09-04-2019 03:41 PM
My VoIP provider stated that they allow a blind transfer of a call via the SPA112 but that they don't provide the needed Dial Plan configuration to perform the transfer. Anyone know how to set this up? Here is the default:
(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
The transfer requires a # dialed first then the 10-digit number after hitting the hook / flash switch.
Solved! Go to Solution.
09-06-2019 04:35 PM
Finally found the short way of making this work:
Thanks to my VoIP wholesaler for the fix on this.
09-06-2019 09:02 AM
You need to know how to call particular target phone (format of local call/intercity call/interstate call/international call). .Dial plan describes those formats. Format may vary between countries, or even between VoIP providers. Dial plan for one provider will vary from dial plan for other provider. Dial plan is nothing we can just guess.
Note the default dial plan is for North America Numbering Plan Areas (and all providers following NANPA numbering plan).
09-06-2019 03:59 PM
@Dan Lukes wrote:You need to know how to call particular target phone (format of local call/intercity call/interstate call/international call). .Dial plan describes those formats. Format may vary between countries, or even between VoIP providers. Dial plan for one provider will vary from dial plan for other provider. Dial plan is nothing we can just guess.
This is not an answer to the question, just stating the obvious. I am in the North America Numbering Plan Areas. Need to add to the dial plan something that allows the use of the # sign to transfer calls in the blind.
09-06-2019 05:18 PM
You are answering to self - if you wish to dial same patterns just with leading # in advance to patterns you have already, then repeat all patterns you have with leading # added.
It's obvious answer - and it's why I'm not sure I understood yours issue.
09-06-2019 04:35 PM
