05-17-2012 11:34 PM - edited 03-21-2019 05:48 AM
Hi.I cannot access AA or voicemail using the CCA for configuration.I'm not very familiar with the voice CLI but I believe transcoding Is enabled.
I've tried everything on the CCA but no luck.
The startup config Is attached below , I would appreciate any assistance !
Solved! Go to Solution.
05-24-2012 02:31 AM
Hi.If It's really not going to put you out of your way , I'll wait until you have some time.Again.No rush.
Thanks again!
05-24-2012 08:38 AM
I contacted SBSC support and the guy was very helpful.In the end It was an old IOS version causing the problem.
Everything has been sorted out now! Thank you for all your help! I can die In peace now or I'm glad It's working to be less dramatic.
05-24-2012 01:37 PM
FANTASTIC!!!
Cheers,
David Trad
"Sent from my Acer Iconia A500"
On May 25, 2012 1:43 AM, "Reprovoid" <
