09-01-2010 10:51 AM - edited 03-21-2019 02:57 AM
I have deployed the auto attendant in my UC560. The AA is answering incoming calls from an analog PSTN line. The problem is, when a client hangs up during the prompt, the call isn't disconnected and is forwarded to a blast group that I have as default forward when no option is selected.
If I forward the PSTN incoming calls to an operator directly, if the client hangs up, then the operator's phone stops ringing correctly.
I have deleted and created the AA, but it doesn't solved nothing.
The UC560 is running SWP8.0.4 and CCA 2.2(5)
Any ideas?.
Thanks.
09-02-2010 07:41 PM
Can you get the following debugs for a test call?
debug voip ccapi inout
debug vpm signal
debug ccsip message
When you're on the console can you type in the session to mark when the PSTN hung up the call?
Also include the 'show run'.
-Anthony
09-03-2010 01:03 AM
Hi Anthony,
I have attached the debugs and the run.
I have placed a call, and when the prompt starts I hang up, after playing the prompt the second time the call (already finished) forwards to a blast group and finally to the voice mail.
I have marked the moment I finish the call in the .txt with this:
/******************** END OF THE CALL ************************/
001657: Sep 3 07:51:06.050: htsp_process_event: [0/3/0, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
001658: Sep 3 07:51:06.050: htsp_timer_stop2
001659: Sep 3 07:51:06.050: htsp_timer_stop2
001660: Sep 3 07:51:19.486: htsp_process_event: [50/0/9.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
001661: Sep 3 07:51:19.486: [50/0/9.1] get_local_station_id calling num=BCD calling name= calling time=09/03 09:51 orig called=
Regards!
09-08-2010 09:12 AM
Hi Anthony,
Did you find out where is the problem?. I was thinking in resetting the CUE, but I don't want to lose mail-boxes and configuration.
Regards.
09-12-2010 10:39 PM
Sorry about the delay. When the PSTN party hangs up the phone with when they're connected to an IP phone user, does the IP phone user hears any tone?
-Anthony
09-13-2010 12:30 AM
Yes, the ip phone user listens the hung tone.
09-13-2010 12:33 AM
Immediately? Is it a fast busy or dial-tone? It looks like your provider is using disconnect tone for disconnect supervision. I may need you to get PCM captures so we can define a custom disconnect tone.
09-13-2010 10:23 AM
It is a busy tone.
09-13-2010 11:55 AM
Can you get PCM captures for the call so that I can get an audio sample of the disconnect tone?
09-13-2010 12:36 AM
Can you also get the same debugs "debug vpm signal" when you call an internal extension that does not have this problem? Indicate in the debugs once the pstn disconnects.
Anthony
09-13-2010 10:21 AM
09-14-2010 01:32 AM
09-15-2010 07:45 AM
There's nothing in the PCM capture file. They may have been captured for the wrong port. Are you using CCA or the CLI to capture PCM traces?
09-15-2010 08:39 AM
Hi Anthony,
I did it with CLI following this tutorial: https://www.myciscocommunity.com/docs/DOC-8419. I tried with CCA, but it does not allow to save the resultant file, the window that appears after getting the samples only allows open a file, instead of save, must be a CCA bug, you can see it in the picture.
I made a mistake the first time because I started getting the samples before placing the call, I apologise. Now I got a 8Mb file.
09-19-2010 08:29 PM
Can you give this a try-
voice class custom-cptone custom_disconnect
dualtone busy
frequency 425
cadence 200 198
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone custom_disconnect
Let me know how that works. I may need to tweak the cadence measurements even more if it doesn't work.
-Anthony
