Error Message on CUE with %SYS-3-TIMERNEG: Cannot start timer
hi,
I am getting this error message on the CUE every 10 secs. How do I stop this message appearing this meessage?
Message details-
A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:00.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1486548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:10.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1496548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:20.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1506548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:30.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1516548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:40.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1526548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
regards,
arman
7 Replies 7
antyeung
Level 4
Level 4
Are these messages seen when you are on the CLI of CME or when you are sessioned into CUE?
-Anthony
Hi Anthony,
These messages are seen when I am on the CLI of CUE.
Arman
It would be best to open a TAC case to diagnose this issue. To clarify are there any symptoms that are service impacting besides these error messages appearing on the console when session into cue?
Anthony
Nope there is no other symptoms other than that error message.
It's always good to be proactive :-)
Opening a TAC case would be best to understand those error messaages.
Anthony
I have just did a factory reset on this device to install form the scratch to see whether that message come up. If it doesn't show up then it would be an issue with my config. So far it looks good.
That's one stealth config you got...
Anthony
