CUE - how to use schedule in script
roderick.cwps
I have set up businesshours as M-F 8:30 to 5:00 and eveninghours as M-F 5:00pm to 9:00pm. How do I Set a schedule variable MySchedule to one the schedules?
Set property:
Variable: MySchedule
Assign: ???
Brandon Buffin
Create a schedule variable and assign it a value of "systemschedule" or the name of your schedule if you've configured something other than the default in CUE. Then use a Business Hours step under General in the CUE Editor. Add the step, then right-click > properties and reference your schedule variable. You will now have a branch for Open and one for Closed under Business Hours so you can route the call based on the schedule.
Hope this helps.
Brandon
It worked. Thank you, Brandon.
