09-07-2010 09:09 AM - last edited on 03-25-2019 10:53 PM by ciscomoderator
I've set up a B-ACD que with one member, when the hunt timeout ends the "All agents busy" prompt plays and then the call disconnects. I would like it to continue to hunt on the member until the phone is picked up. Have I missed something in the config or is there something wrong?
Here's the application config:
application
service aaservice0 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
param aa-pilot 352
paramspace english index 0
param second-greeting-time 30
paramspace english language en
param call-retry-timer 15
param voice-mail 502
param max-time-call-retry 600
param service-name bacd
param number-of-hunt-grps 1
paramspace english location flash:/bacdprompts/
param drop-through-option 1
param handoff-string aaservice0
param max-time-vm-retry 1
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
param number-of-hunt-grps 10
param aa-hunt2 A360
param queue-len 30
param queue-cme-debugs 1
param aa-hunt1 A352
Hunt group config:
ephone-hunt 50 sequential
pilot A352
list 501
timeout 14
no-reg pilot
statistics collect
description *** CCA BACD ***
"show ephone-hunt 50 stat" shows this. What makes the call abandoned?
Tue 17:00 - 18:00
Max Agents: 1
Min Agents: 1
Queue related statistics:
Total calls presented to the queue: 4
Calls answered by agents: 0
Number of calls in the queue: 0
Average time to answer (secs): 0
Longest time to answer (secs): 0
Number of abandoned calls: 1
Average time before abandon (secs): 30
Calls forwarded to voice mail: 0
Calls answered by voice mail: 0
Best regards
Markus
09-08-2010 07:14 AM
You have 10 hunt groups defined in the queue, but only one defined in the aa, and you are actually only pointing to a single hunt group. param number-of-hunt-grps should match the amount of aahunt options you have configured, and should be the same in both the aa and the queue.
Ensure that you have MOH configured on CME, as well.
Since you didn't include your whole configuration, I assume that your ephone-hunt pilot is configured for A352?
Typically 'paramspace english index 0' is specified instead of 'paramspace english index 1'. Is there a reason why you have index 1 configured instead of 0?
Be sure to restart the whole application after you make parameter changes, so that they take effect, too.
09-09-2010 12:19 AM
Interesting, now when I think about it it did work before I removed MoH. Will add it back in to se how it reacts.
"Typically 'paramspace english index 0' is specified instead of 'paramspace english index 1'. Is there a reason why you have index 1 configured instead of 0?"
No idea, it's all configured using the CCA. Could it be that the UC is localized to Swedish?
Best regards
Markus
09-09-2010 06:31 AM
MOH is a requirement for BACD to work. That's mentioned in the BACD config guide. So if you removed MOH, adding it back in should fix it.
