Help configuration spa3102 with soft phone
Hackgen_1
Hi guys,
is 2 days trying to get my SPA3102 but I can not.
Let me explain better my situation.
I bought an SPA3102, my requirement is to remote my telecom phone line to use it even in my home is equipped with a secondary connection to the Internet.
I first tried to run locally SPA3102,
x lite using the software, but I can not make calls and receive phone software. I connected an analog phone to the SPA3102, and I can only receive calls not to do them.
Then I should be able to make phone calls via a software type XLite,
first course from my local network and then remote from my second home.
I attach mht file configuration, I hope in some pious soul who can help me.
Thank you all, see you soon
Andrey Cassemiro
Hi Hackgen,
Is it pending yet?
If yes, please tell me that i can help you to setup this scenario.
Regards.
Andrey Cassemiro.
Well I need help in the same scenario.
Thank you in advance
