06-24-2012 05:57 PM - edited 03-21-2019 09:48 AM
Hello!
I am getting a debug message when I attempt to upgrade my SPA2102 to the latest firmware 5.2.13 from 5.2.12 and I get this message after I input the admin password and click OK:
Run-Time Check Failure #2 -Stack around the variable 'strNc' was corrupted.
(Press Retry to debug the application)
If I click on Retry, the firmware update program crashes.
My computer is running Windows 7 Enterprise SP1.
Any assistance would be appreciated.
Richard S.
Solved! Go to Solution.
06-25-2012 06:19 AM
See below link. I had a similar problem:
06-25-2012 06:19 AM
06-25-2012 10:25 AM
Hi Rinku!
Thanks for the information and your assistance. That did the trick! I was able to upload the new firmware to the SPA2102 without any problems.
Thanks again!
Richard S.
10-09-2012 12:01 AM
Could you post the actual answer here? I'd really appreciate it.
For me
https://communities.cisco.com/thread/27606?tstart=0
returns
"your Cisco.com login does not have the authority level to access this site"
10-09-2012 01:01 AM
Hi Craig,
I get the same response when I try to access the link. I found the same information that I used:
https://supportforums.cisco.com/docs/DOC-9907
Hope this helps!
Richard
10-22-2013 12:04 PM
Please click on IGNORE button and give atry. It will work.
