DnD, will do what you are seeing.
See user guide of the phone are refer the DND section.
Below is the Clip from the document :-
Do Not Disturb; prevents incoming calls from ringing your phone.
See “Setting Do Not Disturb,” on page 46.
Ronak patel
Please rate helpful posts.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
