Can UC560 work with 3560 Switch?
Tim Brown
I have a UC560 and ESW520 switch.  Customer already has 3560 switch.  Does UC560 have to work with ESW520?
David Trad
Hi Tim,
The 3560 should work and should have enough PoE capabilities, however you would need to manually program the switch up using CLI or Cisco Configuration Professional, and you would need to get our support from the Netpro forums not the SMB one like this one
It would be easier to just use the new SF/SG-300 series, they are better suited for the UC-500 series, but that is a sales thing and something for you to work out internally
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
