Can not create or modify DHCP pool in UC560
Jacques Nguyen
I can't create new or modify existing DHCP pool inside our UC560 by using CCA 3.2.3 version: Configurate->Routing->DHCP server.  I always get error "invalid DHCP pool range. The default gateway IP address 192.168.2.1 must be within the range of the address excluded from the DHCP pool."
I check my DHCP exclude tab: I already have start IP: 192.168.2.1 and End IP 192.168.2.10.
I would like to know solution to modify my current DHCP pool or I can add new DHCP pool by using CCA.  If I have to use CLI, please let me know how to do it.
Jacques
Jacques Nguyen
Something with my configuration that CCA can't modify it.. It have to go through CLI
Jacque
