10-22-2009 06:51 AM - edited 03-21-2019 01:41 AM
inluded is the screen shot...
UC520
Anyone else having this?
Going into security - NAT
Just adding a basic NAT
click apply and error
10-27-2009 07:39 AM
10-28-2009 05:51 AM
This may be a configuration error. Are you trying to use vlan 100 for outside interface? VLAN 100 is used for voice subnet. You may want to use interface fastethernet 0/0 (WAN) for outside interface.
-Saurabh
10-28-2009 06:42 AM
of course im using FastEthernet0/0.
From a brand new config this is how the error is reproduced.
First delete all firewall settings
Second delete NAT settings
create a VLAN, say 50, create DHCP pool, etc
Make sure FastEthernet0/0 is DHCP
now go into NAT, and try anything that makes a change and requires saving... BOOM error
this is with CCA2.1
from the CLI I have NAT outside for FastEthernet0/0
Nat inside for the VLANs 1 and 50, but not the BVIs (maybe thats an issue)
I also have attempted doing the "VLAN database" and recreating the vlan.dat
so I can ping from the FastEthernet0/0 to outside, but can not ping the outside from any other interface (vlan)
10-28-2009 07:13 AM
Let me run this scenario by the CCA engineering team.
-Saurabh
11-04-2009 04:17 AM
problem is resolved in CCA 2.1.1 !!!!!!!
11-04-2009 04:26 AM
thanks for the good news!!!!!
