Showing results forĀ
Search instead forĀ
Did you mean:Ā
How far will a FXS run to a remote phone on UC320W
David Hornstein
Level 7
Level 7
Hi Joel,
I posted the answer here from a product engineer, because it is very relevant to other folks who probably have the same question.
There should be no problem  ringing a phone(<=1 REN) with 1200 feet 24AWG wire.
UC320W has higher ringing voltage(53Vrms vs. 40Vrms) and it should ring a phone from longer distance.
However we don't recommend this kind of off premise usage as the FXS port, as the FXS port is  designed for on premise use.
The protection circuit may not be strong enough to survive the high voltage introduced by lightening, if the cable is run between building and not in metal conduit.
If the cable goes outside the building, it could very well be susceptible to lightening and other induced interference.
regards Dave
nalbert
Level 4
Level 4
Dave,
Answer from our engineer Yong
"For the ring capability, There should be no problem to ring a phone(<=1 REN) with 1200 feet 24AWG wire.  Phonebooth has higher ringing voltage(53Vrms vs. 40Vrms) and it should ring a phone from longer distance. However we donā€™t recommend this kind of off premise usage. The issue is safety. The FXS port of this product is designed for on premise use. The protection circuit may not be strong enough to survive the high voltage introduced by lightening.  If the cable go outside the building, it is suseptable to lightening and other interference."
