How to Register SPA8800 with SPA9000?
CSCO11605023
The title sums it up. What I have done so far is this:
Cisco SPA9000
Static IP: 192.168.1.200
Subnet Mask: 255.255.255.0
Gateway: 192.168.1.1
DNS Server: 192.168.1.1
Proxy: 192.168.1.201
SIP Port: 5060
User ID: SPA9000
Display Name: SPA9000
Password: 12345
Auth ID: SPA9000
Use Auth ID: Yes
Cisco SPA8800
Static IP: 192.168.1.201
Proxy: 192.168.1.200
SIP Port: 5060
User ID: SPA9000
Display Name: SPA8800
Password: 12345
Auth ID: SPA9000
Use Auth ID: Yes
But it keeps showing registration failed, any suggestions how to make it register?
nseto
Level 6
Level 6
Units registering to spa9000, needs to know what the 'proxy listen port' and 'phone ext password' on the spa9000 is set to.
By default the 'proxy listen port' is 6060 and 'phone ext password' is blank.
These parameters are in the SIP tab of the spa9000.
So by default, I would be putting in the "192.168.1.200:6060" for the proxy parameter of the spa8800.  And no password if the 'phone ext password' is blank.  The userID should be the ext number that you want the spa8800 to be.
