02-01-2013 01:07 AM - edited 03-21-2019 06:56 AM
I have completed initialized and configured first E1 interface, but can not find the second E1 interface in the GUI.
Can you help me?thanks.
Solved! Go to Solution.
02-01-2013 01:35 AM
To add the second E1/T1 interface (assuming that this wasn't configured from the First Time Setup Wizard, follow:
1. Connections > PSTN Connections
2. Add PSTN Connection
3. Choose E1 or T1 and click next
4. Device type should be CUCMBE3000 and Device Internal Gateway - click next
5. Click next to accept the default Cisco Digital Access "Service Provider".
6. Set your preferred Description and protocol type. You can use the advanced settings if you need to.
7. Click finish
Hope that helps,
Andy
02-01-2013 01:35 AM
7. Click finish
Hope that helps,
Andy
02-05-2013 06:11 AM
it's ok.thanks for your support.
