Cisco Mobile 8.1
aacosta78
please i need your help
how to configure a cisco mobile 8.1 on a uc540w?
best regards
David Trad
Hi Diego,
This is not yet available for the UC-500 series system, I believe though that it might be on the agenda for later releases.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
