09-16-2010 07:11 AM - edited 03-21-2019 03:00 AM
Happening on 2 525 - in both cases only started after upgrade
dialing numbers, pressing handsfree, even dtmf in a call
502/504 fine
Stuart
09-21-2010 02:16 AM
Hi Stuart;
(In order to replicate it properly), can you provide a description of the deployment scenario and potentially a configuration file (remove any private info)?
regards
Alberto
09-21-2010 04:15 PM
config is nothing special -what we have used for ages - only change was firmware upgrade
The two of us with 525 both got it.
This is definitely a UI / phone state issue - no sip messag flow
For UI we use normal stuff + softkeys, ldap directory, device feature sync and we have an XML phone app
We have had to go back to previous firmware as was unusable when it happened.
I noticed it most when dialing "on hook" ie hands free as you enter the number the phone will present liist of previous numbers that match,
I thought it was just restricted to that, however we also got it going between handsfree and the handset during a call..
I also go it using the keypad to generate dtmf during a call - so not screen related
Not using bluetooth or wifi.
not a problem on 502/504 on same firmware and now very similar config (now other 502/4 bugs resolved)
Sorry cant help more
PS I have a more pressing need to get the other couple of issues I have raisded resolved
11-15-2010 12:14 PM
I have a similar issue but it's very pronounced when using my SPA525G on the WiFi network. I have attached a short video clip of how my system dials a an internal 5 digit extension to our conference bridge.
