auto_attendant uc560 can not call internal extension
majid omeir
Dear all
i am having problem enabling user to dial employee extension after he hears the greeting message ,it says invalid number although the extension is valid
and i have enable dial by number any time .the configuration is as shown in the attached image any help will be appreciated
2 Accepted Solutions
Steven DiStefano
Does the user have a voicemail box in CUE?
It's a bug. If CCA doesn't create a mailbox user it's also not creating a user on CUE Open a case for the workaround or create a voice mail box
Steven DiStefano
no they do not have yet ,but what is  the link between calling extension from Auto_attendant and enabling voicemail ???????????????
