How to change port number and protocol for SIP trunk?
IdontNeedNick
I have to connect a UC500 with two asterisk IPT systems.
First asterisk system use standard SIP port 5060 , but UDP instead of TCP.
Second one use port number 5070 and UDP protocol.
How to setup these two trunks with different parameters ?
O
ADAM CRISP
Level 4
Level 4
Hello.
You can specify the transport using the "session transport" keyword; the default is UDP.
The port number can be set following by using a colon
eg
dial-peer voice 9000 voip
description "route calls starting 9xxx to by asterisk endpoint"
destination-pattern ^9...
session protocol sipv2
session transport UDP
session target ipv4:192.168.69.1:5070
dtmf-relay rtp-nte
Adam
ADAM CRISP
Level 4
Level 4
Hello.
eg
dtmf-relay rtp-nte
Adam
Hi Adam,
thank you for replay,
I will try your solution...
BR,
O
