4 to 5 minutes sometimes less then it drops, basically the connection is lost and the phones reset, how do I check on the UC560 to see why the connection wi...
Hi all,Firstly, let me apologize for my ignoreance in all matters Cisco - I'm slowly learning!For some reason recently when I reconfigured our UC540 via the CCA (created a additional VLAN with DHCP, disabled DHCP on the DATA VLAN), I am now no longer...
Is it possible to turn off call waiting? We have a customer that would like it so that if some one is on the phone the call will go directly to voicemail.
I am trying to get Smart CallConnector Toolbar working sucessfully on a computer with Windows 7 (64 bit) and Outlook 2007 (32 bit). The install procedure appears to complete successfully (no error indications) and I am able to use the CallConnector P...
Good Morning,It appears that UC320's are being shipped with older firmware applied on them, and as a result we are having difficulty logging into them using the latest versions of IE;Firefox and Google Chrome. Although I havent tried Safari I imagine...
Hi All,First of all, great job on V2.2.2.. I cant wait to see what the future holds for the UC320?. Can I make a feature request please. We access our systems from a particular range of public IP addresses for security purposes. When allowing https r...
My PAP2T works with YouMagic SIP Service (http://www.youmagic.com/index.php?lang=en)It displays wrong Caller ID - it displays MY number (+7499709xxxx) not calling party number (+7916xxxxxxx)Wiresharked INVITE request INVITE sip:7499709xxxx@a.b.c.d:34...
Hi,I'm having issue with SPA8000 daylight settingsegusing this parameters for NSW timezone (used in other SPA units eg SPA900, 500 series etc)<Time_Zone ua="na">GMT+10:00</Time_Zone><Daylight_Saving_Time_Enable ua="na">Yes</Daylight_Saving_Time_Enabl...
