취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
Blast Group to Hunt Group - OOB
Joseph Chambers
UC560 - 15.0(1)XA2
Wanted call flow:
Call 3216 which would hit blast group & if they didn't answer, go to hunt group 5020 and if he didn't answer, go to 3000.
So this is what I did.
voice hunt-group 92 parallel
final 5020
list 3233,3133,3210,3110,3220,3120,3228,3128,3234,3134
timeout 20
pilot 3216
ephone-hunt 21 sequential
pilot 5020
list 3207
final 3000
timeout 8
no-reg pilot
statistics collect
description Svc Final
The blast group worked fine.  But call would disconnect when it sent to Hunt Group 5020.  If you called HG 5020 directly, it worked great.
Any idea of how to fix?
I wanted to go OOB to use DID directly.
1 응답 1
Faris Hamdan
Hello Joe,
Since Voice hunt groups are subject to the "max-redirect" restriction, I would suggest to increase its value, by default it is "10"
it is a global command under the telephony-service. for example:
telephony-service
max-redirect 20
I think what is causing the problem in your call flow is the number of times call is being redirected.
I hope that this will help.
Faris
