01-24-2012 02:32 PM - edited 03-21-2019 05:14 AM
I thought I remembered that there was some command line operations that were CCA 3.x compliant. Does anyone have a link to this info?
Solved! Go to Solution.
01-24-2012 09:25 PM
Hi Jforbis,
You can read THIS thread which also has a link to the PDF document there for the OOB guide lines.
However I will point out the following:
Before you commit yourself to CLI modifications please check with this forum first to make sure that we cannot achieve what you want using CCA, in theory CCA should be able to do 90-95% of yoru configuration with ease.
Cheers,
David.
01-24-2012 09:25 PM
Hi Jforbis,
Cheers,
David.
01-25-2012 06:23 AM
David... Thank you for the help. You are a great resource for this forum. I appreciate it.
One thing I am looking for is a way to change the phone of a user without deleting and recreating the user. Lets say I have a user with CIPC and they will be getting a 7945. Is there an easy way to accomplish this thru CCA?
01-25-2012 06:52 AM
In theory yes you can, so long as the following conditions are meet:
1. Phone "A" is no longer registered to the system I.E not plugged in and talking to the system
2. Phone "B" is also not currently registered and belonging to any other ephone (not a DN)
So assuming phone "B" is a new phone, you will go to phone "A" details in CCA' and right at the top you will input in the new MAC address of the new phone ("B"), then change the phone type and appropriate codec for it.
I have done this on more than one ocassion although I have been told you are not suppoosed to be able too, but the above conditions must be meet
Hope this helps you out.
Cheers,
David.
