Can't connect to the GUI and CCA 2.0 with UC500
nealvarez
Hi all,
I recently delete my startup configuration, so now I have no configuration on my UC500. When I try to access the GUI and CCA using 10.1.1.1, It doesn't connect on either. The way im doing this is with my PC connected to a LAN port on the UC 500. Do I need to set up an IP address on the UC to be able to access the GUI? Thanks
Steven Smith
Level 7
Level 7
Yes, you will need to setup an IP address to access the GUI.  But, if you can console in, you can copy the default config that is on flash to the startup config and reboot the box.
