Is there a "Cisco Recommended" wireless headset for the SPA 504G Phones?
Hello, Is there a "Cisco Recommended" wireless headset for the SPA 504G Phones?
Please let me know.  Thank you, Paul
Darren DeCroock
Level 4
Level 4
Hello Paul,
I can't say there is one that is "recommended", but here is a link to some that have been tested with the SPA phones.
https://supportforums.cisco.com/docs/DOC-9926
Thank you,
Darren
Cisco SPA 504G phones can be tricky for headsets because of the 2.5mm headset jack.  Go here for details:
http://headsetplus.com/category99_108/index.html
I'd recommend the Plantronics CS540, W740, Jabra 9450, or Jabra 920.  They are all compatible with the 504G.
David Trad
Hi Paul,
My recommendation would be the "Plantronics Savii 700 series" which have worked consistently and without issues, you need the HL-10 Handset lifter with them which work with the SPA-500 series.
The Savii series come as DECT for when you are using it with a phone (Waaaaaaaaaaaaaay better reception than Bluetooth) and Bluetooth for when you have it synced with a computer at the same time, it also comes with combination headset connectors so you can have one over the head, or around the neck or even just hanging over the ear.
I fully recommend them with the 500 series phones.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
