11-08-2012 11:22 AM - edited 03-21-2019 06:34 AM
Hi all.
I have read a lot of documents and applied configuration changes to the voice-ports in my UC-520 but until now I can not get to work the incoming Caller ID function; I think it is a matter of matching parameters with my telephony company: Telmex in Mexico.
I did not find any reference for the telephone line specifications, so I was guessing but with no luck.
Does anybody have the Caller ID function properly in Mexico with Telmex and with UC500? Can share with me the configuration?
After many changes, I went back to the following configuration:
# show running
voice-port 0/1/0
trunk-group ALL_FXO 64
input gain 3
output attenuation 0
cptone MX
connection plar opx 201
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
UC_520>show voice port 0/1/0
Foreign Exchange Office 0/1/0 Slot is 0, Sub-unit is 1, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is Configured by CCA 4 FXO-0/1/0-OP
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 3 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar opx
Connection Number is 201
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for MX
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
I will apreciate any help.
Aurelio.
11-08-2012 12:57 PM
Have you verified first the caller ID works with a normal telephone ?
11-08-2012 03:13 PM
Yes, with a telephone set with caller-id, with every line before to conect to UC520.
11-08-2012 04:00 PM
There are settings for caller-id ring under voice-port, try that.
11-14-2012 06:55 PM
After erratic behavior of UC520 I decided to reinstall from scratch, configuring again by hand with CCA, not restoring any configuration, and now everything is working well. I think I did a mess with the configuratión using CCA and CLI. Sorry, my mistake.
So for Caller-id the default configuration works well, nothing additional to do.
Paolo, thanks for the help.
