GSM Gateway
hotrot_net
How about a GSM Gateway form Cisco.
I got a lot of client that have the UC520 that want to use a GSM Gateway there are 3rd party product, but they want a cisco.. Is there anything out there? Or in the nearby future?
Or is there a recommend Gateway by Cisco?
Greetings
Andy Gribnau
7 Replies 7
Steven Smith
Level 7
Level 7
I think this should help.
http://www.cisco.com/en/US/prod/routers/ps380/3g_solns.html
We have a few routers that support this as some ISR's that you can hwic's for.
Steven
Dear Steven,
Thats a datagateway..( if i;m not mistaking). I want to be able to place calls trough GSM like  these
http://www.voip-info.org/wiki/view/VOIP+GSM+Gateways
Greetings
Andy Gribnau
We do not have a product like this in our portfolio. You could potentially connect something like this to a Communications Manager Express (CME) device using SIP, but it is something that we have not tested with any vendor.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Dear Marcos,
Thank you for you're reply.. I;m disapponed but never the less, thanx for the info.
I've already got 2 client runnig with ISDN to GSM gateway (form there previos PBX) , other client would like to see a cisco option.
Greetings
Andy Gribnau
Do you want the Cisco device to replace the PBX or the GSM gateway? If you are talking about connecting Cisco to the GSM gateway via ISDN, that should be doable.
Marcos
Dear Marcos,
No not replace a UC500.!!!!!!!!!!!!!! ;)
What I allready have in use is a UC500 with a GSM ISDN gateway. For a new client i want a CISCO GSM (VOIP) gateway . But as you don't manufactur these thats not an option.
Greetings
Andy
I did some research, and it appears that there might be a Cisco products that support this in the future, but unfortunately, I cannot say when it will be supported or in which products.  Sorry about that.
Steven
