02-01-2013 07:46 AM - edited 03-21-2019 06:56 AM
To simplify BE 6000 ordering process for Disti and direct orders, we are introducing the new ordering structure.
The following are some highlights. Ordering guide will be published on Feb 4th 2013.
New System ordering work flow:
Step 1. Order a BE6000 Server Bundle : BE6K-ST-BDL-K9=
Note: For deployments that require high availability, order two server bundles for redundancy.
If you need a secondary power supply, order UCSC-PSU-650W= as spare part
Step 2. Select the top-level SKU R-CBE6K-K9, and choose a Software Starter Bundle
BE6K-START-UCL25 - includes 25 ENHANCED user license and 25 advanced voice mail licenses
BE6K-START-UWL25 - include 25 Cisco UWL standard licenses
Note: Choose only one Software Starter Bundle per BE6000 deployment. If you purchased more than one server for redundancy, you should purchase only one Software Starter Bundle. Registering more than one Software Starter Bundle on one BE6000 cluster will be rejected.
Step 3. Add additional user licenses. To enable more users beyond the users included in the starter bundle, you can select the appropriate quantities of the license depending on your user profiles (Table 7). One BE6000 deployment can have both UCL licenses and UWL licenses.
Step 4. Select a software version.
Step 5. Select IM and presence deployment options
Step 6. Order optional soft clients
Step 7. Select a software subscription
03-04-2013 06:14 AM
Hello
Today I found an issue with the BE6K-ST-BDL-K9= SKU. I cannot select just smartnet services for the BE6K HW Bundle. What if a customer does not want to use the VCS licenses?
Please see the image for details.
Adolfo
03-04-2013 07:39 AM
Hi Adolfo,
Did you see this today? This issue should have been fixed now.
Andy
03-04-2013 07:46 AM
Yes Andrew, I am seeing the issue now.
03-04-2013 09:34 AM
Adolfo,
We are working on this issue right now. Will keep you updated.
Jing
03-04-2013 11:59 AM
I've also noticed today that I cannot validate R-CBE6K-K9.
03-04-2013 12:03 PM
I had the same issue in Netformx.. I opened a case with them and they are working on it with Cisco.
Jim
03-04-2013 12:07 PM
Cindy, could you please add more information on how did the validation fail?
Jing
03-04-2013 12:11 PM
It appears they've resolved the issue in CCW but the problem still exists in Netformx DesignXpert. The service problem where we can not only add SmartNet and not coverage for VCS on the BE6K server still exists.
03-04-2013 08:37 PM
Any update on the issue? I still get an error when selecting smartnet for BE6K-ST-BDL-K9= on CCW. It requires me to add services for VCS Control.
03-07-2013 10:27 AM
The issue has been resovled today. Please try order on CCW again.
Now you can order smarnet on BE6000 server without ordering VCS services.
To order VCS services, please go to ECMU to order seperately.
Jing
05-06-2013 05:04 AM
Hello
Today I cannot validate a BE6K Licensing Config when the Webex MC bundle is included, could you help me to check?
CCW is showing the following message:
"A selection from Add Cisco Contact Center Express and / or Add WebEx Meeting Center is allowed when a selection made from Software starter bundles. Please make your selection."
Adolfo
05-06-2013 08:09 AM
Hi Adolfo,
I will contact our CCW team to get this resolved. Please stay tuned.
Jing
05-15-2013 04:46 AM
Hello.
I have a question about HA deployments. You stated earlier that for UCCX HA the HA license for UCCX (L-CCX-90-PHA-L-K9=) has to be ordered separately...
Does the same apply for CUCM? Is an addon server license required for a CUCM Subscriber running on the redundant UCS BE6000 server?
If so what does "Note: For deployments that require high availability, order two server bundles for redundancy." imply?
This is only the hardware requirement for HA? Software licenses and/or features required for redundancy must be ordered as addons?
05-15-2013 05:01 AM
Hi Kenan,
No license addon has to be ordered in order to get redundancy at CUCM 9.x level. You just have to order a second server bundle (BE6K-ST-BDL-K9=)
Goswin
10-21-2013 03:35 AM
HI,
I have an another question: with the part number BE6K-START-UWL25 I'm able to add until 25 IP Phones 79xx?
Best Regards,
Alexandre.
