External Access to UC560 for IMAP
mmurrayinno4
Community Member
I would like to set up external access to my UC560 for IMAP for iPhones and Outlook clients. Everything works great on the LAN, not I want to extend it to off-net devices. I have a DNS entry pointing to my static IP. The UC560 is also my edge device to the WAN interface is plugged into the cable modem. What is the config I need on the UC560 as far as NAT and access rules go? My current interface configs are below:
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address 24.24.24.24 255.255.255.224
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface Vlan90
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
can you please post your ACL 103 and 104.
regards
- Please rate helpful posts -
