08-25-2010 10:27 AM - edited 03-21-2019 02:55 AM
It sends *DB out my Sip trunk so I'm getting a busy signal immediatly. What can I do to keep it inside? Also, it was trying to register the dn's with my service provider, so I manually cleaned that up. I'm very excited for this feature to work with CCA, but I think I need a tweak yet.
Stephanie
08-26-2010 08:37 PM
Hm... doesn't sound right that it would send *DB to your SIP provider.
Can you provide your 'show run' excluding the pwds and enable the following debugs when you try to use dialable intercom?
Anthony
08-27-2010 02:09 PM
08-27-2010 02:11 PM
I tried to send this over as well
08-27-2010 02:21 PM
08-27-2010 02:36 PM
We found the problem and we are actively working on resolving this. As a workaround you would need to go into the CLI and shutdown one of your dial-peers.
Can you post your 'show run' output excluding the pwds? I'll be able to tell you which dial peers to shutdown.
Anthony
08-27-2010 02:38 PM
08-27-2010 02:40 PM
Does your SIP trunk provider support star codes? If not you'll need to shut down these dial peers for dialable intercom to work in the interim-
dial-peer voice 1001
shut
dial-peer voice 1002
shut
Anthony
08-27-2010 02:51 PM
Seems to have done the trick. Thank you for the help. I'm not positive if my provider supports star codes, but most likely not.
Again
Thanks!
08-29-2010 05:05 PM
NP. Good to hear you're all set.
-Anthony
