02-09-2015 12:15 AM - edited 03-21-2019 08:32 AM
in deep past has always worked...
when SPAXXX starting or syncing in period phone detect firmave version on TFTP/HTTP server and where necessary, updated firmware ... Now don't do it:-( Now phone syncing only cfg:-(.
How can I setting auto upgrade FW?
Thanks Michal.
Solved! Go to Solution.
05-23-2015 02:09 PM
It work still the same way. Upgrade Enable to yes and fill the Upgrade Rule. Note it will not fetch the same file again (e.g. Upgrade Rule same) if it has been already fetched. Other firmware needs to have other filename. But's also still the same behavior.
05-23-2015 02:09 PM
05-29-2015 07:07 PM
Re-posted discussion to to SPA IP Phones.
