CUE 3.0.3 error changing default language
Damian Halloran
I'm trying to change the default language on a UC500 with CUE3.0.3 installed. Everything appears to go fine until the end when the error: "Did not find bzImage Signature in core manifest" comes up and the change is aborted. I've tried new versions of files to see if any were corrupt but the same problem occurs.
Attached is the output from the attempts.
Assistance greatly appreciated.
owillins
Level 6
Level 6
This looks to be a problem were the system is not responding to the internal install commands. Please try to upgrade the CUE using Boot Helper
Hi, Thanks for the reply but I eventually solved the problem by installing the new version via CCA.
