Continual reboot 5xx phones when different values in Profile_Rule_*
MichaelIsaev
I have provisioning on my SPA 5xx phones:
<Profile_Rule_B>tftp://tftpserver/ipphone/linksys/spa-all.cfg</Profile_Rule_B>
<Profile_Rule_C>tftp://tftpserver/ipphone/linksys/$PSN.cfg</Profile_Rule_C>
<Profile_Rule_D>tftp://tftpserver/ipphone/linksys/mac/$MA.cfg</Profile_Rule_D>
There are parameters in $MA.cfg and spa-all.cfg files with the same name but different values.
Because of this phone reboots when resync time occured.
What can be done to avoid this rebooting?
Patrick Born
Hi Michael,
When the phone boots, it loads the parameters from the config files. If an important parameter has changed, then the phone reboots. From your description, the parameters change every resync due to the content of the files.
There is no need to duplicate values, it's a best-practice to use the fewest possible number of parameters to obtain peak phone performance. The phones have sane factory defaults in that they will work by default without changing anything.
You will need to configure registration and user information, perhaps some other desirable parameters such as backlight, network timers, and so on, specific to your users and network. That's it, you shouldn't need more than about 100 lines of configuration parameters between all the configuration files.
The following may be of use to you:
Patrick
