is it possible to access the PSTN line to dial * and # for Telecom's special numbers?
I ofter forward the calls to another number directly from the Telecom line with *21* etc. I tried various ways to create a dial plan but it doesn't work.
Is there a way to do this?
Thanks to all
Roberto Ercolano
Alberto Montilla
Yes, should be able to do it.
(1) Write the phone dial plan, the call routing rule and the Line X dial plan (where SPA400 is connected) to accept and route * and # numbers you define.
(2) Make sure the short code is not already listed on the [Regional] Tab. if it is there there will be a conflict, so please delete it.
Alberto
