Forwarding incoming PSTN call over fxo port
syarifsyahrir
Dear all,
How do I make redirects each incoming calls from PSTN lines via the FXO port 0 to port FXO others already incorporated (I mean port 1 until port 3 made into one port group?
So the core of my question, how to make redirects call the FXO port and make group the FXO port?
We use the MGCP configuration Loop Start on voice gateways and CUCM 10.x
Hopefully we can get the answers to our case here.
thank you
josh000014
With FXO ports, for incoming calls from the PSTN your provider will need to configure the roll over for the lines. They can normally create hunt groups for the lines you want.
Josh
