CUCME XML API Capablilities
raluca.butnaru
Hello all,
I represent a company that develops call accounting solutions for enterprises. Part of our features is handeling CUCM entities such as directory numbers or forced authorization codes (for example changing the level for an authorization code, for call restrictions) throug AXL, from our web application.
Could anyone tell me to what extent is this possible with a CUCME? I know that there is a different API for CUCME, but I dind't find details on its capabilities (lots of GET functions a one EXECCLI command - not documented). In addition, what happens behind the scenes when both CUCM and CUCME exist in the system?
Thank you,
Raluca
David Hornstein
Level 7
Level 7
Hi Raluca,
Maybe you should look at the developer site at Cisco and see if the question has been answered there of pose your question there.
http://developer.cisco.com/web/sxml/home
Serviceability XML Developer Guides
http://developer.cisco.com/web/sxml/docs
regards Dave
