How to propagate CFWD to Asterisk
petr.hrbek
I have problem with propagation of CFWD setting by soft button to Asterisk 11 PBX. I have set Vertical Service Activation Codes for CFWD, I experimented with Feature Dial Services Code parameter but with no succcess. Setting by star code *72 works well.
Is there any simple instruction how to set it? Thanks
Petr
Dan Lukes
Phone can announce the user (de-)activated the CFWD to PBX, but
1. you will not get the target number
2. it is unreliable announcement, so if you are unable to process it, you will be out of sync
3. PBX can't reject user's attempt to set CFWD if inapropriate
Also, CFWD can't be driven by PBX at the same time.
Note you must not allow call forwarding to emergency numbers in Czech Republic. You should handle attempt to forward call to itself as well. It's not possible to do it in full with forwarding handled by phone.
My proposal is ...
Don't use phone's embedded forward logic. Disable it at all here. Handle forwarding at PBX level instead. If you have spare line button, the BLF feature can be used as visual notification of the current state.
