Inbound call from SIP Provider reply with “SIP/2.0 500 Internal Server Error”
Ivan Ivanov
   Hello, I need to configure inbound calls from SIP provider to UC520 and then to CUCM 8.6.2
The calls do no go through, when a trace is performed the SIP Trunk Provider says UC520 replying with "500 internal server error" in response to inbound call. I know about this article https://supportforums.cisco.com/document/36761/siph323-trunks-cisco-unified-communications-500-series-cisco-smart-business and i include address of SIP provider in ACL CCA_SIP_SOURCE_GROUP_EXTERNAL, but “SIP/2.0 500 Internal Server Error” is still there.
2277613 – sip account address
213.221.38.31 – destination IP address
237.29.52.93 – provider address
84952204279 – calling number
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 4
translation-profile incoming SIP_Incoming
access-list 4 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 4 remark SDM_ACL Category=1
access-list 4 permit 192.168.10.1
access-list 4 permit 10.1.10.0 0.0.0.3
access-list 4 permit 192.168.10.0 0.0.0.255
access-list 4 permit 10.1.1.0 0.0.0.255
voice translation-profile SIP_Incoming
 translate called 411
voice translation-rule 411
 rule 1 /^9\(.*\)/ /ABCD9\1/
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 5
access-list 5 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 5 remark SDM_ACL Category=1
access-list 5 permit 125.241.242.99
access-list 5 permit 237.29.52.93
access-list 5 deny   any
dial-peer voice 2277613 voip
description ** to_CUCM **
destination-pattern 2277613
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
Dial-peer 20002  pots  up   up           BCD$           0                    50/0/9
dial-peer voice 1000 voip
 permission term
 description ** Incoming call from SIP trunk  **
 voice-class sip dtmf-relay force rtp-nte
 session target sip-server
 incoming called-number .%
 dtmf-relay rtp-nte
 fax rate 14400
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
048658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2277613@213.221.38.31:5060 SIP/2.0
Via: SIP/2.0/UDP 237.29.52.93:5060;branch=z9hG4bK73c3a1bd;rport
Max-Forwards: 70
From: "84952204279" <sip: 84952204279@237.29.52.93>;tag=as02915454
To: <sip:2257411@213.248.38.34:5060>
Contact: <sip:84959508179@237.29.52.93:5060>
Call-ID: 04554ce459fdd9816bbe9a6a269440ba@237.29.52.93:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 1.8.11.0
Date: Wed, 25 Nov 2015 07:23:42 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Remote-Party-ID: "84952204279" <sip: 84952204279@237.29.52.93>;party=calling;privacy=off;screen=yes
Content-Type: application/sdp
Content-Length: 474
v=0
o=root 1829443402 1829443402 IN IP4 217.29.51.90
s=Asterisk PBX 1.8.11.0
c=IN IP4 217.29.51.90
t=0 0
m=audio 17908 RTP/AVP 18 4 3 0 8 9 10 7 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=no
a=rtpmap:3 GSM/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:10 L16/8000
a=rtpmap:7 LPC/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
048659: //7314/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
048660: //-1/75F8956CA201/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
   cisco-username=84952204279
   ----- ccCallInfo IE subfields -----
   cisco-ani=84952204279
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2277613
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
048661: //-1/75F8956CA201/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x85E159CC, Call Info(
   Calling Number=84952204279,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2277613 (TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=7314
048662: //-1/75F8956CA201/CCAPI/cc_api_call_setup_ind_common:
   SPI Call Setup Request Is Failed
048663: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 25 Nov 2015 07:39:14 GMT
Allow-Events: telephone-event
Content-Length: 0
To: <sip: 2277613@213.248.38.34:5060>;tag=7E60034-1CA5
Call-ID: 04554ce459fdd9816bbe9a6a269440ba@217.29.51.90:5060
CSeq: 102 INVITE
Server: Cisco-SIPGateway/IOS-12.x
048664: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip: 2277613@213.248.38.34:5060 SIP/2.0
Max-Forwards: 70
Contact: <sip: 84952204279@237.29.52.93:5060>
CSeq: 102 ACK
Content-Length: 0
048665: //-1/775A9815A205/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=BCD
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
048666: //-1/775A9815A205/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8745537C, Call Info(
   Calling Number=BCD,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
048667: //-1/775A9815A205/CCAPI/ccCheckClipClir:
   In: Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
048668: //-1/775A9815A205/CCAPI/ccCheckClipClir:
   Out: Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
048669: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
048670: :cc_get_feature_vsa malloc success
048671: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
048672:  cc_get_feature_vsa count is 1
048673: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
048674: :FEATURE_VSA attributes are: feature_name:0,feature_time:2298929320,feature_id:4933
048675: //7315/775A9815A205/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=BCD(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
048676: //7315/775A9815A205/CCAPI/cc_process_call_setup_ind:
   Event=0x8655DDF0
048677: //7315/775A9815A205/CCAPI/ccCallSetContext:
   Context=0x88C3CC5C
048678: //7315/775A9815A205/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 7315 with tag 20002 to app "_ManagedAppProcess_Default"
048679: //7315/775A9815A205/CCAPI/ccCallSetupAck:
   Call Id=7315
048680: //7315/775A9815A205/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
048681: //7315/775A9815A205/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=7315
048682: //7315/775A9815A205/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
048683: //7315/775A9815A205/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
048684: //7315/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x1C93, digit_event=0x1, enable=TRUE, consume=FALSE)
048685: //7315/775A9815A205/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=7315
048686: //7315/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x8745537C, callID=0x1C93, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
048687: //7315/775A9815A205/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x8745537C, Call Id=7315
048688: //7315/775A9815A205/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
048689: //7315/775A9815A205/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=7315, Digit=A, DigitBeginFlags=0x0,
   Rtp Timestamp=0x19C89218, Rtp Expiration=0x0
048690: //7315/775A9815A205/CCAPI/cc_api_call_digit_end:
   Source Call Id=7315, Digit=A, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
048691: //7315/775A9815A205/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
048692: //7315/775A9815A205/CCAPI/cc_api_call_digit_begin:
   Source Call Id=7315, Digit=B, DigitBeginFlags=0x0,
   Rtp Timestamp=0x19C90F18, Rtp Expiration=0x0
048693: //7315/775A9815A205/CCAPI/cc_api_call_digit_end:
   Source Call Id=7315, Digit=B, Duration=100,
048694: //7315/775A9815A205/CCAPI/cc_api_call_digit_end:
048695: //7315/775A9815A205/CCAPI/cc_api_call_digit_begin:
   Source Call Id=7315, Digit=C, DigitBeginFlags=0x0,
   Rtp Timestamp=0x19C98C18, Rtp Expiration=0x0
048696: //7315/775A9815A205/CCAPI/cc_api_call_digit_end:
   Source Call Id=7315, Digit=C, Duration=100,
048697: //7315/775A9815A205/CCAPI/cc_api_call_digit_end:
048698: //7315/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x1C93, digit_event=0x0, enable=FALSE, consume=FALSE)
048699: //7315/775A9815A205/CCAPI/ccCallReportDigits:
048700: //7315/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x8745537C, callID=0x1C93, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
048701: //7315/775A9815A205/CCAPI/cc_api_call_report_digits_done:
048702: //7315/775A9815A205/CCAPI/cc_api_call_report_digits_done:
048703: //7315/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
048704: //7315/775A9815A205/CCAPI/ccCallReportDigits:
048705: //7315/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
048706: //7315/775A9815A205/CCAPI/cc_api_call_report_digits_done:
048707: //7315/775A9815A205/CCAPI/cc_api_call_report_digits_done:
048708: //7315/775A9815A205/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
048709: //7315/775A9815A205/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
048710: //7315/775A9815A205/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
048711: //7315/775A9815A205/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8745537C, Tag=0x0, Call Id=7315,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
048712: //7315/775A9815A205/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
048713: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
048714: :cc_free_feature_vsa freeing 8906E0A0
048715: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
048716:  vsacount in free is 0
blakeflorin
uc560 getting a sip trunk from freepbx....same error, referenced that same fix document also.   In my incoming dial plan I had the country code listed in the DID numbers.  Dropped that so its 10 digit string.  Poof, calls come in.
I swear in the documentation it stated country code must be specified for call forwarding, single number reach, etc...to work correctly?   Hope that might help.
