Error Unable to get list of config files from the Cisco UC320W
btopiwala
Small Business UC320W Configuration Utility ver 2.3.2 (6)
When I try to login UC320W I get the following error screens below. the login screen just freeezes up. Is there a way to reload the config for the UC320W via USB or another way.
Screen 1
Fatal ERROR
Error: Unable to get list of config files from the Cisco UC320W
CI286
Screen 2
Scanning
Loading 100%
I get the the following messages again and again. Urgernt need assistance
Please email me @ lfernandez@sigmametals.ca
flemmanu
Hi Bhav
To reload the config via USB you need to login .
Also check if you are using the compatible browser and flash player.
I advise you to contact Cisco Small Business Support Center.  If you cannot login to the device, there may still be a chance to recover your device.  Our Customer Support personnel should be able to assist you in recovering your UC320W.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cheers,
Florence.
