Hello!
I configured the following setting via the available tutorial
(Forwarding PSTN Calls to a VOIP number on SPA3102 found here: http://www.cisco.com/en/US/products/ps10024/products_qanda_item09186a0080a359ae.shtml)
Firmware: Analog Telephone Adaptor (ATA) Firmware-5.2.13
Setting:
PSTN call --> 0043720123456789@sipgate.at
PSTN display name: blank
PSTN CID for VOIP CID: yes
PSTN Answer delay set to 3 (seconds)
caller ID method Bellcore
caller ID FSK standard bell202
Country: Austria (Bellcore and bell202 should be correct, isn't it?)
Behavior:
Dect phone on other fxo plug shows correct caller ID,
IP Phone shows always same caller ID from VOIP 0043720123456789 instead of real caller ID.
Is it possible that the correct caller ID on the voip phone is displayed?
I'm a newbie. Tried various settings found in forum entries without success.
As the caller ID feature is important for me I'd be glad to get support.
Thanks for your assistance!
KR H.
