Is there an option In cue to enable redial without dial edit ?
Reprovoid
Hi.
  I've Installed a UC540w with spa504g phones In a small office.An extension Is used for outgoing calls as per usual.The customers want to press redial directly for missed calls but they have to Instead press redial followed by edit dial to add the extension number for outgoing calls.
  I can't seem to find any settings on the phone to fix this.Is there any configuration I can change through CCA or via the CLI to allow direct redial ?
Davidwagman1
Level 7
Level 7
Create a translation rule to add your outgoing prefix to incoming calls, ie
voice translation-rule 5
rule 1 /\(..........\)/ /91\1/
voice translation-profile 1
translate calling 5
in dial peers or voice ports:
translation-profile incoming 1
This uses 9 as the outgoing prefix. It takes ph # like 5551113333and converts it to 915551113333 for outgoing calls. You may need to modify this to fit your needs/carrier. This example also assumes US ph #. Please let me know if you are overseas, or if you can modify the translation rule to fit your local dial plan.
Best,
David
Please rate helful posts.
Davidwagman1
Level 7
Level 7
translate calling 5
Best,
David
Thank you!
