DIDs are not working properly
robdowns
So the UC-520 blew up on an upgrade and after working with TAC to recover from that, it was just quirky.  Decided to just blow it all away and start from scratch.  Everything seemed to be working, but my DIDs don't ring their assigned extensions, but it rings the Call Blast group like my primary number.  I've unassigned them, reassigned them and still the same thing.  I looked at the discussions and didn't see the same issue, so I'm posting it here hoping to spare myself a TAC case.  Thanks.
Darren DeCroock
Level 4
Level 4
Your incoming dial-peers should be pointing to a translation profile that translates the number to and internal extension...  To give you a more specific answer, you would need to post your current config, and possibly a debug of an incoming call if everything looks correct in your configuration.
