cisco spa 51x and 50x Failed - Not Reachable for firmware 7.6.2b , 7.6.2c , 7.6.2d only
inforoutedit
Beginner
Beginner
when i upgrade my spa phones 514G and 504G to any of these firmware 7.6.2b , 7.6.2c , 7.6.2d i got
Failed - Not Reachable . for any other firmware version like  7.6.2a the phone works fine . with same config , same network and same every thing , anyone can test this issue and tell me why i am having this . i am doint this upgrade to check if the new firmware is fixing a bug which is :
disable dialing missing number when offhook
My suspection gets confirmed.
Phone starts TLS handshaking sending Client Hello. It wish to start TLS 1.0 session using either TLS_RSA_WITH_AES_256_CBC_SHA or TLS_RSA_WITH_AES_128_CBC_SHA cipher. Server is immediately refusing it responding "Handshake Failure". It mean "unable to negotiate an acceptable set of security parameters given the options available".
So server limits are behind the issue. It seems the support for some protocol or cipher suites known to be insecure or broken has been removed from phone firmware, but server is so ancient to support more recent ciphers. E.g. server supports no TLS 1.0 protocol while phone's support for insecure SSLv3 protocol has been dropped. Or cipher lists on phone and server side have empty intersection.
All at all - unless server will be upgraded to something less ancient (or, may be, just reconfigured to allow newer ciphers/protocols), you can use no newest phone firmware to speak with it.
You may consider to remove attachment from your previous comment. It contain packets unrelated to the issue and they may reveal information you wish not to disclose. I will attach filtered version of capture containing relevant packets only here.
This post contain information related to other's site thus it may contain information considered Sensitive or Confidential.
10 Replies 10
Dan Lukes
Advocate
Advocate
I had used 7.6.2b on my SPA508G ando now I have 7.6.2.d running on it. I has been affected by no issue during upgrade from neither 7.6.2a nor 7.5.5.
I don't know what you mean "not reachable". During firmware upgrade ? Durign access to WWW UI ? During attempt to establish incoming call ?
Turn on syslog&debug logs and catch them. They may reveal the issue cause.
i get this message in the :
Ext 1 Status Registration State:    Failed - Not Reachable
after finishing the upgrade and waited for the registration to happen
i will check enabling the syslog and update here
OK, so the issue is related to SIP registration. Then catch the SIP packets (and ICMP, of course) between phone and upstream PBX to analyze the issue.
For example, "broken" firmware may use other source port to send messages and registration gets rejected by a firewall, incorrect configuration of phone has been tolerated by former firmware, but its not accepted by current one, ...
ok i am getting these err using syslog debug 3
05-13-2018 13:09:48 Local0.Info 10.1.3.84 ### Get Sip Tcp Port = 5063
05-13-2018 13:09:48 Local0.Info 10.1.3.84 Getting a SIP TCP port for line 0
05-13-2018 13:09:46 Local0.Info 10.1.3.84 [0]SIP/TCP:Connect Failed; Backoff 2000 ms
05-13-2018 13:09:46 Local0.Info 10.1.3.84 [0]SIP/TLS:Connect Failed -1
05-13-2018 13:09:46 Local0.Info 10.1.3.84 [0]SIP/TLS:Connecting ...
05-13-2018 13:09:46 Local0.Info 10.1.3.84 [0]SIP/TCP:Connect=0, errno=42
05-13-2018 13:09:46 Local0.Info 10.1.3.84 [0]SIP/TCP:Connecting...(11)
05-13-2018 13:09:46 Local0.Info 10.1.3.84 ### Get Sip Tcp Port = 5063
05-13-2018 13:09:46 Local0.Info 10.1.3.84 Getting a SIP TCP port for line 0
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP/TCP:Connect Failed; Backoff 1000 ms
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP/TLS:Connect Failed -1
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP/TLS:Connecting ...
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP/TCP:Connect=0, errno=42
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP/TCP:Connecting...(11)
05-13-2018 13:09:45 Local0.Info 10.1.3.84 ### Get Sip Tcp Port = 5063
05-13-2018 13:09:45 Local0.Info 10.1.3.84 Getting a SIP TCP port for line 0
05-13-2018 13:09:45 Local0.Info 10.1.3.84 +++ ts 0x94fcc6b0 clean 0 9502a300 9502a470 bcts:1 nRef:0
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP:RegFailed;Retry in 30s
05-13-2018 13:09:45 Local0.Info 10.1.3.84 SIP_tsClientEventProc ts:0x94fcc6b0 event 60 state:1
05-13-2018 13:09:45 Local0.Info 10.1.3.84 [0]SIP/TCP:Connect Failed; Backoff 500 ms
same config for both VOIP server for all phones ( TLS ONLY ) and as i said all phones works fine using firmware 7.6.2a   .
what do you think of these err messages ?
btw there is no FW between the VOIP and the Phone andno VLANS
They are clear - TCP connect has failed. So, now you need to debug TCP connection setup. Catch the packets (full content of packet). I will allow us to analyze why the TCP connection setup is not successful.
I suspect TLS parameters behind the issue, but it's just blind shot.
can you tell me how to enable debug TCP connection setup?
I told it. Capture packets between phone and PBX. Full content of packets. Don't forget ICMP.
here is a complete Packets between the phone and the VOIP using the PC-SW port mirror and wireshark
VOIP server IP is 10.1.3.202
SPA Phone ip is 10.1.3.84
Thanks for your great info and help , i will upgrade the TLS on the server
Recognize Your Peers
