Hi Diego,
This is not yet available for the UC-500 series system, I believe though that it might be on the agenda for later releases.
Cheers,
David.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
