Hi,I would like to find out if the conference call can be made with the following scearios:- - UC 540 is currently setup with the key setup (4 POTS lines), each line is assigned to 1 outside line.- - If there is an active call on one of the but...
I have an odd issue, I have Auto Attendant setup to where a user can dial # and dial a 3 digit extension then # again to be transfered. This works for all of my phones except any Conference phone 7937G which I have 3 of them. Anyone ever seen this od...
Anyone know how to change the time on the UC560?Ours is currently off by 10 minutes.
Hi all,how can you set an "overlap" value on SPA8000 for sip re-register before the register expires time?Example:expires=”3600” and overlap=”60”, the SPA8000 will re-register after 3540 seconds (3600–60).SPA8000 try to re-register at 3540sWhat varia...
Hi, I need to setup my internal corporate Active Directory LDAP with my Phone SPA 502.The Phone return this error: LDIR:Failed;error=-1 (syslog) with Simple auth or MD5Wireshark capture:No. Time Source Destination ...
hello,i am wondering if there is a way to have the DND softkey enabled but instead of the phone handling DND send the desired feature code to the asterisk server to be able to see the DND status on a BLF of a SPA962 for example ? if i enable DND on t...
Hello DearsI would like to know if Cisco SPA 514G works with CCME 4.1 OR Call manager 6.0.1Best Regards
Hi,I'm trying to configure UC560 using CCA.After configuring all the parameters and when i press APPLY CONFIGURATION, the following dialog box appears.Kindly suggest.
hi all,I have two problem very like https://supportforums.cisco.com/thread/2201105,andhttps://supportforums.cisco.com/thread/2207667but there is not resolved,have any suggestion for this ?Thank you,Regards
I an trying to get two SPA's setup so one side is receiving a constant audio (paging audio from a phone system) and the other is connected to a page amp to deliver the audio. I have been told and have found blog posts that this is possible, but I can...
Добрый день прошу помощи в восстановление Cisco SPA502G.Описание неисправности.После обновления до версии 7.5.5 телефон пошел в перезагрузку, после чего, перестал, грузится. После включения питания ЗАЖИГАЮТСЯ 3 лампы приблизительно на 10 секунд, пото...
Hi Community.I have a customer that want to disable touch tones on their SPA 525 and 509 phones on their UC540.They don't want to disable DTMF, they just don't want to hear the tones when they press the buttons on the phone.Any idea ? Thanks in advan...
I hope someone can help me.I have recently ordered VOIP lines from my telephone service provider and they have provided me with SIP details in order to set up our Cisco phones.They have provided me with the following bits of informationNumber/usernam...
Are there any SIP ATAs with the pulse-dialing (rather than the DTMF dialling) method on FXS and FXO ports?Message was edited by: Tony Tony, typos corrected.
