You are running into a limitation of the technology you are using. Analog phone lines can only have a single number associated with a given line. You're best bet would be to direct calls to an auto attendant or a receptionist for call routing. If you require this functionality you will either need an ISDN line or a SIP trunk.
Learn, share, save
