Cisco SPA112 Dial Plan
My VoIP provider stated that they allow a blind transfer of a call via the SPA112 but that they don't provide the needed Dial Plan configuration to perform the transfer. Anyone know how to set this up? Here is the default:
(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
The transfer requires a # dialed first then the 10-digit number after hitting the hook / flash switch.
Finally found the short way of making this work:
  1. Click on Voice menu on the top
  2. Click on the Regional menu on the left
  3. Scroll down to Vertical Service Activation Codes
  4. Change Blind Transfer Code to #
  5. Save & Reboot
Thanks to my VoIP wholesaler for the fix on this.
Dan Lukes
You need to know how to call particular target phone (format of local call/intercity call/interstate call/international call). .Dial plan describes those formats. Format may vary between countries, or even between VoIP providers. Dial plan for one provider will vary from dial plan for other provider. Dial plan is nothing we can just guess.
Note the default dial plan is for North America Numbering Plan Areas (and all providers following NANPA numbering plan).
This is not an answer to the question, just stating the obvious. I am in the North America Numbering Plan Areas. Need to add to the dial plan something that allows the use of the # sign to transfer calls in the blind.
You are answering to self - if you wish to dial same patterns just with leading # in advance to patterns you have already, then repeat all patterns you have with leading #  added.
It's obvious answer - and it's why I'm not sure I understood yours issue.
  5. Save & Reboot
