CRM and UC520
mikemavris
Hello.
I have a CRM server and a client pc. I have install the CRM call connector and works fine between the pc and the server.(I cant have calls because no configuration exist to the connector for the uc520)
Now how I connect the server with the uc520?
The connection between the Call Connector client and the UC500 is via TAPI. By default, each phone on the UC500 can support a TAPI client whose credentials are the username and password configured in CCA, or under the "ephone" command line interface.
https://www.myciscocommunity.com/docs/DOC-1406
Marcos
