Buffer I/O error on device hda1, logical block 81934
Telcocapital
I getting the follow erro message when I session into the CUE of the UC520. All advice appreciated. I read the similar post, however  I'm not given any prompts to make a selection.
Processing manifests . Error processing file exceptions.IOError [Errno 5] Input/output error
. . . . . . Error processing file zlib.error Error -3 while decompressing: invalid distances set
. . . . . . . . Error processing file zlib.error Error -3 while decompressing: invalid distances set
. . complete
==> Management interface is eth0
malloc: builtins/evalfile.c:138: assertion botched
free: start and end chunk sizes differ
Stopping myself.../etc/rc.d/rc.aesop: line 478:  1514 Aborted                 /bin/runrecovery.sh
Serial Number:
INIT: Entering runlevel: 2
********** rc.post_install ****************
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
STARTED: cli_server.sh
STARTED: ntp_startup.sh
STARTED: LDAP_startup.sh
STARTED: SQL_startup.sh
STARTED: dwnldr_startup.sh
STARTED: HTTP_startup.sh
STARTED: probe
STARTED: superthread_startup.sh
STARTED: ${ROOT}/usr/bin/products/herbie/herbie_startup.sh
STARTED: /usr/wfavvid/run-wfengine.sh
STARTED: /usr/bin/launch_ums.sh
Waiting 5 ...Buffer I/O error on device hda1, logical block 70429
Waiting 6 ...hda: no DRQ after issuing MULTWRITE
hda: drive not ready for command
Buffer I/O error on device hda1, logical block 2926
Buffer I/O error on device hda1, logical block 2927
Buffer I/O error on device hda1, logical block 2928
Buffer I/O error on device hda1, logical block 2929
Buffer I/O error on device hda1, logical block 2930
Buffer I/O error on device hda1, logical block 2931
Buffer I/O error on device hda1, logical block 2932
Buffer I/O error on device hda1, logical block 2933
Buffer I/O error on device hda1, logical block 2934
REISERFS: abort (device hda1): Journal write error in flush_commit_list
REISERFS: Aborting journal for filesystem on hda1
Jun 17 16:36:11 localhost kernel: REISERFS: abort (device hda1): Journal write error in flush_commit_list
Jun 17 16:36:11 localhost kernel: REISERFS: Aborting journal for filesystem on hda1
Waiting 8 ...MONITOR EXITING...
SAVE TRACE BUFFER
Jun 17 16:36:13 localhost err_handler:   CRASH appsServices startup startup.sh System has crashed. The trace buffer information is stored in the file "atrace_save.log". You can upload the file using "copy log" command
/bin/startup.sh: line 262: /usr/bin/atr_buf_save: Input/output error
Waiting 9 ...Buffer I/O error on device hda1, logical block 172794
INIT: cannot execute "/etc/rc.d/rc.reboot"
INIT: no more processes left in this runlevel
The flash card for CUE might be corrupt. Try and reinstall CUE and restore from backup to see if that fixes it. If it doesnt, try a different flash card.
Cole
I had format the router flash and updated to new version of ios. please could u tell me the flash files if required to run CUE...
