ISSUE with VOIP
jmmoralesf
Hi good mornig, I have a strange issue with an UCM560 , let me explain.
Actually this device  is configred  witth a  SIP trunk  to a provider. in order to have connectivity VOIP with the rest of the organization  the ucm is connected to a Cisco 1750 using this one as voip gateway and then connecting 2 fxo ports of the ucm560 to the 1750.
It works in the direction fron office to centrl, but when we call from central to this office the call finishes when the cue takes the call.
This problem began when we change from h323 to sip
Any idea  ?
Thanks in advance.
Kevin Monteiro
Level 7
Level 7
Do post the "show tech" output of both the gateway.
Kevin
Sent from Cisco Technical Support Android App
Here the sh tech of both devices
#sh tech-support C1700
------------------ show version ------------------
IOS (tm) C1700 Software (C1700-IPVOICE-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 14:24 by dchih
ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
N* uptime is 23 weeks, 1 day, 1 hour, 5 minutes
System restarted at 13:46:59 UTC Mon Sep 2 2013
System image file is "flash:c1700-ipvoice-mz.123-26.bin"
cisco 1751-V (MPC860P) processor (revision 0x300) with 55706K/9830K bytes of memory.
Processor board ID JAD064704H3 (4236365223), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show running-config ------------------
Building configuration...
Current configuration : 2987 bytes
! Last configuration change at 14:48:58 UTC Tue Feb 11 2014 by z
version 12.3
service timestamps debug uptime
service timestamps log datetime
service password-encryption
hostname *
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
aaa new-model
aaa authentication fail-message ^C
Your connection attempt has been logged and will be investigated.
DISCONNECT IMMEDIATELY!
^C
aaa authentication login authentication local group radius
aaa authorization exec authorization local group radius
aaa session-id common
ip subnet-zero
ip cef
no ip domain lookup
voice service voip
h323
sip
voice class codec 3
codec preference 1 g729r8
codec preference 2 g711alaw
voice class codec 2
codec preference 3 g711ulaw
fax interface-type fax-mail
username privilege 15 password
interface FastEthernet0/0
ip address *.*.180.10 255.255.255.0
no ip redirects
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr *.*.180.10
ip classless
ip route 0.0.0.0 0.0.0.0 *.*.180.1
ip route *.*.180.0 255.255.255.0 *.*.180.9
no ip http server
logging trap emergencies
logging source-interface FastEthernet0/0
logging *.*.2.186
snmp-server community RO
snmp-server trap-source FastEthernet0/0
radius-server host auth-port 1812 acct-port 1646 key 7
radius-server retransmit 2
radius-server timeout 3
voice-port 0/0
timeouts interdigit 3
voice-port 0/1
dial-peer cor custom
dial-peer voice 1801 pots
destination-pattern 1801
port 0/0
dial-peer voice 1802 pots
destination-pattern 1802
port 0/1
dial-peer voice 1 voip
description Rome
destination-pattern 5....
voice-class codec 3
session protocol sipv2
session target ipv4:*.*.1.13
dial-peer voice 155 voip
description Panama
destination-pattern 155.
voice-class codec 3
session target ipv4:*.*.155.9
dial-peer voice 248 voip
description Chile
destination-pattern 248....
voice-class codec 2
session target ipv4:*.*.248.9
banner motd ^C
* - Authorised use only.
All connection attempts are logged, monitored and reviewed.
If you are NOT an authorised user, please DISCONNECT!
^C
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
1764/3000   allegro libretto init
5584/6000   CPE MMI SNMP
7836/12000  Init
5464/6000   RADIUS INITCONFIG
2576/3000   Rom Random Update Process
35292/36000  TCP Command
7404/12000  Virtual Exec
Interrupt level stacks:
Level    Called Unused/Size  Name
  3           0   9000/9000  PA Management Int Handler
  4  3680884813   7884/9000  Network interfaces
  5           0   9000/9000  Timebase Reference Interrupt
  6         206   8920/9000  16552 Con/Aux Interrupt
  7  3500186361   8920/9000  MPC860P TIMER INTERRUPT
------------------ show interfaces ------------------
FastEthernet0/0 is up, line protocol is up
  Hardware is PQUICC_FEC, address is 000a.b742.1390 (bia 000a.b742.1390)
  Internet address is 168.202.180.10/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 4 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     22382869 packets input, 1693804642 bytes
     Received 22165745 broadcasts, 0 runts, 0 giants, 0 throttles
     52 input errors, 41 CRC, 0 frame, 10 overrun, 0 ignored
     0 watchdog
     1868147 packets output, 193393932 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
------------------ show controllers ------------------
Interface FastEthernet0/0
Hardware is PQUICC MPC860P ADDR: 822CC644, FASTSEND: 8047A934
DIST ROUTE ENABLED: 0
Route Cache Flag: 11
ADDR_LOW =0x000AB742, ADDR_HIGH =0x00001390, HASH_HIGH =0x00000100, HASH_LOW =0x00000000
R_DES_ST =0x0377DD40, X_DES_ST  =0x0377DE80, R_BUFF_SIZ=0x00000600, ECNTRL   =0xF0000006
IEVENT   =0x00000000, IMASK     =0x0A000000, IVEC      =0xC0000000, R_DES_ACT=0x01000000
X_DES_ACT=0x00000000, MII_DATA  =0x50821000, MII_SPEED =0x00000014, R_BOUND  =0x00000600
R_FSTART =0x00000500, X_FSTART  =0x00000440, FUN_CODE  =0x7F000000, R_CNTRL  =0x00000004
R_HASH   =0x750005F2
X_CNTRL  =0x00000004
HW filtering information:
  Promiscuous Mode Disabled
Software MAC address filter(hash:length/addr/mask/hits):
pquicc_fec_instance=0x822CEA64
rx ring entries=32, tx ring entries=32
rxring=0x377DD40, rxr shadow=0x822CECA4, rx_head=14, rx_tail=0
txring=0x377DE80, txr shadow=0x822CED50, tx_head=16, tx_tail=16, tx_count=0
RX_RING_ENTRIES
status 8000,  len 40, buf_ptr 3785920
status 8000,  len 40, buf_ptr 37A0AA0
status 8000,  len 40, buf_ptr 37A3740
status 8000,  len 40, buf_ptr 378EBC0
status 8000,  len 40, buf_ptr 37898E0
status 8000,  len 40, buf_ptr 379A4A0
status 8000,  len 40, buf_ptr 379D7A0
status 8000,  len 40, buf_ptr 378AC00
status 8000,  len 40, buf_ptr 37A1DC0
status 8000,  len 40, buf_ptr 379D140
status 8000,  len 40, buf_ptr 3794500
status 8000,  len 60, buf_ptr 378B260
status 8000,  len 40, buf_ptr 378FEE0
status 8000,  len 40, buf_ptr 37971A0
status 8000,  len 60, buf_ptr 3790540
status 8000,  len 40, buf_ptr 37A30E0
status 8000,  len 40, buf_ptr 3796B40
status 8000,  len 40, buf_ptr 3797E60
status 8000,  len 40, buf_ptr 378CBE0
status 8000,  len 40, buf_ptr 3782C80
status 8000,  len 40, buf_ptr 37A1100
status 8000,  len 60, buf_ptr 378C580
status 8000,  len F7, buf_ptr 3787F60
status 8000,  len 40, buf_ptr 3786C40
status 8000,  len 40, buf_ptr 379C480
status 8000,  len 40, buf_ptr 3784600
status 8000,  len 40, buf_ptr 3780640
status 8000,  len 60, buf_ptr 37964E0
status 8000,  len 40, buf_ptr 37A3DA0
status 8000,  len 95, buf_ptr 3781960
status 8000,  len 95, buf_ptr 3792520
status A000,  len 40, buf_ptr 377E660
TX_RING_ENTRIES
status 0,  len 4A, buf_ptr 3669DEA
status 0,  len 3C, buf_ptr 3668E4A
status 0,  len 52, buf_ptr 37EB22A
status 0,  len 3C, buf_ptr 37EA8CA
status 0,  len 24E, buf_ptr 366AD8A
status 0,  len 24E, buf_ptr 36697AA
status 0,  len 8C, buf_ptr 366A74A
status 0,  len 24E, buf_ptr 3669ACA
status 0,  len 24E, buf_ptr 366B3CA
status 0,  len 24E, buf_ptr 37EA28A
status 0,  len 24E, buf_ptr 366948A
status 0,  len 24E, buf_ptr 366B0AA
status 0,  len 24E, buf_ptr 37EABEA
status 0,  len 24E, buf_ptr 366A42A
status 0,  len 24E, buf_ptr 37EAF0A
status 0,  len 24E, buf_ptr 366880A
status 0,  len 24E, buf_ptr 37EB86A
status 0,  len 24E, buf_ptr 37EB54A
status 0,  len 24E, buf_ptr 37EA5AA
status 0,  len 24E, buf_ptr 366AA6A
status 0,  len 24E, buf_ptr 366A10A
status 0,  len 24E, buf_ptr 37E9C4A
status 0,  len 3C, buf_ptr 366B0AA
status 0,  len 40, buf_ptr 37EABEA
status 0,  len 3C, buf_ptr 36672CA
status 0,  len 3C, buf_ptr 366880A
status 0,  len 3C, buf_ptr 37EB86A
status 0,  len 3C, buf_ptr 37EB54A
status 0,  len 3C, buf_ptr 37EA5AA
status 0,  len 3C, buf_ptr 366AA6A
status 0,  len 3C, buf_ptr 366A10A
status 2000,  len 3C, buf_ptr 37E9C4A
throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=10
rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
PHY registers:
Register 00 1000
Register 01 7829
Register 02 7810
Register 03 0003
Register 04 01E1
Register 05 C1E1
Register 06 000B
Register 16 0000
Register 17 0000
Register 18 4000
Register 19 0800
Register 20 38C8
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*  6 vty 0     z           idle                 00:00:00 *.*.1.30
  Interface    User               Mode         Idle     Peer Address
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show file systems ------------------
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     rw   system:
       29688       25434     nvram     rw   nvram:
           -           -   network     rw   snmp:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
*   33554428    20974588     flash     rw   flash:
           -           -   network     rw   rcp:
           -           -   network     rw   pram:
           -           -   network     rw   ftp:
           -           -    opaque     ro   cns:
------------------ dir nvram: ------------------
Directory of nvram:/
   24  -rw-        3151                      startup-config
   25  ----          27                      private-config
    1  -rw-           0                      ifIndex-table
29688 bytes total (25434 bytes free)
------------------ show flash: all ------------------
Partition   Size    Used      Free      Bank-Size  State          Copy Mode
  1        32767K  12285K    20482K    16384K      Read/Write     Direct
System flash directory:
File  Length   Name/status
        addr      fcksum  ccksum
  1   12579776  c1700-ipvoice-mz.123-26.bin
        0x40      0xC493  0xC493
[12579840 bytes used, 20974588 available, 33554428 total]
   Chip    Bank    Code      Size      Name
    1      1       8918      16384KB    INTEL 28F128J3
    1      2       8918      16384KB    INTEL 28F128J3
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   821A106C    22476052     7864036    14612016    14323852    14116920
      I/O    3666800    10065920     1748984     8316936     8290928     8316892
------------------ show process memory ------------------
Total: 32541972, Used: 9612784, Free: 22929188
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0     347244      10892    5314084          0          0 *Init*
   0   0      12656     320636      12656          0          0 *Sched*
   0   0   12041396    5472232     146848     407448          0 *Dead*
   1   0          0          0       6892          0          0 Chunk Manager
   2   0        188        188       3892          0          0 Load Meter
   4   0      65580          0      90472          0          0 EDDRI_MAIN
   5   0          0          0       6892          0          0 Check heaps
   6   0   36561956    2557900      31992   33802680   33983648 Pool Manager
   7   0        188        188       6892          0          0 Timers
   8   0         76          0       6968          0          0 ARP Input
   9   0        188        188       6892          0          0 ATM Idle Timer
  10   0        188        188       6892          0          0 AAA high-capacit
  11   0        188        188       6892          0          0 DDR Timers
  12   0       8604       1496      14000          0          0 Entity MIB API
  13   0          0          0       6892          0          0 HC Counter Timer
  14   0        188        188       6892          0          0 Serial Backgroun
  15   0        188        188       6892          0          0 SMART
  16   0        188        188       6892          0          0 GraphIt
  17   0        188        188      12892          0          0 Dialer event
  18   0          0          0       6892          0          0 SERIAL A'detect
  19   0          0          0       6892          0          0 Critical Bkgnd
  20   0      23984          0      16200          0          0 Net Background
  21   0        188        188      12892          0          0 Logger
  22   0        188        500       6892          0          0 TTY Background
  23   0          0          0       9892          0          0 Per-Second Jobs
  24   0          0          0       3892          0          0 IPM_C1700_CLOCK
  25   0          0          0       3892          0          0 dev_device_inser
  26   0          0          0       3892          0          0 dev_device_remov
  27   0          0          0       6892          0          0 Net Input
  28   0        188        188       6892          0          0 Compute load avg
  29   0          0     819072       6892          0          0 Per-minute Jobs
  30   0          0          0      12892          0          0 AAL2CPS TIMER_CU
  31   0     404344     451248     238288          0          0 IPM DSPRM MAIN
  32   0          0          0       6892          0          0 AAA_SERVER_DEADT
  33   0        188        188       6892          0          0 AAA Dictionary R
  34   0      11980       1016      11936          0          0 AAA Server
  35   0          0          0       6892          0          0 AAA ACCT Proc
  36   0          0          0       6892          0          0 ACCT Periodic Pr
  37   0       1976        188       8680          0          0 CDP Protocol
  38   0     317488      86140      14444          0          0 IP Input
  39   0          0          0       6892          0          0 ICMP event handl
  40   0        376        376      12892          0          0 PPP Hooks
  41   0          0          0      12892          0          0 SSS Manager
  42   0          0          0      12892          0          0 SSS Test Client
  43   0          0          0       6892          0          0 SSS Feature Mana
  44   0          0          0       6892          0          0 SSS Feature Time
  45   0          0          0      12892          0          0 VPDN call manage
  46   0          0          0       6892          0          0 X.25 Encaps Mana
  47   0        188        188      12892          0          0 PPP IP Route
  48   0        188        188      12892          0          0 PPP IPCP
  49   0          0          0       9892          0          0 IP Background
  50   0        152          0      10044          0          0 IP RIB Update
  51   0      74664       1184      73896          0          0 CEF process
  52   0          0          0       6892          0          0 Socket Timers
  53   0          0          0       6892          0          0 SNMP Timers
  54   0          0      27140      12892          0          0 TCP Timer
  55   0     222400          0      12892          0          0 TCP Protocols
  56   0          0          0      24892          0          0 COPS
  57   0   23822312   23792668      22752          0          0 DHCPD Receive
  58   0        188        188       6892          0          0 Dialer Forwarder
  59   0        188        188       9892          0          0 Adj Manager
  60   0       1868          0      11760          0          0 HTTP CORE
  61   0          0      10740       6892          0          0 IP Cache Ager
  62   0          0          0       6892          0          0 RARP Input
  63   0          0          0       6892          0          0 PAD InCall
  64   0        188        188      12892          0          0 X.25 Background
  65   0        188        188       6892          0          0 PPP Bind
  66   0        188        188       6892          0          0 PPP SSS
  67   0        188        188       6892          0          0 CRM_CALL_UPDATE_
  68   0        436        188       7140          0          0 ASNL
  69   0        188        188       6892          0          0 ENABLE AAA
  70   0          0          0       6892          0          0 Key chain liveke
  71   0        188        188       6892          0          0 LINE AAA
  72   0       7908       3192       7160          0          0 LOCAL AAA
  73   6    1440000    1425636      27964       4536          0 Virtual Exec
  74   0      14064        188      20768          0          0 TPLUS
  75   0        188        188       6892          0          0 VSP_MGR
  76   0      83900          0      93792          0          0 CCVPM_HTSP
  77   0        428          0       7320          0          0 CCVPM_R2
  78   0        328          0       7220          0          0 CCSWVOICE
  80   0       1868          0       8760          0          0 http client proc
  81   0        324          0       7216          0          0 sssapp
  82   0       5444          0      12336          0          0 QOS_MODULE_MAIN
  83   0        268          0      25160          0          0 RPMS_PROC_MAIN
  84   0          0          0      24892          0          0 VoIP AAA
  85   0       1544      13664       6892          0          0 AAA SEND STOP EV
  87   0          0          0       6892          0          0 Syslog Traps
  88   0          0          0       6892          0          0 trunk conditioni
  89   0       1196          0       8088          0          0 trunk conditioni
  90   0          0          0       6892          0          0 VPDN Scal
  92   0        188        188       6892          0          0 CC-API_VCM
  93   0    2881328    2473236      84816          0          0 VTSP
  94   0      29656          0      54548          0          0 TSP
  95   0      75120     339324      14252          0          0 VOIP_RTCP
  96   0        536          0      13428          0          0 lib_off_app
  97   0        324          0       7216          0          0 pcapp
  98   0        324          0       7216          0          0 placecall
  99   0        512        188       7216          0          0 tcl ivr app
100   0        512        188       7216          0          0 tcl ivr app
101   0       5556        188      12260          0          0 tcl ivr app
102   0        512        188       7216          0          0 tcl ivr app
103   0        512        188       7216          0          0 tcl ivr app
104   0        512        188       7216          0          0 tcl ivr app
105   0        512        188       7216          0          0 tcl ivr app
106   0        512        188       7216          0          0 tcl ivr app
107   0        188        188       6892          0          0 Voice Player
108   0          0          0       6892          0          0 Media Record
109   0          0          0       6892          0          0 Resource Measure
110   0    2026504     846924     804988          0          0 Session Applicat
111   0    6678264    5950384     360852          0          0 CCH323_CT
112   0          0          0       6892          0          0 CCH323_DNS
113   0     698544     359888     349724          0          0 CCSIP_SPI_CONTRO
114   0          0          0       6892          0          0 CCSIP_DNS
115   0      79584     125732      27392          0          0 CCSIP_UDP_SOCKET
116   0       3320          0      28212          0          0 CCSIP_TCP_SOCKET
117   0     352836          0     377728          0          0 RTPSPI
118   0     164360        188     189064          0          0 CCFRF11_CT
119   0     206064        188     230768          0          0 CCAAL2_CT
120   0       8988       7600      13744          0          0 IP SNMP
121   0       7740          0      12892          0          0 PDU DISPATCHER
122   0      19960      28236      12892          0          0 SNMP ENGINE
123   0          0          0      12892          0          0 SNMP ConfCopyPro
124   0          0          0      12892          0          0 SNMP Traps
125   0      14976      12268      17284          0          0 RADIUS
126   0        472        188       7176          0          0 NTP
127   0          0          0       3892          0          0 C1700_RING_LIMIT
128   0        188          0       7080          0          0 CEF Scanner
129   0          0          0       6892          0          0 DHCPD Timer
130   0        188          0       7080          0          0 DHCPD Database
131   0          0          0       6892          0          0 faxmsp
132   0          0          0       6892          0          0 DocMSP
133   0     333832     333768       7040          0          0 fax timers
134   0          0          0      12892          0          0 esmtp client soc
135   0          0          0       6892          0          0 esmtp server soc
136   0        596          0      10524          0          0 Fax Onramp-VFC
                                  9610424 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 2%/1%; one minute: 2%; five minutes: 2%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         1          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2         184   2800147          0  0.00%  0.00%  0.00%   0 Load Meter
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5     9482044   1657183       5721  0.15%  0.10%  0.06%   0 Check heaps
   6        5848      1600       3655  0.00%  0.00%  0.00%   0 Pool Manager
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8     4627168  15040882        307  0.00%  0.03%  0.05%   0 ARP Input
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  10           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  11           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  12          12         2       6000  0.00%  0.00%  0.00%   0 Entity MIB API
  13          12    700037          0  0.00%  0.00%  0.00%   0 HC Counter Timer
  14           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  15           0         2          0  0.00%  0.00%  0.00%   0 SMART
  16         240  14000730          0  0.00%  0.00%  0.00%   0 GraphIt
  17           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  18           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  19           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  20         688   5600328          0  0.00%  0.00%  0.00%   0 Net Background
  21          28        44        636  0.00%  0.00%  0.00%   0 Logger
  22         112  14000669          0  0.00%  0.00%  0.00%   0 TTY Background
  23         544  14000747          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
  24        1368       326       4196  0.00%  0.00%  0.00%   0 IPM_C1700_CLOCK
  25           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  26           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  27         252      1304        193  0.00%  0.00%  0.00%   0 Net Input
  28          40   2800148          0  0.00%  0.00%  0.00%   0 Compute load avg
  29     9334224    234791      39755  0.00%  0.04%  0.05%   0 Per-minute Jobs
  30           0         1          0  0.00%  0.00%  0.00%   0 AAL2CPS TIMER_CU
  31          52         6       8666  0.00%  0.00%  0.00%   0 IPM DSPRM MAIN
  32           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  33           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  34           4        38        105  0.00%  0.00%  0.00%   0 AAA Server
  35           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  36           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  37      106160   1855024         57  0.00%  0.00%  0.00%   0 CDP Protocol
  38     2452472   5494175        446  0.23%  0.09%  0.09%   0 IP Input
  39           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  40           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  41           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  42           4   1866765          0  0.00%  0.00%  0.00%   0 SSS Test Client
  43           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  44         276  54690364          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  45           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  46           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  47           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  48           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  49         776    466498          1  0.00%  0.00%  0.00%   0 IP Background
  50        1816    233376          7  0.00%  0.00%  0.00%   0 IP RIB Update
  51        3976  25062490          0  0.00%  0.00%  0.00%   0 CEF process
  52           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  53           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
  54          36      1274         28  0.00%  0.00%  0.00%   0 TCP Timer
  55          16        13       1230  0.00%  0.00%  0.00%   0 TCP Protocols
  56           0         1          0  0.00%  0.00%  0.00%   0 COPS
  57       68848    110236        624  0.00%  0.00%  0.00%   0 DHCPD Receive
  58           4         2       2000  0.00%  0.00%  0.00%   0 Dialer Forwarder
  59         148    233347          0  0.00%  0.00%  0.00%   0 Adj Manager
  60           0     46671          0  0.00%  0.00%  0.00%   0 HTTP CORE
  61           0    233346          0  0.00%  0.00%  0.00%   0 IP Cache Ager
  62           0         2          0  0.00%  0.00%  0.00%   0 RARP Input
  63           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  64           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
  65           4         2       2000  0.00%  0.00%  0.00%   0 PPP Bind
  66           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  67           0    560031          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
  68           0         2          0  0.00%  0.00%  0.00%   0 ASNL
  69           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
  70           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
  71           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
  72          20        29        689  0.00%  0.00%  0.00%   0 LOCAL AAA
  73        3984      1849       2154  0.71%  0.18%  0.32%   6 Virtual Exec
  74           4         2       2000  0.00%  0.00%  0.00%   0 TPLUS
  75           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
  76         852      1439        592  0.00%  0.00%  0.00%   0 CCVPM_HTSP
  77           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
  78           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
  80           0         1          0  0.00%  0.00%  0.00%   0 http client proc
  81           0         1          0  0.00%  0.00%  0.00%   0 sssapp
  82           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
  83           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
  84           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
  85           0        12          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
  87           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
  88         144  14000628          0  0.00%  0.00%  0.00%   0 trunk conditioni
  89           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
  90           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
  92         116    116988          0  0.00%  0.00%  0.00%   0 CC-API_VCM
  93        4204      2889       1455  0.00%  0.00%  0.00%   0 VTSP
  94           4         1       4000  0.00%  0.00%  0.00%   0 TSP
  95         304       779        390  0.00%  0.00%  0.00%   0 VOIP_RTCP
  96           0         1          0  0.00%  0.00%  0.00%   0 lib_off_app
  97           0         1          0  0.00%  0.00%  0.00%   0 pcapp
  98           0         1          0  0.00%  0.00%  0.00%   0 placecall
  99           4         2       2000  0.00%  0.00%  0.00%   0 tcl ivr app
100           0         2          0  0.00%  0.00%  0.00%   0 tcl ivr app
101           0         2          0  0.00%  0.00%  0.00%   0 tcl ivr app
102           0         2          0  0.00%  0.00%  0.00%   0 tcl ivr app
103           4         2       2000  0.00%  0.00%  0.00%   0 tcl ivr app
104           0         2          0  0.00%  0.00%  0.00%   0 tcl ivr app
105           0         2          0  0.00%  0.00%  0.00%   0 tcl ivr app
106           0         2          0  0.00%  0.00%  0.00%   0 tcl ivr app
107           0         2          0  0.00%  0.00%  0.00%   0 Voice Player
108           0         1          0  0.00%  0.00%  0.00%   0 Media Record
109           0         1          0  0.00%  0.00%  0.00%   0 Resource Measure
110        1024      1670        613  0.00%  0.00%  0.00%   0 Session Applicat
111        5500      2640       2083  0.00%  0.00%  0.00%   0 CCH323_CT
112           0         1          0  0.00%  0.00%  0.00%   0 CCH323_DNS
113         340        79       4303  0.00%  0.00%  0.00%   0 CCSIP_SPI_CONTRO
114           0         1          0  0.00%  0.00%  0.00%   0 CCSIP_DNS
115         128        71       1802  0.00%  0.00%  0.00%   0 CCSIP_UDP_SOCKET
116           4         1       4000  0.00%  0.00%  0.00%   0 CCSIP_TCP_SOCKET
117          12         1      12000  0.00%  0.00%  0.00%   0 RTPSPI
118           4         2       2000  0.00%  0.00%  0.00%   0 CCFRF11_CT
119           8         2       4000  0.00%  0.00%  0.00%   0 CCAAL2_CT
120          12        56        214  0.00%  0.00%  0.00%   0 IP SNMP
121          20        29        689  0.00%  0.00%  0.00%   0 PDU DISPATCHER
122          80        30       2666  0.00%  0.00%  0.00%   0 SNMP ENGINE
123           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
124           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
125          36        29       1241  0.00%  0.00%  0.00%   0 RADIUS
126        3776  14126959          0  0.00%  0.00%  0.00%   0 NTP
127           0         1          0  0.00%  0.00%  0.00%   0 C1700_RING_LIMIT
128         360    485521          0  0.00%  0.00%  0.00%   0 CEF Scanner
129           0    116673          0  0.00%  0.00%  0.00%   0 DHCPD Timer
130          56   3966867          0  0.00%  0.00%  0.00%   0 DHCPD Database
131           0         1          0  0.00%  0.00%  0.00%   0 faxmsp
132           0         1          0  0.00%  0.00%  0.00%   0 DocMSP
133           4      3891          1  0.00%  0.00%  0.00%   0 fax timers
134         160  28001219          0  0.00%  0.00%  0.00%   0 esmtp client soc
135           4         2       2000  0.00%  0.00%  0.00%   0 esmtp server soc
136           0         1          0  0.00%  0.00%  0.00%   0 Fax Onramp-VFC
------------------ show process cpu history ------------------
NICARAGUA   02:52:29 PM Tuesday Feb 11 2014 UTC
    2222222221111111111222221111111111222222222211111111112222
100
90
80
70
60
50
40
30
20
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
     11   1
    2334333233322232222322222222222222322222222222222222322222
100
90
80
70
60
50
40
30
20
10  **   *
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    3333333233323333343333333233333333323333333333333233233333333333333333
100
90
80
70
60
50
40
30
20
10 *
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show context ------------------
No valid exception information to display.
------------------ show diag ------------------
Slot 0:
        C1751-V FE VE DV Mainboard Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 3.0
        PCB Serial Number        : JAD064704H3
        Part Number              : 73-7241-03
        Board Revision           : A0
        Fab Version              : 04
        Product (FRU) Number     : CISCO1751
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 02 4D 41 03 00 C1 8B 4A 41 44 30 36 34
          0x10: 37 30 34 48 33 82 49 1C 49 03 42 41 30 02 04 FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Packet Voice DSP Module Slot 0:
        Hardware Revision        : 3.2
        Part Number              : 73-6726-01
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 03
        PCB Serial Number        : ICP064708K8
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 02
        Number of DSP's          : 1
        DSP memory size(in kwords): 256
        Type of DSP              : TMS320C549
        Product (FRU) Number     : PVDM-256K-4=
        0x00:   04 FF 40 02 AC 41 03 02 82 49 1A 46 01 42 41 30
        0x10:   80 00 00 00 00 02 03 C1 8B 49 43 50 30 36 34 37
        0x20:   30 38 4B 38 03 00 81 00 00 00 00 04 00 09 02 FF
        Packet Voice DSP Module Slot 1:
        Not populated
        WIC/VIC Slot 0:
        Dual FXS Voice Interface Card
        Hardware revision 1.1   Board revision B0
        Serial number     0029544181    Part number    800-02493-04
        FRU Part Number   VIC-2FXS=
        Test history      0x00          RMA number     00-00-00
        Connector type    WAN Module
        EEPROM format version 1
        0x20:   01 0E 01 01 01 C2 CE F5 50 09 BD 04 00 00 00 00
        0x30:   58 00 00 00 02 11 09 01 FF FF FF FF FF FF FF FF
------------------ show c1700 ------------------
C1700 Platform Information:
Interrupts:
Assigned Handlers...
  Vect  Handler   # of Ints   Name
    01  8049C4CC   D0A09C26   MPC860P TIMER INTERRUPT
    02  800BB824   000000CE   16552 Con/Aux Interrupt
    03  800B8F3C   00000000   Timebase Reference Interrupt
    04  800C7954   D8A73D28   WIC Network IO Int Handler
    05  800C79D8   016B762E   MPC860P CPM INTERRUPT
    13  8047B9F8   01532814   pquicc fec interrupt
IOS Priority Masks...
  Level 00 = [ 7C040000 ]
  Level 01 = [ 7C040000 ]
  Level 02 = [ 7C040000 ]
  Level 03 = [ 7C040000 ]
  Level 04 = [ 70000000 ]
  Level 05 = [ 60000000 ]
  Level 06 = [ 40000000 ]
  Level 07 = [ 00000000 ]
SIU_IRQ_MASK  = FFFFFFFF  SIEN   = 7C04xxxx   Current Level = 00
Spurious IRQs = 00000000  SIPEND = 0000xxxx
Interrupt Throttling:
  Throttle Count = 00000000   Timer Count      = 00000000
  Netint usec    = 00000FA0   Netint Mask usec = 000003E8
  Active         =        0   Configured       =        0
  Longest IRQ    = 00000000
IDMA Status:
Requests = 22353977      Drops                = 00000088
Complete = 22353889      Post Coalesce Frames = 22353889
Giant    = 00000000
Available Blocks = 256/256
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show voice dsp ------------------
DSP  DSP             DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC    VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
C549 000 00 g711ulaw  4.1.41 Idle  Idle      0  0 0/0       NA     0 12221/18812
C549 000 01 g711ulaw  4.1.41 Idle  Idle      0  0 0/1       NA     0 13403/18708
Active Voice Call details
Current total analog signalling channels: 2
Current max allowed digital timeslot for voice: 0
Current number of DSP group: 1
Group 0:
Current allocated analog signalling channels: 2
Current free analog signalling channels: 0
Current allocated digital signalling channels: 0
Current free digital signalling channels: 0
Port(s) served: 0/0  0/1
Current Available MIPS: 100
SPMM  DSPRM  State   Image     D-sig  D-sig     A-sig  A-sig  Mips Voice/Xcode
  Dsp   Dsp                  allocate   free  allocate   free  Free     Chan
  0/0     0      UP   FIXHC         0      0         2      0   100        0
------------------ show controller voice ------------------
EPIC0 Switch registers:STDA 0x0 STDB 0x0 SARA 0x0 SARB 0x0 SAXA 0x0 SAXB 0x0 STCR 0x0 MFAIR 0x0
STAR 0x45 OMDR 0xE2 VNSR 0x8 PMOD 0x4C PBNR 0xFF POFD 0xF0 POFU 0x18
PCSR 0x1 PICM 0x0 CMD1 0xA0 CMD2 0x70 CBNR 0xFF CTAR 0x2 CBSR 0x20 CSCR 0x0
Current TDM configuration ---
Port Conf Stat    Type    Payload      Timing        EPIC   TSA    PLL  Depend
0/0  Yes  N/A    Ana VIC   voice  import onboard      0    Undef    0
0/1  No
0/2  No
0/3  No
0/4  No
0/5  No
0/6  No
0/7  No
0/8  No
0/9  No
0/10  No
0/11  No
0/12  No
0/13  No
0/14  No
0/15  No
PLL   Status byCLI   Reference
0    Set     No    onboard clock
EPIC  Status    VIC  Port0  Port1  Port2  Port3   PLL
0    Fixed    Analog   0/0     Undef      Undef      Undef     0
TSA   Port    PLL
0    Undef  Undef
1    Undef  Undef
System registers ---
    SSR 0: 0x13, SSR 1: 0x80
   WIC/VIC INTR MASK REG: 0x00
    TDM/SPMM1 INTR MASK REG: 0x3F
    TDM/SPMM2 INTR MASK REG: 0x1F
    SCR 0: 0x7E, SCR 1: 0x45, SCR 2: 0xD0
    SCR 3: 0x01, SCR 4: 0x48, SCR 5: 0xFC
    SCR 6: 0x00, SCR 7: 0x00, SCR 8: 0x90
    SCR 9: 0x40, SCR10: 0x70, SCR11: 0x70
    SCR12: 0x01, SCR13: 0x04, SCR14: 0x62
    SCR15: 0x00, SCE16: 0x31, SCR17: 0xBD
    SCR18: 0x71, SCE19: 0xF1, SCR20: 0x03
    SCR21: 0x01, SCE22: 0x00, SCR23: 0xF1
    SCR24: 0x00
DSP 0 Host Port Interface:
HPI Control Register 0x202
InterfaceStatus 0x2A MaxMessageSize 0x84
RxRingBufferSize 0x6 TxRingBufferSize 0x9
pInsertRx 0x5 pRemoveRx 0x5 pInsertTx 0x4 pRemoveTx 0x4
Rx Message 0:
packet_length 8 channel_id 0 packet_id 1 process id 0xEF01
Rx Message 1:
Rx Message 2:
Rx Message 3:
Rx Message 4:
Rx Message 5:
Tx Message 0:
packet_length 8 channel_id 0 packet_id 131 process id 0xEF01
Tx Message 1:
Tx Message 2:
Tx Message 3:
Tx Message 4:
Tx Message 5:
Tx Message 6:
Tx Message 7:
Tx Message 8:
Bootloader 1.8, Appn 4.1.41
Application firmware 4.1.41, Built by yubo on Thu Jul 22 17:03:58 2004
tx outstanding 0, max tx outstanding 40
ptr 0x0, length 0x0, max length 0x351
received 0 packets, 0 bytes, 0 giant packets
0 drops, 0 no buffers, 0 input errors 0 input overruns
3511485 bytes output, 27402 frames output, 0 output errors, 0 output underrun
0 unaligned frames
0 resets
*****VIC Interface Foreign Exchange Station 0/0, DSP instance (0x82373288)
Signalling channel num 128 Signalling proxy 0x0 Signalling dsp 0x82373288
received 18812 packets, 0 bytes, 0 giant packets
1288545 bytes output, 12221 frames output, 0 output errors, 0 output underrun
0 unaligned frames
*****VIC Interface Foreign Exchange Station 0/1, DSP instance (0x82373524)
Signalling channel num 129 Signalling proxy 0x0 Signalling dsp 0x82373524
received 18708 packets, 0 bytes, 0 giant packets
1754240 bytes output, 13403 frames output, 0 output errors, 0 output underrun
0 unaligned frames
------------------ show voice port ------------------
Foreign Exchange Station 0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXS
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 200 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 3 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to 1000 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
Foreign Exchange Station 0/1 Slot is 0, Sub-unit is 0, Port is 1
------------------ show dial-peer voice ------------------
VoiceEncapPeer1801
        peer type = voice, information type = voice,
        description = `',
        tag = 1801, destination-pattern = `1801',
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 1801, Admin state is up, Operation state is up,
        Outbound state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
        type = pots, prefix = `',
        forward-digits default
        session-target = `', voice-port = `0/0',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with GK = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 21564, Charged Units = 0,
        Successful Calls = 73, Failed Calls = 1, Incomplete Calls = 0
        Accepted Calls = 12, Refused Calls = 0,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 1400050377.
VoiceEncapPeer1802
        description = `',
        tag = 1802, destination-pattern = `1802',
        group = 1802, Admin state is up, Operation state is up,
        dnis-map =
        permission :both
        session-target = `', voice-port = `0/1',
        Connect Time = 20981, Charged Units = 0,
        Successful Calls = 72, Failed Calls = 3, Incomplete Calls = 0
        Accepted Calls = 6, Refused Calls = 0,
        Last Setup Time = 1392267440.
VoiceOverIpPeer1
        description = `Rom,
        tag = 1, destination-pattern = `5....',
        group = 1, Admin state is up, Operation state is up,
        modem transport = system,
        dnis-map =
        permission :both
        type = voip, session-target = `ipv4:*.*.1.13',
        technology prefix:
        settle-call = disabled
        ip media DSCP = ef, ip signaling DSCP = af31, UDP checksum = disabled,
        session-protocol = sipv2, session-transport = system, req-qos = best-effort,
        acc-qos = best-effort,
        RTP dynamic payload type values: NTE = 101
        Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
               CAS=123, ClearChan=125, PCM switch over u-law=0,A-law=8
        RTP comfort noise payload type = 19
        fax rate = voice,   payload size =  20 bytes
        fax protocol = system
        fax-relay ecm enable
        fax NSF = 0xAD0051 (default)
        codec = g729r8,   payload size =  20 bytes,
        Media Setting = flow-through (global)
        Expect factor = 10, Icpif = 20,
        Playout Mode is set to adaptive,
        Initial 60 ms, Max 250 ms
        Fax nominal 300 ms
        Max Redirects = 1, signaling-type = cas,
        VAD = enabled, Poor QOV Trap = disabled,
        Source Interface = NONE
        voice class sip url = system,
        voice class sip rel1xx = system,
        voice class perm tag = `'
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "",
        Last Disconnect Text is "",
        Last Setup Time = 0.
VoiceOverIpPeer155
        description = `Pa',
        tag = 155, destination-pattern = `155.',
        group = 155, Admin state is up, Operation state is up,
        dnis-map =
        permission :both
        type = voip, session-target = `ipv4:*.*.155.9',
        technology prefix:
        Fax nominal 300 ms
        Connect Time = 9991, Charged Units = 0,
        Accepted Calls = 40, Refused Calls = 0,
        Last Setup Time = 1341464278.
VoiceOverIpPeer248
        description = `le',
        tag = *48, destination-pattern = `*48....',
        group = *48, Admin state is up, Operation state is up,
        dnis-map =
        permission :both
        type = voip, session-target = `ipv4:*.*.*48.9',
        technology prefix:
        session-protocol = cisco, session-transport = system, req-qos = best-effort,
        Fax nominal 300 ms
------------------ show gateway ------------------
H.323 ITU-T Version: 4.0   H323 Stack Version: 0.1
H.323 service is up
This gateway  is not registered to any gatekeeper
Alias list (CLI configured)
E164-ID 1801
E164-ID 1802
Alias list (last RCF) is empty
------------------ show call active voice ------------------
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 0
MGCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 0
------------------ show call history voice last 50 ------------------
GENERIC:
SetupTime=1115509202 ms
Index=307
PeerAddress=666
PeerSubAddress=
PeerId=0
PeerIfIndex=7
LogicalIfIndex=0
DisconnectCause=10
DisconnectText=normal call clearing (16)
ConnectTime=1115511752 ms
DisconnectTime=1115515632 ms
CallDuration=00:00:03 sec
CallOrigin=2
ReleaseSource=2
ChargedUnits=0
InfoType=speech
TransmitPackets=305
TransmitBytes=48641
ReceivePackets=186
ReceiveBytes=29123
VOIP:
ConnectionId[0x2C0688D0 0x926211E3 0x810A851E 0x7A90055E]
IncomingConnectionId[0x2C0688D0 0x926211E3 0x810A851E 0x7A90055E]
RemoteIPAddress=*.*.1.77
RemoteUDPPort=19558
RemoteSignallingIPAddress=*.*.1.77
RemoteSignallingPort=5060
RemoteMediaIPAddress=*.*.1.77
RemoteMediaPort=19558
RoundTripDelay=183 ms
SelectedQoS=best-effort
tx_DtmfRelay=rtp-nte
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=sipv2
ProtocolCallId=30169558-926211E3-810D851E-7A90055E@*.*.1.77
SessionTarget=*.*.1.77
OnTimeRvPlayout=3220
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=65 ms
LoWaterPlayoutDelay=55 ms
ReceiveDelay=55 ms
LostPackets=0
EarlyPackets=1
LatePackets=0
VAD = enabled
CoderTypeRate=g711ulaw
CodecBytes=160
cvVoIPCallHistoryIcpif=0
MediaSetting=flow-around
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=666
OriginalCallingOctet=0x0
OriginalCalledNumber=1801
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=666
TranslatedCallingOctet=0x0
TranslatedCalledNumber=1801
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwReceivedCalledNumber=1801
GwReceivedCalledOctet3=0x80
GwReceivedCallingNumber=666
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x80
Username=666
GENERIC:
SetupTime=1115509222 ms
Index=308
PeerAddress=1801
PeerSubAddress=
PeerId=1801
PeerIfIndex=5
LogicalIfIndex=3
DisconnectCause=10
ConnectTime=1115511742 ms
DisconnectTime=1115516582 ms
CallDuration=00:00:04 sec
CallOrigin=1
ReleaseSource=2
ChargedUnits=0
InfoType=speech
TransmitPackets=186
TransmitBytes=29123
ReceivePackets=305
ReceiveBytes=48641
TELE:
ConnectionId=[0x2C0688D0 0x926211E3 0x810A851E 0x7A90055E]
IncomingConnectionId=[0x2C0688D0 0x926211E3 0x810A851E 0x7A90055E]
TxDuration=5400 ms
VoiceTxDuration=5090 ms
FaxTxDuration=0 ms
NoiseLevel=-83
ACOMLevel=23
SessionTarget=
ImgPages=0
CallerName=
GwOutpulsedCallingNumber=666
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x80
GENERIC:
SetupTime=1115601862 ms
Index=309
PeerAddress=666
PeerSubAddress=
PeerId=0
PeerIfIndex=7
LogicalIfIndex=0
DisconnectCause=10
ConnectTime=1115604412 ms
DisconnectTime=1115609752 ms
CallDuration=00:00:05 sec
CallOrigin=2
ReleaseSource=2
ChargedUnits=0
InfoType=speech
TransmitPackets=378
TransmitBytes=7531
ReceivePackets=321
ReceiveBytes=6285
VOIP:
ConnectionId[0x657396C4 0x926211E3 0x810E851E 0x7A90055E]
IncomingConnectionId[0x657396C4 0x926211E3 0x810E851E 0x7A90055E]
RemoteUDPPort=17358
RemoteMediaPort=17358
RoundTripDelay=230 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=67517EFE-926211E3-8111851E-7A90055E@*.*.1.77
OnTimeRvPlayout=5090
HiWaterPlayoutDelay=70 ms
LoWaterPlayoutDelay=60 ms
ReceiveDelay=60 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = enabled
CoderTypeRate=g729r8
CodecBytes=20
CallerName=
Username=666
GENERIC:
SetupTime=1115601882 ms
Index=310
PeerAddress=1801
PeerSubAddress=
PeerId=1801
PeerIfIndex=5
LogicalIfIndex=3
DisconnectCause=10
ConnectTime=1115604402 ms
DisconnectTime=1115610712 ms
CallDuration=00:00:06 sec
CallOrigin=1
ReleaseSource=2
ChargedUnits=0
InfoType=speech
TransmitPackets=321
TransmitBytes=6285
ReceivePackets=378
ReceiveBytes=7531
TELE:
ConnectionId=[0x657396C4 0x926211E3 0x810E851E 0x7A90055E]
IncomingConnectionId=[0x657396C4 0x926211E3 0x810E851E 0x7A90055E]
TxDuration=6140 ms
VoiceTxDuration=5830 ms
FaxTxDuration=0 ms
NoiseLevel=-82
ACOMLevel=-3
SessionTarget=
ImgPages=0
CallerName=
------------------ show raw reclaimed ------------------
RAW LEAK REPORT:
ORPHAN    :  0       raw buffers reclaimed
TSP       :  0       raw buffers reclaimed
VTSP      :  0       raw buffers reclaimed
H323      :  0       raw buffers reclaimed
SIP       :  0       raw buffers reclaimed
CCAPI     :  0       raw buffers reclaimed
VOATM     :  0       raw buffers reclaimed
XGCP      :  0       raw buffers reclaimed
CAS       :  0       raw buffers reclaimed
IVR       :  0       raw buffers reclaimed
SSAPP     :  0       raw buffers reclaimed
Last Audit Session is at 14:51:01 UTC Tue Feb 11 2014
------------------ show buffers ------------------
Buffer elements:
     1103 in free list (1000 max allowed)
     3669862 hits, 0 misses, 1119 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 85 @ 3w4d):
     48 in free list (20 min, 150 max allowed)
     22639213 hits, 2963 misses, 191 trims, 191 created
     1111 failures (0 no memory)
Middle buffers, 600 bytes (total 31, permanent 25, peak 58 @ 7w0d):
     14 in free list (10 min, 150 max allowed)
     1362053 hits, 365 misses, 135 trims, 141 created
     256 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 56 @ 7w0d):
     50 in free list (5 min, 150 max allowed)
     233756 hits, 102 misses, 6 trims, 6 created
     98 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 7w0d):
     9 in free list (0 min, 100 max allowed)
     11 hits, 88 misses, 1 trims, 1 created
     88 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 7w0d):
     1 in free list (0 min, 10 max allowed)
     0 hits, 88 misses, 1439 trims, 1440 created
Huge buffers, 18024 bytes (total 1, permanent 0, peak 1 @ 7w0d):
     1 in free list (0 min, 4 max allowed)
Interface buffer pools:
VPM 0 buffers, 264 bytes (total 576, permanent 576):
     0 in free list (0 min, 576 max allowed)
     576 hits, 0 fallbacks
     576 max cache size, 576 in cache
     1439263 hits in cache, 0 misses in cache
Header pools:
Header buffers, 0 bytes (total 137, permanent 128, peak 137 @ 7w0d):
     9 in free list (10 min, 512 max allowed)
     125 hits, 3 misses, 0 trims, 9 created
     0 failures (0 no memory)
     128 max cache size, 128 in cache
     0 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
     128 in free list (128 min, 1024 max allowed)
     256 hits, 0 misses, 0 trims, 0 created
     256 max cache size, 256 in cache
Normal buffers, 1548 bytes (total 512, permanent 512):
     384 in free list (128 min, 1024 max allowed)
     311 hits, 0 misses, 0 trims, 0 created
Private particle pools:
FastEthernet0/0 buffers, 1536 bytes (total 96, permanent 96):
     0 in free list (0 min, 96 max allowed)
     96 hits, 0 fallbacks
     96 max cache size, 64 in cache
     22382924 hits in cache, 151 misses in cache
------------------ show inventory ------------------
NAME: "1751-V chassis", DESCR: "1751-V chassis, Hw Serial#: 42*****, Hw Revision: 0x300"
PID: 1751-V            , VID: 0x300, SN: JAD064***** (42*****)
NAME: "Chassis Slot", DESCR: "1700 Chassis Slot"
PID: 1700 Chassis Slot , VID:    , SN:
NAME: "C1751 Mainboard", DESCR: "C1751 Mainboard"
PID: C1751 Mainboard   , VID: 0x300, SN: JAD064******(423*****3)
NAME: "Daughter card slot:0", DESCR: "1700 DaughterCard Slot"
PID: 1700 DaughterCard Slot, VID:    , SN:
NAME: "WIC/VIC 0", DESCR: "Two port FXS voice interface daughtercard"
PID: Two port FXS voice interface daughtercard, VID: 1.1, SN: 29*****
NAME: "voice-port 0/0", DESCR: "Foreign Exchange Station 0/0"
PID: Foreign Exchange Station 0/0, VID:    , SN:
NAME: "voice-port 0/1", DESCR: "Foreign Exchange Station 0/1"
PID: Foreign Exchange Station 0/1, VID:    , SN:
NAME: "FastEthernet0/0", DESCR: "PQUICC_FEC"
PID: PQUICC_FEC        , VID:    , SN:
NAME: "Daughter card slot:1", DESCR: "1700 DaughterCard Slot"
NAME: "Daughter card slot:2", DESCR: "1700 DaughterCard Slot"
NAME: "DSP Module Slot", DESCR: "Packet Voice DSP Module Slot 0"
PID: Packet Voice DSP Module Slot 0, VID:    , SN:
NAME: "DSP Module Slot", DESCR: "Packet Voice DSP Module Slot 1"
PID: Packet Voice DSP Module Slot 1, VID:    , SN:
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x03666800  0x03FFFFFF    10065920  Iomem  R/W    iomem
0x60000000  0x61FFFFFF    33554432  Flash  R/O    flash
0x80000000  0x836667FF    57042944  Local  R/W    main
0x8000816C  0x81458B53    21301736  IText  R/O    main:text
0x81458B54  0x81F42D0F    11444668  IData  R/W    main:data
0x81DCDB40  0x81DF9DDF      180896  Local  R/W    data:ADSL firmware
0x81DF9DE4  0x81E778C3      514784  Local  R/W    data:firmware
0x81F42D10  0x821A106B     2483036  IBss   R/W    main:bss
0x821A106C  0x836667FF    21780372  Local  R/W    main:heap
sh tech UC500
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 12-Jul-11 22:01 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
N.Pbx uptime is 23 weeks, 6 days, 9 minutes
System returned to ROM by reload at 13:31:43 CST Wed Aug 28 2013
System restarted at 13:32:14 CST Wed Aug 28 2013
System image file is "flash:uc500-advipservicesk9-mz.151-2.T4"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco UC560-FXO-K9 (MPC8378) processor (revision 0x100) with 497664K/26624K bytes of memory.
Processor board ID FGL152912ST
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
80 User Licenses
4 Gigabit Ethernet interfaces
31 Serial interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#            PID                              SN
*0              UC560-FXO-K9          FGL152912ST
Current configuration : 50791 bytes
! Last configuration change at 12:33:06 CST Tue Feb 11 2014 by Local
! NVRAM config last updated at 13:37:06 CST Tue Feb 11 2014
version 15.1
parser config cache interface
no service pad
no service timestamps debug uptime
service internal
service compress-config
service sequence-numbers
hostname N.Pbx
boot-start-marker
boot-end-marker
card type e1 0 2
no logging rate-limit
logging console errors
enable secret 5
aaa new-model
aaa authentication login default local
aaa authentication login tango_authen_login line local
aaa authorization exec tango_author_exec if-authenticated
clock timezone CST -4 0
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
crypto pki trustpoint TP-self-signed-1964470190
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1964470190
revocation-check none
crypto pki certificate chain TP-self-signed-1964470190
certificate self-signed 01
  03551D
  23041830 168014D5 1D9B990A 40F23985 C3567DC7 F1FC1DFE 723BF730 1D060355
  1D0E0416 0414D51D 9B990A40 F23985C3 567DC7F1 FC1DFE72 3BF7300D 06092A86
  4886F70D 01010405 00038181 000C550F 696CE0E1 1DBDC4EC 5CBA9B3D C8B7050E
  0A56EE09 7C63355B 1590E4FE C240D65C 3AF9783B 1E405C26 B38674A4 3198D0FB
  DB50BE86 E3D49162 00EE72B8 017A4F48 E2384F83 71A02FCA 1EA89FB8 84DB61DF
  61FFD74C 36B6246B BA2E615D DFA5CBEE 0D2181B7 AB98767C E4B3D8F4 2728F26D
  EE327A09 D2DA54F3 1B492364 BC
            quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 172.16.180.1 172.16.180.39
ip dhcp excluded-address 172.16.180.201 172.16.180.255
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.10.241 192.168.10.255
ip dhcp pool phone
   network 172.16.180.0 255.255.255.0
   default-router 172.16.180.1
   option 150 ip 172.16.180.1
ip dhcp pool data
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip domain name *.*
ip name-server *.*.180.33
ip inspect WAAS flush-timeout 10
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type primary-net5
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
trunk group VoIP
max-retry 5
hunt-scheme sequential
trunk group FAOR
max-retry 5
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
  ipv4 *.*.0.0 255.255.0.0
  ipv4 172.16.0.0 255.255.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
  registrar server expires max 3600 min 3600
  localhost dns:*.*.*
  no update-callerid
  sip-profiles 1000
voice class codec 1
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class cause-code 1
no-circuit
voice register global
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 2
rule 1 /^7/ //
voice translation-rule 4
rule 15 /^....$/ /87699300/
voice translation-rule 5
rule 1 /87699300/ /3098/
voice translation-rule 180
rule 1 /^180/ //
voice translation-rule 248
rule 1 /^5/ //
voice translation-rule 410
rule 2 /^7\(.*\)/ /\1/
rule 3 /^9\(.*\)/ /\1/
rule 4 /^8\(.*\)/ /\1/
rule 15 /^....$/ /95559865/
voice translation-rule 411
rule 2 /^7\(.*\)/ /ABCD7\1/
rule 3 /^9\(.*\)/ /ABCD9\1/
rule 4 /^8\(.*\)/ /ABCD8\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
rule 2 /^8/ //
rule 4 /^7/ //
voice translation-rule 1114
rule 1 /^9\(........\)/ /490152\1/
voice translation-rule 2004
rule 2 /^9\(........\)/ /490152\1/
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile OUTGOING_VPN_PROFILE
translate called 2004
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile S180
translate called 180
voice translation-profile S5
translate called 248
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile Strip9
translate called 2
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice translation-profile teste1-OP_Called_5
translate calling 3265
translate called 5
voice-card 0
dspfarm
dsp services dspfarm
license udi pid UC560-FXO-K9 sn FGL1*
archive
log config
  logging enable
  logging size 600
  hidekeys
username support privilege 15 secret 5
username Local privilege 15 secret 5
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-31
process-max-time 50
ip tftp source-interface Vlan90
interface GigabitEthernet0/0
ip address dhcp client-id GigabitEthernet0/0
ip nat outside
ip virtual-reassembly in
load-interval 30
shutdown
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport mode trunk
switchport voice vlan 100
macro description cisco-switch
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address . plan unknown type unknown
isdn supp-service name calling
isdn sending-complete
trunk-group ALL_T1E1
no cdp enable
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan20
ip address *.*.180.9 255.255.255.0
ip nat inside
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip nat inside
interface Vlan100
ip address 172.16.180.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Vlan90
logging esm config
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 172.16.180.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 1 permit *.*.180.0 0.0.0.255
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 172.16.180.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit *.*.146.52
access-list 3 permit *.*.196.11
access-list 3 deny   any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-8.bin alias spa525g-7-4-8.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-8a.bin alias spa50x-30x-7-4-8a.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
station-id name G*
station-id number 4001
caller-id enable
voice-port 0/0/1
station-id name C*
station-id number 4002
caller-id enable
voice-port 0/0/2
station-id name VC Room 1
station-id number 4003
caller-id enable
voice-port 0/0/3
station-id name VC Room 2
station-id number 4004
caller-id enable
voice-port 0/2/0:15
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 3098
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
no battery-reversal
voice-port 0/1/3
trunk-group FR 64
connection plar opx 2302
caller-id enable
voice-port 0/3/0
caller-id enable
voice-port 0/3/1
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
no battery-reversal
description TO FXS Port 1751
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
shutdown
description Music On Hold Port
sccp local Vlan90
sccp ccm 172.16.180.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
associate profile 2 register mtp6400f1a911e0
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Fonocall
codec g711ulaw
codec g729abr8
codec g729ar8
maximum sessions 10
associate application SCCP
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum sessions 2
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name PSTN-fax
name f*r
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list call-fax
member PSTN-fax
dial-peer cor list call-f*r
member f**r
dial-peer cor list user-faor
member internal
member local
member local-plus
member national
member emergency
member toll-free
member f*r
dial-peer voice 1 pots
corlist incoming user-internal
translation-profile incoming CallBlocking
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 4002
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 4003
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 4004
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description catch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 3099
b2bua
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 pots
direct-inward-dial
port 0/2/0:15
dial-peer voice 118 pots
trunkgroup ALL_FXO
description **CCA***Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 2
destination-pattern 91T
forward-digits all
no sip-register
dial-peer voice 124 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA***National***
preference 2
destination-pattern 922......
forward-digits all
no sip-register
dial-peer voice 126 pots
trunkgroup ALL_FXO
corlist outgoing call-local-plus
description **CCA** Long Distance**
preference 2
destination-pattern 927......
forward-digits all
no sip-register
dial-peer voice 128 pots
trunkgroup ALL_FXO
description **CCA****National long Distance**
preference 2
destination-pattern 925......
forward-digits all
no sip-register
dial-peer voice 130 pots
trunkgroup ALL_FXO
description **CCA**National long distance**
preference 2
destination-pattern 923......
forward-digits all
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (*) **
session target sip-server
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (*) **
destination-pattern *..
session protocol sipv2
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^....$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1020 voip
corlist outgoing call-international
description **CCA***International Long Distance SIP**
translation-profile outgoing PSTN_Outgoing
preference 2
destination-pattern 801T
dtmf-relay rtp-nte
no vad
dial-peer voice 82 pots
trunkgroup VoIP
description **CCA**P**
preference 1
destination-pattern 5[1-9]T
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup VoIP
description **CCA**Long Distance EEUU**
preference 5
destination-pattern 81T
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_T1E1
preference 3
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
description **CCA***Long Distance EEUU**
preference 5
forward-digits all
no sip-register
dial-peer voice 1021 voip
description **CCA**a*Long Distance EEUU**
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 151 pots
port 0/3/1
dial-peer voice 153 pots
port 0/3/3
dial-peer voice 2012 voip
description ** cue prompt manager number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 3097
b2bua
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2013 voip
description ** cue aa pilot number **
destination-pattern 3098
b2bua
codec g711ulaw
no vad
dial-peer voice 61 pots
trunkgroup ALL_T1E1
corlist outgoing call-national-plus
description * M*es
preference 1
destination-pattern 9[8].......
forward-digits all
no sip-register
dial-peer voice 150 pots
port 0/3/0
dial-peer voice 152 pots
port 0/3/2
dial-peer voice 8 pots
corlist outgoing call-faor
description Internacional
translation-profile outgoing Strip9
destination-pattern 7[0][0].....T
port 0/1/3
forward-digits all
dial-peer voice 248 voip
description C*
translation-profile outgoing S5
destination-pattern 52482...
session target ipv4:*.*.248.9
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 39 voip
description R*
destination-pattern 55....
session target ipv4:*.*.1.13
dial-peer voice 180 voip
description trunk internal
translation-profile outgoing S180
destination-pattern 180.T
session target ipv4:172.16.180.1
dtmf-relay rtp-nte
dial-peer voice 62 pots
trunkgroup ALL_FXO
trunkgroup ALL_T1E1
preference 1
destination-pattern 9[5].......
forward-digits 8
no sip-register
no dial-peer outbound status-check pots
sip-ua
credentials username * password 7 realm *.*.104.50
credentials username * password 7 realm *.*.com
keepalive target dns:*.*.com
authentication username * password 7
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
sip-server dns:*.*e.com
host-registrar
g729-annexb override
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 2 mtp6400f1a911e0
conference hardware
video
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 172.16.180.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
system message *a
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale 1 U4 load CME-locale-es_MX-Spanish-8.1.2.1.tar
network-locale 1 U4
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-8
load 501G spa50x-30x-7-4-8a
load 502G spa50x-30x-7-4-8a
load 504G spa50x-30x-7-4-8a
load 508G spa50x-30x-7-4-8a
load 509G spa50x-30x-7-4-8a
load 525G2 spa525g-7-4-8
load 301 spa50x-30x-7-4-8a
load 303 spa50x-30x-7-4-8a
time-zone 10
keepalive 30 auxiliary 4
voicemail 3099
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
web admin system name cisco secret 5 *
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6.... blind
secondary-dialtone 9
night-service day Sun 00:00 23:59
night-service day Mon 17:30 08:00
night-service day Tue 17:30 08:00
night-service day Wed 17:30 08:00
night-service day Thu 17:30 08:00
night-service day Fri 14:00 23:59
night-service day Sat 00:00 23:59
directory entry 1 2601 name A*
directory entry 2 2602 name Al*
directory entry 3 2316 name Me*
directory entry 4 2324 name Ma*
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn ConfList RmLstC Acct Park Select Join
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  549  dual-line
number 2302 no-reg both
label*
description *
name *
ephone-dn  550  octo-line
number 7071 no-reg primary
conference meetme
ephone-dn  551  octo-line
number C001 no-reg primary
conference ad-hoc
ephone-dn  552  dual-line
number 2338 no-reg both
label 2338
description *
name*
call-forward busy 3099
call-forward noan 3099 timeout 20
ephone-dn  553  dual-line
number 4001 no-reg both
label 4001
description *
name Seguridad S*
ephone-dn  554  dual-line
number 2606 no-reg both
label 2606
description Ir*
name Ir*
corlist incoming user-national-plus
ephone-dn  555
number 95*
description SIP Main Number registration
preference 10
ephone-dn  556  dual-line
number 2336 no-reg both
label 2336
description A*
name A*
ephone-dn  557
number 3A13 no-reg primary
label 2*
trunk A3 monitor-port 0/1/3
ephone-dn  558
number 3A12 no-reg primary
label VoIP_Line
trunk A2 monitor-port 0/1/2
ephone-dn  559
number 3A11 no-reg primary
label 2*
call-forward all A1
trunk A1 monitor-port 0/1/1
ephone-dn  560
number 3A10 no-reg primary
label 2*
call-forward all A0
trunk A0 monitor-port 0/1/0
ephone-dn  561  dual-line
number 2335 no-reg both
label 2335
description J*
name J*
ephone-dn  562  dual-line
number 2334 no-reg both
label 2334
description W*
name W*
corlist incoming user-local-plus
ephone-dn  563  dual-line
number 2333 no-reg both
label 2333
description Sa*
name S*
ephone-dn  564  dual-line
number 2332 no-reg both
label 2332
description J*
name J*
ephone-dn  565  dual-line
number 2331 no-reg both
label 2331
description J*
name J*
ephone-dn  566  dual-line
number 2323 no-reg both
label 2323
description C*
name Cr*
ephone-dn  567  dual-line
number 2328 no-reg both
label 2328
description Li*
name L*
ephone-dn  568  dual-line
number 2325 no-reg both
label 2325
description M*
name M*
ephone-dn  569  dual-line
number 2329 no-reg both
label 2329
description Da*
name D*
corlist incoming user-international
ephone-dn  570  dual-line
number 2327 no-reg both
label 2327
description Jac*
name Ja*
ephone-dn  571  dual-line
number 2326 no-reg both
label 2326
description Li*
name Li*
ephone-dn  572  dual-line
number 2324 no-reg both
label 2324
description Ma*
name Ma*
ephone-dn  573  dual-line
number 2322 no-reg both
label 2322
description Ka*
name Ka*
ephone-dn  574  dual-line
number 2317 no-reg both
label 2317
description E*
name Enm*
ephone-dn  575  dual-line
number 2321 no-reg both
label 2321
description O*
name O*
ephone-dn  576  dual-line
number 2319 no-reg both
label 2319
description El*
name *
ephone-dn  577  dual-line
number 2320 no-reg both
label 2320
description L*
name L*
ephone-dn  578  dual-line
number 2318 no-reg both
label 2318
description E*
name E**
ephone-dn  579  dual-line
number 2311 no-reg both
label 2311
description Fr*
name Fr*
ephone-dn  580  dual-line
number 2312 no-reg both
label 2312
description Pa*
name Pa*
ephone-dn  581  dual-line
number 2314 no-reg both
label 2314
description VC Room 1
name VCROOM 1
ephone-dn  582  dual-line
number 2605 no-reg both
label 2605
description Ma*
ephone-dn  583  dual-line
number 2504 no-reg both
label 2504
description Ho*
name Ho*
ephone-dn  584  dual-line
number 2601 no-reg both
label 2601
description And*
name A*
ephone-dn  585  dual-line
number 2505 no-reg both
label 2505
description Ma*
name Ma*
ephone-dn  586  dual-line
number 2503 no-reg both
label 2503
description VCROOM 2
name VCROOM2
ephone-dn  587  dual-line
number 2502 no-reg both
label 2502
description T*
name T*
ephone-dn  588  dual-line
number 2501 no-reg both
label 2501
description S*
name S*
ephone-dn  589  dual-line
number 2315 no-reg both
label 2315
description C*
name C*
ephone-dn  590  dual-line
number 2603 no-reg both
label 2603
description VCROOM 3
name VCROOM 3
ephone-dn  591  dual-line
number 2310 no-reg both
label 2310
name L*
ephone-dn  592  dual-line
number 2304 no-reg both
label 2304
description A*
name A*
ephone-dn  593  dual-line
number 2101 no-reg both
label 2101
description *
name *
call-forward night-service 4001
night-service bell
ephone-dn  594  dual-line
number 2301 no-reg both
label 2301
description F*
name F*
corlist incoming user-faor
ephone-dn  595  dual-line
number 2303 no-reg both
label 2303
description F*
name F*
ephone-dn  596  dual-line
number 2602 no-reg both
label 2602
description Al*
name Al*
ephone-dn  597  dual-line
number 2316 no-reg both
label 2316
description M*
name M*
ephone-dn  598
number 6.... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 3099
ephone-dn  599
number A801.... no-reg primary
mwi off
ephone-dn  600
number A800.... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address E8*
ephone-template 16
max-calls-per-button 2
type 508G
button  1:594
ephone  2
mac-address E8*
ephone-template 16
type 502G
button  1:570
ephone  3
mac-address E8B*
ephone-template 16
type 502G
button  1:571
ephone  4
mac-address E*
ephone-template 16
type 502G
button  1:586
ephone  5
mac-address E*
ephone-template 16
*st"
type 508G addon 1 500S
button  1:595 2:549
ephone  6
mac-address E8B*
ephone-template 16
button  1:593 3:559 4:558
ephone  7
mac-address E8*
ephone-template 16
type 502G
button  1:587
ephone  8
mac-address E8B*
ephone-template 16
username "*6
type 502G
button  1:585
ephone  9
mac-address E8*
ephone-template 16
username "VC*
type 502G
button  1:581
ephone  10
mac-address E*
ephone-template 16
username *
type 502G
button  1:565
ephone  11
mac-address E*
ephone-template 16
usernam*
type 502G
button  1:580
ephone  12
mac-address E8B*
ephone-template 16
use*
type 502G
button  1:577
ephone  13
mac-address E*
ephone-template 16
user*
type 502G
button  1:574
ephone  14
mac-address E8*
ephone-template 16
use*
type 502G
button  1:572
ephone  15
mac-address E8*
ephone-template 16
userna*
type 502G
button  1:576
ephone  16
mac-address E8*
ephone-template 16
user*
type 502G
button  1:575
ephone  17
mac-address E8*
ephone-template 16
username "*
type 502G
button  1:579
ephone  18
mac-address E8*
ephone-template 16
usern*
type 502G
button  1:591
ephone  19
mac-address E8*
ephone-template 16
username "*
type 502G
button  1:573
ephone  20
mac-address E8*
ephone-template 16
userna*
type 502G
button  1:564
ephone  21
mac-address E*
ephone-template 16
userna*
type 502G
button  1:588
ephone  574
alias exec cca_voice_mode PBX
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Tue Feb 11 14:38:12 CET 2014^C
line con 0
modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output telnet rlogin ssh
stopbits 1
speed 115200
line vty 0 4
access-class 23 in
privilege level 15
login authentication tango_authen_login
transport input all
line vty 5 100
access-class 23 in
privilege level 15
transport input all
ntp master
ntp server *.**.*.242 prefer
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
8100/9000   EEM ED RF
11132/12000  MRIB IPv4 Init Process
11136/12000  MRIB IPv6 Init Process
4984/6000   RAC I/F Conf.
4896/6000   Inspect Init Msg
5124/6000   SPAN Subsystem
58904/60000  script background loader
3284/12000  Init
58624/60000  EEM Auto Registration Proc
4816/6000   DIB error message
5132/6000   SASL MAIN
2108/3000   allegro libretto init
5128/6000   LICENSE AGENT DEFAULT
9824/12000  HTTP SSL PKI CERTIFICATE CREATE PROC
4924/6000   RADIUS INITCONFIG
5172/6000   FLEX DSPRM boot download main
2132/3000   Rom Random Update Process
5128/6000   IP SLAs Deferred Schedule Processor
33988/36000  TCP Command
3212/6000   Background Loader
3952/12000  Virtual Exec
9232/12000  TFTP Server
13840/24000  HTTP CP
4856/12000  show_voice_call_sum_task
10204/12000  show_voice_call_status_task
4964/12000  SSH Process
10664/12000  EzVPN Client Process
9156/12000  TTY Daemon
Interrupt level stacks:
Level    Called Unused/Size  Name
  4   968803957   5880/9000  Host/PCI Bridge Interrupt
  5           0   9000/9000  Timebase Reference Interrupt
  6       17922   8760/9000  16552 Con/Aux Interrupt
  7  3607344212   8904/9000  M8300_TIMER_INTERRUPT
Spurious interrupts: 7659519
------------------ show interfaces ------------------
GigabitEthernet0/0 is administratively down, line protocol is down
  Hardware is PQII_PRO_TSEC, address is 6400.f1a9.11f1 (bia 6400.f1a9.11f1)
  Internet address will be negotiated using DHCP
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Auto Duplex, Auto Speed, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Integrated-Service-Engine0/0 is up, line protocol is up
  Hardware is Service Module Mgmt
  Description: Interface used to manage integrated application modulecue is initialized with default IMAP group
  Interface is unnumbered. Using address of Vlan90 (10.1.10.2)
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Output queue: 0/0 (size/max)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
GigabitEthernet0/1/0 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 6400.f1a9.11e2 (bia 6400.f1a9.11e2)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 100 usec,
  Full-duplex, 1000Mb/s
  Last input 00:00:00, output never, output hang never
  Input queue: 0/75/161698/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 184000 bits/sec, 32 packets/sec
  5 minute output rate 49000 bits/sec, 27 packets/sec
     521308604 packets input, 4055534211 bytes, 0 no buffer
     Received 15121985 broadcasts (0 multicasts)
     425276880 packets output, 3159519356 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
GigabitEthernet0/1/1 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 6400.f1a9.11e3 (bia 6400.f1a9.11e3)
  Last input 00:00:32, output never, output hang never
  5 minute input rate 36000 bits/sec, 22 packets/sec
  5 minute output rate 104000 bits/sec, 30 packets/sec
     228428694 packets input, 2864084764 bytes, 0 no buffer
     Received 4855864 broadcasts (0 multicasts)
     354690204 packets output, 4237558289 bytes, 0 underruns
GigabitEthernet0/1/2 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 6400.f1a9.11e4 (bia 6400.f1a9.11e4)
  Last input 00:00:01, output never, output hang never
  5 minute input rate 145000 bits/sec, 89 packets/sec
  5 minute output rate 206000 bits/sec, 100 packets/sec
     275678781 packets input, 1671787881 bytes, 0 no buffer
     Received 2944044 broadcasts (0 multicasts)
     456820899 packets output, 2202692818 bytes, 0 underruns
GigabitEthernet0/1/3 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 6400.f1a9.11f2 (bia 6400.f1a9.11e5)
  Description: Interface used to communicate with integrated service module
     5363901 packets input, 1092056023 bytes, 0 no buffer
     Received 20034 broadcasts (0 multicasts)
     13993221 packets output, 1909772843 bytes, 0 underruns
Serial0/2/0:0 is down, line protocol is down
  Hardware is DSX1
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive not set
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     0 carrier transitions
Serial0/2/0:1 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:2 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:3 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:4 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:5 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:6 is up, line protocol is up
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:7 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:8 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:9 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:10 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:11 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:12 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:13 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:14 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:15 is up, line protocol is up (spoofing)
  Hardware is DSX1
  Last input 00:00:07, output never, output hang never
     Conversations  0/1/256 (active/max active/max total)
     2126437 packets input, 9197743 bytes, 0 no buffer
     7 runts, 0 giants, 0 throttles
     10 input errors, 10 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort
     2126508 packets output, 9427392 bytes, 0 underruns
     53 carrier transitions
  Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
Serial0/2/0:16 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:17 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:18 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:19 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:20 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:21 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:22 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:23 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:24 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:25 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:26 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:27 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:28 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:29 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Serial0/2/0:30 is down, line protocol is down
  Hardware is DSX1
  Keepalive not set
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 6400.f1a9.11e2 (bia 6400.f1a9.11e2)
  Internet address is 192.168.10.1/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Last input 00:02:39, output never, output hang never
     47685 packets input, 2861100 bytes, 0 no buffer
     2 packets output, 120 bytes, 0 underruns
     0 output errors, 1 interface resets
     47685 unknown protocol drops
Vlan20 is up, line protocol is up
  Internet address is 168.202.180.9/24
  5 minute input rate 5000 bits/sec, 5 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     35065929 packets input, 4063841166 bytes, 0 no buffer
     Received 22461495 broadcasts (38184 IP multicasts)
     0 runts, 0 giants, 2 throttles
     4414466 packets output, 729796719 bytes, 0 underruns
     2085482 unknown protocol drops
Vlan90 is up, line protocol is up
  Internet address is 10.1.10.2/30
  Last input 00:00:09, output never, output hang never
     5363898 packets input, 1070600132 bytes, 0 no buffer
     Received 20034 broadcasts (0 IP multicasts)
     6060847 packets output, 1299733941 bytes, 0 underruns
Vlan100 is up, line protocol is up
  Internet address is 172.16.180.1/24
  5 minute input rate 123000 bits/sec, 70 packets/sec
  5 minute output rate 125000 bits/sec, 81 packets/sec
     208385335 packets input, 3155771342 bytes, 0 no buffer
     Received 447835 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 1 throttles
     244026238 packets output, 3158405002 bytes, 0 underruns
NVI0 is administratively down, line protocol is down
  Hardware is NVI
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
------------------ show interfaces history ------------------
------------------ show controllers ------------------
Interface GigabitEthernet0/0
= Hardware =
ADDR: 86B19C74, FASTSEND: 80065124
Route Cache Flag: 11
= Media  RJ45 =
= MPC8300 TSEC Registers =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000004
GADDR2 = 0x00001000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
IEVENT=0x00000000, IMASK=B3718180, EDIS=00000000, ECNTRL=00003022
MINFLR=0x00000003, PTV=00000000, DMACTRL=000000DA, TBIPA=0000001C
TSTAT=0x00000000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1E70FCA0
TBASE=0x1E70FCA0, OSTBD=0x00000000, OSTBDP=0x00000000, RCTRL=0x00000004
RSTAT=0x00000000, RBDLEN=0x00000000, CRBPTR=0x00000000, MRBLR=0x00000600
RBASE=0x1E70F860, MACCFG1=0x00000030, MACCFG2=0x00007225, IPGIFG=0x40605060
HAFDUP=0x0001F037, MAXFRM=0x00000600, MIIMCFG=0x00000012, MIIMCOM=0x00000000
MIIMADD=0x00000101, MIIMCON=0x00009B7F, MIIMSTAT=0x00000000, MIIMIND=0x00000000
IFSTAT=0x00000008, MACSTNADDR1=0xF111A9F1, MACSTNADDR2=0x00640000
ATTR=0x000048C0, ATTRELI=0x00000008
RMON MIB Registers
TR64=0, TR127=0, TR255=0, TR511=0
TR1K=0, TRMAX=0, TRMGV=0
RBYT=0, RPKT=0, RFCS=0, RMCA=0
RBCA=0, RXCF=0, RXPF=0, RXUO=0
RALN=0, RFLR=0, RCDE=0, RCSE=0
RUND=0, ROVR=0, RFRG=0, RJBR=0
RDRP=0
TBYT=0, TPKT=0, TMCA=0, TBCA=0
TXPF=0, TDFR=0, TEDF=0, TSCL=0
TMCL=0, TLCL=0, TNCL=0, TDRP=0
TJBR=0, TFCS=0, TXCF=0, TOVR=0
TUND=0, TFRG=0
CAR1=0x00000000, CAR2=0x00000000
CAM1=0xFE03FFFF, CAM2=0x000FFFFD
TBI MII Registers
TBI (CR:0x00)= 0x0140, TBI (SR:0x01)= 0x014D
TBI (AN:0x04)= 0x0000, TBI (CON:0x11)= 0x0020
Software MAC address filter(hash:length/addr/mask/hits):
  0xC0:  0  0100.0ccc.cccc  0000.0000.0000         0
  0xC0:  1  0180.c200.0002  0000.0000.0000         0
= Device stats/data =
throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_crc_err=0, rx_short_err=0
rx_non_align_err=0, rx_truncation_err=0
rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
PHY Registers
All pages
  Register 0x00:   1800  7949  0141  0C97  05E1  0000  0004  2001
  Register 0x08:   0000  0300  0000  0000  0000  0000  0000  3000
  Register 0x16:   8000
  PHY Control (0x00):
  AUTONEG_EN POWERDOWN
  PHY Status (0x01):
  LINK_DOWN
  Auto-Negotiation Advertisement (0x04):
  PAUSE 100FD 100HD 10FD 10HD
  Link Partner Ability (0x05):
  1000BASE-T Control (0x09):
  M/S_AUTO DTE 1000FD 1000HD
  1000BASE-T Status (0x0A):
  M/S_CFG_OK SLAVE
Page 0
  Register 0x10:   6060  8040  0000  0040  0000  0000  8000
  Register 0x1A:   0040
  Copper Specific Status 1 (0x11):
  1000 HD NOT-RESOLVED LINK_DOWN MDIX
Page 2
  Register 0x02:   0141
  Register 0x10:   0288  0440  0000  0000  0000  0000  0002  0000
  Register 0x18:   0000  0000  0000
= Ring Buffer Information =
tsec_instance=0x86B1B9E0
rx ring entries=128, tx ring entries=64
rxring=0x1E70F860, rxr shadow=0x86B1BD50, rx_head=0, rx_tail=0
txring=0x1E70FCA0, txr shadow=0x86B1BF84, tx_head=0, tx_tail=0, tx_count=0
Driver Level Counters: (Cumulative, Zeroed only at Reset)
Rx Frames=0, Bytes=0
Tx Frames=0, Bytes=0
== RX_RING_ENTRIES ==
0 status 9000,  len 0, buf_ptr 1E64BB88
1 status 9000,  len 0, buf_ptr 1E64B528
2 status 9000,  len 0, buf_ptr 1E64AEC8
3 status 9000,  len 0, buf_ptr 1E64A868
4 status 9000,  len 0, buf_ptr 1E64A208
5 status 9000,  len 0, buf_ptr 1E649BA8
6 status 9000,  len 0, buf_ptr 1E649548
7 status 9000,  len 0, buf_ptr 1E648EE8
8 status 9000,  len 0, buf_ptr 1E648888
9 status 9000,  len 0, buf_ptr 1E648228
10 status 9000,  len 0, buf_ptr 1E647BC8
11 status 9000,  len 0, buf_ptr 1E647568
12 status 9000,  len 0, buf_ptr 1E646F08
13 status 9000,  len 0, buf_ptr 1E6468A8
14 status 9000,  len 0, buf_ptr 1E646248
15 status 9000,  len 0, buf_ptr 1E645BE8
16 status 9000,  len 0, buf_ptr 1E645588
17 status 9000,  len 0, buf_ptr 1E644F28
18 status 9000,  len 0, buf_ptr 1E6448C8
19 status 9000,  len 0, buf_ptr 1E644268
20 status 9000,  len 0, buf_ptr 1E643C08
21 status 9000,  len 0, buf_ptr 1E6435A8
22 status 9000,  len 0, buf_ptr 1E642F48
23 status 9000,  len 0, buf_ptr 1E6428E8
24 status 9000,  len 0, buf_ptr 1E642288
25 status 9000,  len 0, buf_ptr 1E641C28
26 status 9000,  len 0, buf_ptr 1E6415C8
27 status 9000,  len 0, buf_ptr 1E640F68
28 status 9000,  len 0, buf_ptr 1E640908
29 status 9000,  len 0, buf_ptr 1E6402A8
30 status 9000,  len 0, buf_ptr 1E63FC48
31 status 9000,  len 0, buf_ptr 1E63F5E8
32 status 9000,  len 0, buf_ptr 1E65EEC8
33 status 9000,  len 0, buf_ptr 1E65E868
34 status 9000,  len 0, buf_ptr 1E65E208
35 status 9000,  len 0, buf_ptr 1E65DBA8
36 status 9000,  len 0, buf_ptr 1E65D548
37 status 9000,  len 0, buf_ptr 1E65CEE8
38 status 9000,  len 0, buf_ptr 1E65C888
39 status 9000,  len 0, buf_ptr 1E65C228
40 status 9000,  len 0, buf_ptr 1E65BBC8
41 status 9000,  len 0, buf_ptr 1E65B568
42 status 9000,  len 0, buf_ptr 1E65AF08
43 status 9000,  len 0, buf_ptr 1E65A8A8
44 status 9000,  len 0, buf_ptr 1E65A248
45 status 9000,  len 0, buf_ptr 1E659BE8
46 status 9000,  len 0, buf_ptr 1E659588
47 status 9000,  len 0, buf_ptr 1E658F28
48 status 9000,  len 0, buf_ptr 1E6588C8
49 status 9000,  len 0, buf_ptr 1E658268
50 status 9000,  len 0, buf_ptr 1E657C08
51 status 9000,  len 0, buf_ptr 1E6575A8
52 status 9000,  len 0, buf_ptr 1E656F48
53 status 9000,  len 0, buf_ptr 1E6568E8
54 status 9000,  len 0, buf_ptr 1E656288
55 status 9000,  len 0, buf_ptr 1E655C28
56 status 9000,  len 0, buf_ptr 1E6555C8
57 status 9000,  len 0, buf_ptr 1E654F68
58 status 9000,  len 0, buf_ptr 1E654908
59 status 9000,  len 0, buf_ptr 1E6542A8
60 status 9000,  len 0, buf_ptr 1E653C48
61 status 9000,  len 0, buf_ptr 1E6535E8
62 status 9000,  len 0, buf_ptr 1E652F88
63 status 9000,  len 0, buf_ptr 1E652928
64 status 9000,  len 0, buf_ptr 1E6522C8
65 status 9000,  len 0, buf_ptr 1E651C68
66 status 9000,  len 0, buf_ptr 1E651608
67 status 9000,  len 0, buf_ptr 1E650FA8
68 status 9000,  len 0, buf_ptr 1E650948
69 status 9000,  len 0, buf_ptr 1E6502E8
70 status 9000,  len 0, buf_ptr 1E64FC88
71 status 9000,  len 0, buf_ptr 1E64F628
72 status 9000,  len 0, buf_ptr 1E66EF08
73 status 9000,  len 0, buf_ptr 1E66E8A8
74 status 9000,  len 0, buf_ptr 1E66E248
75 status 9000,  len 0, buf_ptr 1E66DBE8
76 status 9000,  len 0, buf_ptr 1E66D588
77 status 9000,  len 0, buf_ptr 1E66CF28
78 status 9000,  len 0, buf_ptr 1E66C8C8
79 status 9000,  len 0, buf_ptr 1E66C268
80 status 9000,  len 0, buf_ptr 1E66BC08
81 status 9000,  len 0, buf_ptr 1E66B5A8
82 status 9000,  len 0, buf_ptr 1E66AF48
83 status 9000,  len 0, buf_ptr 1E66A8E8
84 status 9000,  len 0, buf_ptr 1E66A288
85 status 9000,  len 0, buf_ptr 1E669C28
86 status 9000,  len 0, buf_ptr 1E6695C8
87 status 9000,  len 0, buf_ptr 1E668F68
88 status 9000,  len 0, buf_ptr 1E668908
89 status 9000,  len 0, buf_ptr 1E6682A8
90 status 9000,  len 0, buf_ptr 1E667C48
91 status 9000,  len 0, buf_ptr 1E6675E8
92 status 9000,  len 0, buf_ptr 1E666F88
93 status 9000,  len 0, buf_ptr 1E666928
94 status 9000,  len 0, buf_ptr 1E6662C8
95 status 9000,  len 0, buf_ptr 1E665C68
96 status 9000,  len 0, buf_ptr 1E665608
97 status 9000,  len 0, buf_ptr 1E664FA8
98 status 9000,  len 0, buf_ptr 1E664948
99 status 9000,  len 0, buf_ptr 1E6642E8
100 status 9000,  len 0, buf_ptr 1E663C88
101 status 9000,  len 0, buf_ptr 1E663628
102 status 9000,  len 0, buf_ptr 1E662FC8
103 status 9000,  len 0, buf_ptr 1E662968
104 status 9000,  len 0, buf_ptr 1E662308
105 status 9000,  len 0, buf_ptr 1E661CA8
106 status 9000,  len 0, buf_ptr 1E661648
107 status 9000,  len 0, buf_ptr 1E660FE8
108 status 9000,  len 0, buf_ptr 1E660988
109 status 9000,  len 0, buf_ptr 1E660328
110 status 9000,  len 0, buf_ptr 1E65FCC8
111 status 9000,  len 0, buf_ptr 1E65F668
112 status 9000,  len 0, buf_ptr 1E67EF48
113 status 9000,  len 0, buf_ptr 1E67E8E8
114 status 9000,  len 0, buf_ptr 1E67E288
115 status 9000,  len 0, buf_ptr 1E67DC28
116 status 9000,  len 0, buf_ptr 1E67D5C8
117 status 9000,  len 0, buf_ptr 1E67CF68
118 status 9000,  len 0, buf_ptr 1E67C908
119 status 9000,  len 0, buf_ptr 1E67C2A8
120 status 9000,  len 0, buf_ptr 1E67BC48
121 status 9000,  len 0, buf_ptr 1E67B5E8
122 status 9000,  len 0, buf_ptr 1E67AF88
123 status 9000,  len 0, buf_ptr 1E67A928
124 status 9000,  len 0, buf_ptr 1E67A2C8
125 status 9000,  len 0, buf_ptr 1E679C68
126 status 9000,  len 0, buf_ptr 1E679608
127 status B000,  len 0, buf_ptr 1E678FA8
== TX_RING_ENTRIES ==
0 status 0,  len 0, buf_ptr 0
1 status 0,  len 0, buf_ptr 0
2 status 0,  len 0, buf_ptr 0
3 status 0,  len 0, buf_ptr 0
4 status 0,  len 0, buf_ptr 0
5 status 0,  len 0, buf_ptr 0
6 status 0,  len 0, buf_ptr 0
7 status 0,  len 0, buf_ptr 0
8 status 0,  len 0, buf_ptr 0
9 status 0,  len 0, buf_ptr 0
10 status 0,  len 0, buf_ptr 0
11 status 0,  len 0, buf_ptr 0
12 status 0,  len 0, buf_ptr 0
13 status 0,  len 0, buf_ptr 0
14 status 0,  len 0, buf_ptr 0
15 status 0,  len 0, buf_ptr 0
16 status 0,  len 0, buf_ptr 0
17 status 0,  len 0, buf_ptr 0
18 status 0,  len 0, buf_ptr 0
19 status 0,  len 0, buf_ptr 0
20 status 0,  len 0, buf_ptr 0
21 status 0,  len 0, buf_ptr 0
22 status 0,  len 0, buf_ptr 0
23 status 0,  len 0, buf_ptr 0
24 status 0,  len 0, buf_ptr 0
25 status 0,  len 0, buf_ptr 0
26 status 0,  len 0, buf_ptr 0
27 status 0,  len 0, buf_ptr 0
28 status 0,  len 0, buf_ptr 0
29 status 0,  len 0, buf_ptr 0
30 status 0,  len 0, buf_ptr 0
31 status 0,  len 0, buf_ptr 0
32 status 0,  len 0, buf_ptr 0
33 status 0,  len 0, buf_ptr 0
34 status 0,  len 0, buf_ptr 0
35 status 0,  len 0, buf_ptr 0
36 status 0,  len 0, buf_ptr 0
37 status 0,  len 0, buf_ptr 0
38 status 0,  len 0, buf_ptr 0
39 status 0,  len 0, buf_ptr 0
40 status 0,  len 0, buf_ptr 0
41 status 0,  len 0, buf_ptr 0
42 status 0,  len 0, buf_ptr 0
43 status 0,  len 0, buf_ptr 0
44 status 0,  len 0, buf_ptr 0
45 status 0,  len 0, buf_ptr 0
46 status 0,  len 0, buf_ptr 0
47 status 0,  len 0, buf_ptr 0
48 status 0,  len 0, buf_ptr 0
49 status 0,  len 0, buf_ptr 0
50 status 0,  len 0, buf_ptr 0
51 status 0,  len 0, buf_ptr 0
52 status 0,  len 0, buf_ptr 0
53 status 0,  len 0, buf_ptr 0
54 status 0,  len 0, buf_ptr 0
55 status 0,  len 0, buf_ptr 0
56 status 0,  len 0, buf_ptr 0
57 status 0,  len 0, buf_ptr 0
58 status 0,  len 0, buf_ptr 0
59 status 0,  len 0, buf_ptr 0
60 status 0,  len 0, buf_ptr 0
61 status 0,  len 0, buf_ptr 0
62 status 0,  len 0, buf_ptr 0
63 status 2000,  len 0, buf_ptr 0
Interface GigabitEthernet0/1/0
Marvell switch registers
Number of Packets received with errors:
Bad Marvell Trailer: 0           Packets received on stacked port: 0
Marvell PHY (0) Register:
Reg 29 = 0x0              Reg 30 = 0x0
Intr enable: 0x400              Intr status : 0x0
Control    : 0x1000              Status      : 0x7969
Identifier : 0x141  0xCB1
Auto Neg   : 0x1E1              Auto Neg Exp: 0xF
LP Ability : 0xC1E1              LP NxtPg    : 0x4F5C
PHY ctrl   : 0x3360              PHY status  : 0xBC08
Marvell MAC Port (0) Registers:
Status     : 0x1E80              Control     : 0x477
MAC Control : 0x3
Identifier : 0x1066              Vlan Map    : 0x7FE
VID and PRI: 0x1              Rate Control: 0x3000
Port Asc Vt: 0x1
TX counter : 0x0              RX counter  : 0x0
Global Registers:
Status   : 0x8874              Control  : 0x482
Port (CPU PORT) Registers:
Status     : 0xE86              Control     : 0x173
MAC Control : 0x43E
Identifier : 0x1066              Vlan Map    : 0x7DF
Port Asc Vt: 0x20
SerDes CRTL : 0x140             SerDes SPIC : 0xDB
Outputs    : 0xFAED3A4              Inputs      : 0x153DB4F7
Output err : 0x0              Input err   : 0x0
Output drop: 0x0              Input drops : 0x0
Output Coll: 0x0              Input Giants: 0x0
Number of VLANs on unit (0): 4
Vlan[db]\Port| 0  | 1  | 2  | 3  | CPU|
  <1[1]>   | EUT| EUT| EUT| NM | ET |
  <20[2]>   | ET | ET | ET | NM | ET |
  <90[3]>   | ET | ET | ET | EUT| ET |
  <100[4]>   | ET | ET | ET | NM | ET |
= Hardware =
ADDR: 86B535C4, FASTSEND: 80065124
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
MINFLR=0x86B54744, PTV=00000000, DMACTRL=000000C2, TBIPA=0000001D
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1E7BCD00
TBASE=0x1E7BCB60, OSTBD=0x00000000, OSTBDP=0x00000000, RCTRL=0x0000000C
RSTAT=0x00000080, RBDLEN=0x00000000, CRBPTR=0x00000000, MRBLR=0x00000600
RBASE=0x1E7BC720, MACCFG1=0x0000003F, MACCFG2=0x00007225, IPGIFG=0x40605060
HAFDUP=0x0001F037, MAXFRM=0x00000600, MIIMCFG=0x00000007, MIIMCOM=0x00000000
MIIMADD=0x00001D01, MIIMCON=0x00000140, MIIMSTAT=0x00000000, MIIMIND=0x00000000
IFSTAT=0x00000008, MACSTNADDR1=0xF211A9F1, MACSTNADDR2=0x00640000
RMON MIB Registers
TR64=2084676, TR127=2718503, TR255=1308611, TR511=2651360
TR1K=396492, TRMAX=89870, TRMGV=0
RBYT=2297269400, RPKT=1012688, RFCS=0, RMCA=4094394
RBCA=1957853, RXCF=0, RXPF=0, RXUO=0
RUND=0, ROVR=1564, RFRG=0, RJBR=0
RDRP=9
TBYT=1899594151, TPKT=4044084, TMCA=719965, TBCA=3426
TUND=0, TFRG=0
CAR1=0xE001B000, CAR2=0x00003800
TBI MII Registers
PHY Registers
All pages
  Register 0x00:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x08:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x16:   FFFF
  PHY Control (0x00):
  RESET LOOPBACK 100MBPS AUTONEG_EN POWERDOWN ISOLATE AUTONEG_RESTART FULLDUPLEX 1000MBPS
  PHY Status (0x01):
  AUTONEG_DONE REMOTE_FAULT LINK_UP
  ASYM_PAUSE PAUSE 100FD 100HD 10FD 10HD
  M/S_MANUAL_MASTER HUB 1000FD 1000HD
  M/S_CFG_FAULT MASTER LOCAL_RX_OK REMOTE_RX_OK 1000FD 1000HD
Page 0
  Register 0x10:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x1A:   FFFF
  reserved FD RESOLVED LINK_UP MDIX
Page 2
  Register 0x02:   FFFF
  Register 0x10:   FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x18:   FFFF  FFFF  FFFF
tsec_instance=0x86B54744
rxring=0x1E7BC720, rxr shadow=0x86B54AB4, rx_head=71, rx_tail=0
txring=0x1E7BCB60, txr shadow=0x86B54CE8, tx_head=52, tx_tail=52, tx_count=0
Rx Frames=256865223, Bytes=2297268500
Tx Frames=356365620, Bytes=474131671
0 status 9000,  len DE, buf_ptr 1E7EC118
1 status 9000,  len DE, buf_ptr 1E7D9A68
2 status 9000,  len DE, buf_ptr 1E7D9338
3 status 9000,  len 40, buf_ptr 1E7DE978
4 status 9000,  len 40, buf_ptr 1E7CC2C8
5 status 9000,  len DE, buf_ptr 1E7EC848
6 status 9000,  len 40, buf_ptr 1E7E2A28
7 status 9000,  len 40, buf_ptr 1E7C8218
8 status 9000,  len DE, buf_ptr 1E7F7BF8
9 status 9000,  len 40, buf_ptr 1E7E4E18
10 status 9000,  len 40, buf_ptr 1E7D11D8
11 status 9000,  len DE, buf_ptr 1E7D4428
12 status 9000,  len 40, buf_ptr 1E7ED6A8
13 status 9000,  len DE, buf_ptr 1E7C00B8
14 status 9000,  len 40, buf_ptr 1E7D7DA8
15 status 9000,  len 40, buf_ptr 1E7DF7D8
16 status 9000,  len 40, buf_ptr 1E7CD128
17 status 9000,  len 4A, buf_ptr 1E7CFC48
18 status 9000,  len DE, buf_ptr 1E7F01C8
19 status 9000,  len DE, buf_ptr 1E7E3158
20 status 9000,  len 4A, buf_ptr 1E7EE508
21 status 9000,  len DE, buf_ptr 1E7E22F8
22 status 9000,  len DE, buf_ptr 1E7F74C8
23 status 9000,  len DE, buf_ptr 1E7D1908
24 status 9000,  len DE, buf_ptr 1E7DC588
25 status 9000,  len DE, buf_ptr 1E7CAD38
26 status 9000,  len DE, buf_ptr 1E7C24A8
27 status 9000,  len DE, buf_ptr 1E7DAFF8
28 status 9000,  len 40, buf_ptr 1E7F8328
29 status 9000,  len DE, buf_ptr 1E7E63A8
30 status 9000,  len 40, buf_ptr 1E7D2768
31 status 9000,  len DE, buf_ptr 1E7E8068
32 status 9000,  len 40, buf_ptr 1E7C97A8
33 status 9000,  len DE, buf_ptr 1E7ECF78
34 status 9000,  len 40, buf_ptr 1E7CEDE8
35 status 9000,  len 40, buf_ptr 1E7E7208
36 status 9000,  len 40, buf_ptr 1E7C1D78
37 status 9000,  len 86, buf_ptr 1E7C6C88
38 status 9000,  len 40, buf_ptr 1E7CF518
39 status 9000,  len 40, buf_ptr 1E7F2CE8
40 status 9000,  len DE, buf_ptr 1E7E5548
41 status 9000,  len DE, buf_ptr 1E7C9ED8
42 status 9000,  len 40, buf_ptr 1E7E8EC8
43 status 9000,  len 40, buf_ptr 1E7DBE58
44 status 9000,  len 40, buf_ptr 1E7EDDD8
45 status 9000,  len DE, buf_ptr 1E7D35C8
46 status 9000,  len 40, buf_ptr 1E7E3FB8
47 status 9000,  len DE, buf_ptr 1E7BD598
48 status 9000,  len 40, buf_ptr 1E7C0F18
49 status 9000,  len DE, buf_ptr 1E7DD3E8
50 status 9000,  len DE, buf_ptr 1E7D0378
51 status 9000,  len 86, buf_ptr 1E7D84D8
52 status 9000,  len DE, buf_ptr 1E7E46E8
53 status 9000,  len DE, buf_ptr 1E7F25B8
54 status 9000,  len DE, buf_ptr 1E7F3B48
55 status 9000,  len DE, buf_ptr 1E7C3A38
56 status 9000,  len DE, buf_ptr 1E7F50D8
57 status 9000,  len DE, buf_ptr 1E7CE6B8
58 status 9000,  len DE, buf_ptr 1E7DF0A8
59 status 9000,  len DE, buf_ptr 1E7D7678
60 status 9000,  len 40, buf_ptr 1E7C4FC8
61 status 9000,  len DE, buf_ptr 1E7BEB28
62 status 9000,  len DE, buf_ptr 1E7E95F8
63 status 9000,  len 40, buf_ptr 1E7C5E28
64 status 9000,  len DE, buf_ptr 1E7E3888
65 status 9000,  len 40, buf_ptr 1E7E6AD8
66 status 9000,  len 40, buf_ptr 1E7CBB98
67 status 9000,  len 40, buf_ptr 1E7F1028
68 status 9000,  len DE, buf_ptr 1E7C8948
69 status 9000,  len 40, buf_ptr 1E7E5C78
70 status 9000,  len 40, buf_ptr 1E7E0D68
71 status 9000,  len 40, buf_ptr 1E7CC9F8
72 status 9000,  len 40, buf_ptr 1E7D60E8
73 status 9000,  len DE, buf_ptr 1E7F08F8
74 status 9000,  len DE, buf_ptr 1E7EEC38
75 status 9000,  len DE, buf_ptr 1E7F1E88
76 status 9000,  len DE, buf_ptr 1E7F3418
77 status 9000,  len DE, buf_ptr 1E7F5808
78 status 9000,  len DE, buf_ptr 1E7D59B8
79 status 9000,  len DE, buf_ptr 1E7E9D28
80 status 9000,  len DE, buf_ptr 1E7DB728
81 status 9000,  len DE, buf_ptr 1E7C4898
82 status 9000,  len DE, buf_ptr 1E7C9078
83 status 9000,  len DE, buf_ptr 1E7C2BD8
84 status 9000,  len DE, buf_ptr 1E7C1648
85 status 9000,  len 40, buf_ptr 1E7E8798
86 status 9000,  len DE, buf_ptr 1E7F6668
87 status 9000,  len DE, buf_ptr 1E7C3308
88 status 9000,  len 40, buf_ptr 1E7EFA98
89 status 9000,  len 40, buf_ptr 1E7D4B58
90 status 9000,  len 40, buf_ptr 1E7F6D98
91 status 9000,  len 40, buf_ptr 1E7CB468
92 status 9000,  len 40, buf_ptr 1E7F1758
93 status 9000,  len DE, buf_ptr 1E7C56F8
94 status 9000,  len DE, buf_ptr 1E7D8C08
95 status 9000,  len DE, buf_ptr 1E7C07E8
96 status 9000,  len DE, buf_ptr 1E7EAB88
97 status 9000,  len DE, buf_ptr 1E7E1498
98 status 9000,  len DE, buf_ptr 1E7C4168
99 status 9000,  len DE, buf_ptr 1E7DFF08
100 status 9000,  len DE, buf_ptr 1E7C7AE8
101 status 9000,  len DE, buf_ptr 1E7CDF88
102 status 9000,  len DE, buf_ptr 1E7EF368
103 status 9000,  len DE, buf_ptr 1E7CD858
104 status 9000,  len DE, buf_ptr 1E7D2E98
105 status 9000,  len 40, buf_ptr 1E7D6818
106 status 9000,  len 40, buf_ptr 1E7EB9E8
107 status 9000,  len 40, buf_ptr 1E7CA608
108 status 9000,  len DE, buf_ptr 1E7DE248
109 status 9000,  len 40, buf_ptr 1E7DA8C8
110 status 9000,  len DE, buf_ptr 1E7BF258
111 status 9000,  len 40, buf_ptr 1E7D2038
112 status 9000,  len 40, buf_ptr 1E7C6558
113 status 9000,  len 40, buf_ptr 1E7E1BC8
114 status 9000,  len 40, buf_ptr 1E7F5F38
115 status 9000,  len 40, buf_ptr 1E7D3CF8
116 status 9000,  len DE, buf_ptr 1E7DA198
117 status 9000,  len 40, buf_ptr 1E7D0AA8
118 status 9000,  len DE, buf_ptr 1E7D6F48
119 status 9000,  len DE, buf_ptr 1E7BDCC8
120 status 9000,  len DE, buf_ptr 1E7BF988
121 status 9000,  len DE, buf_ptr 1E7F4278
122 status 9000,  len DE, buf_ptr 1E7C73B8
123 status 9000,  len DE, buf_ptr 1E7EA458
124 status 9000,  len DE, buf_ptr 1E7E7938
125 status 9000,  len DE, buf_ptr 1E7BE3F8
126 status 9000,  len DE, buf_ptr 1E7F49A8
127 status B000,  len DE, buf_ptr 1E7D5288
0 status 0,  len DA, buf_ptr 1EB11312
1 status 0,  len 40, buf_ptr 1E606E46
2 status 0,  len DA, buf_ptr 1EB30372
3 status 0,  len DA, buf_ptr 1EB39912
4 status 0,  len DA, buf_ptr 1EB10BF2
5 status 0,  len DA, buf_ptr 1EB3F5B2
6 status 0,  len 40, buf_ptr 1E6070C6
7 status 0,  len DA, buf_ptr 1EB2EBB2
8 status 0,  len DA, buf_ptr 1EB40192
9 status 0,  len DA, buf_ptr 1EB2E492
10 status 0,  len DA, buf_ptr 1EB19A72
11 status 0,  len DA, buf_ptr 1EB08952
12 status 0,  len DA, buf_ptr 1EB4FAF2
13 status 0,  len 252, buf_ptr 1EC14466
14 status 0,  len 252, buf_ptr 1E60A6C6
15 status 0,  len 252, buf_ptr 1EC15E66
16 status 0,  len 252, buf_ptr 1E608986
17 status 0,  len 252, buf_ptr 1E60A046
18 status 0,  len 252, buf_ptr 1E609D06
19 status 0,  len DA, buf_ptr 1EB429F2
20 status 0,  len 252, buf_ptr 1E609686
21 status 0,  len 252, buf_ptr 1EC15166
22 status 0,  len DA, buf_ptr 1EB3C3D2
23 status 0,  len 252, buf_ptr 1E60AD46
24 status 0,  len 252, buf_ptr 1E60A386
25 status 0,  len 252, buf_ptr 1E60A6C6
26 status 0,  len 252, buf_ptr 1EC15E66
27 status 0,  len 252, buf_ptr 1E609D06
28 status 0,  len 252, buf_ptr 1E608986
29 status 0,  len DA, buf_ptr 1EB150D2
30 status 0,  len DA, buf_ptr 1EB10732
31 status 0,  len DA, buf_ptr 1EB06812
32 status 0,  len DA, buf_ptr 1EB2FC52
33 status 0,  len DA, buf_ptr 1EB05052
34 status 0,  len DA, buf_ptr 1EB4B3B2
35 status 0,  len DA, buf_ptr 1EB345F2
36 status 0,  len DA, buf_ptr 1EB0BD92
37 status 0,  len DA, buf_ptr 1EB40B12
38 status 0,  len DA, buf_ptr 1EB0CBD2
39 status 0,  len DA, buf_ptr 1EB18512
40 status 0,  len 252, buf_ptr 1E609686
41 status 0,  len 252, buf_ptr 1E60A046
42 status 0,  len DA, buf_ptr 1EB1BBB2
43 status 0,  len 252, buf_ptr 1EC15166
44 status 0,  len 252, buf_ptr 1E60A386
45 status 0,  len DA, buf_ptr 1EB2E232
46 status 0,  len DA, buf_ptr 1EB10012
47 status 0,  len 252, buf_ptr 1E60AD46
48 status 0,  len 252, buf_ptr 1E608CC6
49 status 0,  len 252, buf_ptr 1E6099C6
50 status 0,  len 252, buf_ptr 1EC147A6
51 status 0,  len DA, buf_ptr 1EB228F2
52 status 0,  len 252, buf_ptr 1EC14AE6
53 status 0,  len 252, buf_ptr 1EC14E26
54 status 0,  len 252, buf_ptr 1E607FC6
55 status 0,  len 252, buf_ptr 1EC14126
56 status 0,  len 252, buf_ptr 1EC157E6
57 status 0,  len 252, buf_ptr 1EC15B26
58 status 0,  len 252, buf_ptr 1E60AA06
59 status 0,  len 252, buf_ptr 1E608306
60 status 0,  len DA, buf_ptr 1EB06352
61 status 0,  len 252, buf_ptr 1EC154A6
62 status 0,  len 252, buf_ptr 1E608646
63 status 2000,  len DA, buf_ptr 1EB370B2
Interface GigabitEthernet0/1/1
Marvell PHY (1) Register:
LP Ability : 0xC1E1              LP NxtPg    : 0x4F06
PHY ctrl   : 0x3360              PHY status  : 0xBC48
Marvell MAC Port (1) Registers:
MAC Control : 0x3
Identifier : 0x1066              Vlan Map    : 0x7FD
Port Asc Vt: 0x2
MAC Control : 0x43E
Port Asc Vt: 0x20
= Hardware =
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1E7BCC58
MIIMADD=0x00001D11, MIIMCON=0x00000140, MIIMSTAT=0x00000020, MIIMIND=0x00000000
IFSTAT=0x00000000, MACSTNADDR1=0xF211A9F1, MACSTNADDR2=0x00640000
RMON MIB Registers
TR64=11, TR127=2, TR255=32, TR511=0
TR1K=25, TRMAX=0, TRMGV=0
RBYT=4256, RPKT=27, RFCS=0, RMCA=0
RDRP=0
TBYT=18638, TPKT=43, TMCA=0, TBCA=0
TUND=0, TFRG=0
TBI MII Registers
PHY Registers
All pages
  Register 0x16:   FFFF
  PHY Control (0x00):
  PHY Status (0x01):
Page 0
  Register 0x1A:   FFFF
Page 2
  Register 0x02:   FFFF
rxring=0x1E7BC720, rxr shadow=0x86B54AB4, rx_head=98, rx_tail=0
txring=0x1E7BCB60, txr shadow=0x86B54CE8, tx_head=31, tx_tail=31, tx_count=0
Rx Frames=256865250, Bytes=2297272756
Tx Frames=356365663, Bytes=474150137
89 status 9000,  len 40, buf_ptr 1E7EB2B8
90 status 9000,  len DE, buf_ptr 1E7D4B58
91 status 9000,  len 40, buf_ptr 1E7F6D98
92 status 9000,  len DE, buf_ptr 1E7CB468
93 status 9000,  len 40, buf_ptr 1E7F1758
94 status 9000,  len 40, buf_ptr 1E7C56F8
95 status 9000,  len 40, buf_ptr 1E7D8C08
96 status 9000,  len 40, buf_ptr 1E7C07E8
97 status 9000,  len 40, buf_ptr 1E7EAB88
98 status 9000,  len DE, buf_ptr 1E7E1498
99 status 9000,  len DE, buf_ptr 1E7C4168
100 status 9000,  len DE, buf_ptr 1E7DFF08
101 status 9000,  len DE, buf_ptr 1E7C7AE8
102 status 9000,  len DE, buf_ptr 1E7CDF88
103 status 9000,  len DE, buf_ptr 1E7EF368
104 status 9000,  len DE, buf_ptr 1E7CD858
105 status 9000,  len DE, buf_ptr 1E7D2E98
106 status 9000,  len DE, buf_ptr 1E7D6818
107 status 9000,  len DE, buf_ptr 1E7EB9E8
108 status 9000,  len DE, buf_ptr 1E7CA608
109 status 9000,  len DE, buf_ptr 1E7DE248
110 status 9000,  len 40, buf_ptr 1E7DA8C8
111 status 9000,  len 40, buf_ptr 1E7BF258
112 status 9000,  len 40, buf_ptr 1E7D2038
113 status 9000,  len DE, buf_ptr 1E7C6558
114 status 9000,  len DE, buf_ptr 1E7E1BC8
115 status 9000,  len 40, buf_ptr 1E7F5F38
116 status 9000,  len 40, buf_ptr 1E7D3CF8
117 status 9000,  len 4A, buf_ptr 1E7DA198
118 status 9000,  len DE, buf_ptr 1E7D0AA8
119 status 9000,  len DE, buf_ptr 1E7D6F48
120 status 9000,  len 40, buf_ptr 1E7BDCC8
121 status 9000,  len 4A, buf_ptr 1E7BF988
122 status 9000,  len 40, buf_ptr 1E7F4278
0 status 0,  len 46, buf_ptr 1EC1E446
25 status 0,  len 252, buf_ptr 1E6099C6
26 status 0,  len 252, buf_ptr 1EC147A6
27 status 0,  len DA, buf_ptr 1EB4A7D2
28 status 0,  len 252, buf_ptr 1E608CC6
29 status 0,  len 252, buf_ptr 1EC14AE6
30 status 0,  len 252, buf_ptr 1EC14E26
31 status 0,  len 252, buf_ptr 1E607FC6
32 status 0,  len 252, buf_ptr 1EC14126
33 status 0,  len 252, buf_ptr 1EC157E6
34 status 0,  len 252, buf_ptr 1EC15B26
35 status 0,  len 252, buf_ptr 1E60AA06
36 status 0,  len DA, buf_ptr 1EB475F2
37 status 0,  len DA, buf_ptr 1EB34AB2
38 status 0,  len DA, buf_ptr 1EB4F172
39 status 0,  len DA, buf_ptr 1EB2A472
40 status 0,  len DA, buf_ptr 1EB2D192
41 status 0,  len DA, buf_ptr 1EB2D652
42 status 0,  len DA, buf_ptr 1EB2DFD2
43 status 0,  len DA, buf_ptr 1EB26452
44 status 0,  len DA, buf_ptr 1EB4D9B2
45 status 0,  len DA, buf_ptr 1EB30112
46 status 0,  len DA, buf_ptr 1EB08492
47 status 0,  len DA, buf_ptr 1EB377D2
48 status 0,  len 252, buf_ptr 1E608306
49 status 0,  len 252, buf_ptr 1EC154A6
50 status 0,  len 252, buf_ptr 1E608646
51 status 0,  len 252, buf_ptr 1EC14466
52 status 0,  len 252, buf_ptr 1E60A6C6
53 status 0,  len 252, buf_ptr 1EC15E66
54 status 0,  len DA, buf_ptr 1EB39B72
55 status 0,  len 252, buf_ptr 1E609D06
56 status 0,  len 252, buf_ptr 1E608986
57 status 0,  len DA, buf_ptr 1EB25D32
58 status 0,  len 252, buf_ptr 1E60A046
59 status 0,  len 252, buf_ptr 1E609686
60 status 0,  len 6A, buf_ptr 1ECB9826
61 status 0,  len DA, buf_ptr 1EB2EE12
62 status 0,  len 252, buf_ptr 1E60A386
63 status 2000,  len 252, buf_ptr 1EC15166
Interface GigabitEthernet0/1/2
Marvell PHY (2) Register:
LP Ability : 0xC1E1              LP NxtPg    : 0x4B1D
Marvell MAC Port (2) Registers:
MAC Control : 0x3
Identifier : 0x1066              Vlan Map    : 0x7FB
Port Asc Vt: 0x4
MAC Control : 0x43E
Port Asc Vt: 0x20
= Hardware =
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1E7BCC68
RMON MIB Registers
TR64=12, TR127=18, TR255=55, TR511=0
RBYT=7280, RPKT=44, RFCS=0, RMCA=0
RDRP=0
TBYT=22028, TPKT=66, TMCA=10, TBCA=0
TUND=0, TFRG=0
TBI MII Registers
PHY Registers
All pages
  Register 0x16:   FFFF
  PHY Control (0x00):
  PHY Status (0x01):
Page 0
  Register 0x1A:   FFFF
Page 2
  Register 0x02:   FFFF
rxring=0x1E7BC720, rxr shadow=0x86B54AB4, rx_head=126, rx_tail=0
txring=0x1E7BCB60, txr shadow=0x86B54CE8, tx_head=10, tx_tail=10, tx_count=0
Rx Frames=256865278, Bytes=2297277096
Tx Frames=356365706, Bytes=474168275
0 status 9000,  len 40, buf_ptr 1E7D5288
1 status 9000,  len 4A, buf_ptr 1E7EC118
2 status 9000,  len DE, buf_ptr 1E7D9A68
3 status 9000,  len DE, buf_ptr 1E7D9338
4 status 9000,  len 4A, buf_ptr 1E7DE978
5 status 9000,  len DE, buf_ptr 1E7CC2C8
6 status 9000,  len DE, buf_ptr 1E7EC848
7 status 9000,  len DE, buf_ptr 1E7E2A28
8 status 9000,  len DE, buf_ptr 1E7C8218
9 status 9000,  len DE, buf_ptr 1E7F7BF8
10 status 9000,  len DE, buf_ptr 1E7E4E18
11 status 9000,  len DE, buf_ptr 1E7D11D8
12 status 9000,  len DE, buf_ptr 1E7D4428
13 status 9000,  len 40, buf_ptr 1E7ED6A8
14 status 9000,  len 40, buf_ptr 1E7C00B8
15 status 9000,  len 40, buf_ptr 1E7D7DA8
16 status 9000,  len DE, buf_ptr 1E7DF7D8
17 status 9000,  len DE, buf_ptr 1E7CD128
18 status 9000,  len 40, buf_ptr 1E7CFC48
19 status 9000,  len DE, buf_ptr 1E7F01C8
20 status 9000,  len 40, buf_ptr 1E7E3158
123 status 9000,  len 40, buf_ptr 1E7C73B8
124 status 9000,  len 40, buf_ptr 1E7EA458
125 status 9000,  len 40, buf_ptr 1E7E7938
126 status 9000,  len DE, buf_ptr 1E7BE3F8
127 status B000,  len DE, buf_ptr 1E7F49A8
1 status 0,  len 252, buf_ptr 1E60AD46
2 status 0,  len 252, buf_ptr 1E6099C6
3 status 0,  len DA, buf_ptr 1EB195B2
4 status 0,  len 252, buf_ptr 1EC147A6
5 status 0,  len 252, buf_ptr 1E608CC6
6 status 0,  len 252, buf_ptr 1EC14AE6
7 status 0,  len 252, buf_ptr 1EC14E26
8 status 0,  len 252, buf_ptr 1E607FC6
9 status 0,  len DA, buf_ptr 1EB25AD2
10 status 0,  len 252, buf_ptr 1EC14126
11 status 0,  len DA, buf_ptr 1EB052B2
12 status 0,  len 6A, buf_ptr 1EC8DD26
13 status 0,  len DA, buf_ptr 1EB2C5B2
14 status 0,  len 46, buf_ptr 1EC17646
15 status 0,  len DA, buf_ptr 1EB29892
16 status 0,  len DA, buf_ptr 1EB0C4B2
17 status 0,  len DA, buf_ptr 1EB29FB2
18 status 0,  len DA, buf_ptr 1EB3EE92
19 status 0,  len DA, buf_ptr 1EB10272
20 status 0,  len DA, buf_ptr 1EB45712
21 status 0,  len 40, buf_ptr 1E606803
22 status 0,  len 44, buf_ptr 1E606E3E
23 status 0,  len 44, buf_ptr 1E606E3E
24 status 0,  len 44, buf_ptr 1E606E3E
25 status 0,  len 44, buf_ptr 1E6070BE
26 status 0,  len 44, buf_ptr 1E6070BE
27 status 0,  len 44, buf_ptr 1E6070BE
28 status 0,  len 44, buf_ptr 1E6066BE
29 status 0,  len 44, buf_ptr 1E6066BE
30 status 0,  len 44, buf_ptr 1E6066BE
31 status 0,  len DA, buf_ptr 1EB2B772
32 status 0,  len DA, buf_ptr 1EB17B92
33 status 0,  len DA, buf_ptr 1EB50B92
34 status 0,  len 252, buf_ptr 1EC157E6
35 status 0,  len 252, buf_ptr 1EC15B26
36 status 0,  len 252, buf_ptr 1E60AA06
37 status 0,  len 252, buf_ptr 1E608306
38 status 0,  len 252, buf_ptr 1EC154A6
39 status 0,  len 252, buf_ptr 1E608646
40 status 0,  len DA, buf_ptr 1EB2DB12
41 status 0,  len DA, buf_ptr 1EB391F2
42 status 0,  len 252, buf_ptr 1EC15E66
43 status 0,  len 252, buf_ptr 1EC14466
44 status 0,  len DA, buf_ptr 1EB3D6D2
45 status 0,  len 252, buf_ptr 1E609D06
46 status 0,  len 252, buf_ptr 1E608986
47 status 0,  len 6A, buf_ptr 1ECA5BE6
48 status 0,  len DA, buf_ptr 1EB0CE32
49 status 0,  len 46, buf_ptr 1EC22906
50 status 0,  len DA, buf_ptr 1EB4ECB2
51 status 0,  len 252, buf_ptr 1E60A046
52 status 0,  len 252, buf_ptr 1E609686
53 status 0,  len 252, buf_ptr 1E60A386
54 status 0,  len 252, buf_ptr 1EC15166
55 status 0,  len 252, buf_ptr 1E60AD46
56 status 0,  len DA, buf_ptr 1EB0D2F2
57 status 0,  len 252, buf_ptr 1E6099C6
58 status 0,  len 252, buf_ptr 1E60A6C6
59 status 0,  len 252, buf_ptr 1EC147A6
60 status 0,  len 252, buf_ptr 1E608CC6
61 status 0,  len 252, buf_ptr 1EC14AE6
62 status 0,  len DA, buf_ptr 1EB28332
63 status 2000,  len DA, buf_ptr 1EB35DB2
Interface GigabitEthernet0/1/3
Control    : 0xFFFF              Status      : 0xFFFF
Identifier : 0xFFFF  0xFFFF
Auto Neg   : 0xFFFF              Auto Neg Exp: 0xFFFF
LP Ability : 0xFFFF              LP NxtPg    : 0xFFFF
PHY ctrl   : 0xFFFF              PHY status  : 0xFFFF
Marvell MAC Port (3) Registers:
Status     : 0xE86              Control     : 0x477
MAC Control : 0x43E
Identifier : 0x1066              Vlan Map    : 0x7EF
VID and PRI: 0x5A              Rate Control: 0x3000
Port Asc Vt: 0x10
MAC Control : 0x43E
Port Asc Vt: 0x20
= Hardware =
Route Cache Flag: 0
= Media  RJ45 =
IADDR0 = 0x00000000
IADDR1 = 0x00000000
IADDR2 = 0x00000000
IADDR3 = 0x00000000
IADDR4 = 0x00000000
IADDR5 = 0x00000000
IADDR6 = 0x00000000
IADDR7 = 0x00000000
GADDR0 = 0x00000000
GADDR1 = 0x00000000
GADDR2 = 0x00000000
GADDR3 = 0x00000000
GADDR4 = 0x00000000
GADDR5 = 0x00000000
GADDR6 = 0x00000000
GADDR7 = 0x00000000
TSTAT=0x00008000, TBDLEN=0x00000000, CTBPTR=0x00000000, TBPTR=0x1E7BCBF0
RMON MIB Registers
TR64=13, TR127=10, TR255=37, TR511=0
TR1K=24, TRMAX=0, TRMGV=0
RBYT=5112, RPKT=35, RFCS=0, RMCA=1
RBCA=1, RXCF=0, RXPF=0, RXUO=0
RDRP=0
TBYT=19034, TPKT=49, TMCA=4, TBCA=0
TUND=0, TFRG=0
TBI MII Registers
PHY Registers
All pages
  Register 0x16:   FFFF
  PHY Control (0x00):
  PHY Status (0x01):
Page 0
  Register 0x1A:   FFFF
Page 2
  Register 0x02:   FFFF
rxring=0x1E7BC720, rxr shadow=0x86B54AB4, rx_head=49, rx_tail=0
txring=0x1E7BCB60, txr shadow=0x86B54CE8, tx_head=18, tx_tail=18, tx_count=0
Rx Frames=256865329, Bytes=2297285148
Tx Frames=356365778, Bytes=474190739
21 status 9000,  len DE, buf_ptr 1E7EE508
22 status 9000,  len 4A, buf_ptr 1E7E22F8
23 status 9000,  len 4A, buf_ptr 1E7F74C8
24 status 9000,  len 40, buf_ptr 1E7D1908
25 status 9000,  len DE, buf_ptr 1E7DC588
26 status 9000,  len 40, buf_ptr 1E7CAD38
27 status 9000,  len DE, buf_ptr 1E7C24A8
28 status 9000,  len 40, buf_ptr 1E7DAFF8
29 status 9000,  len 40, buf_ptr 1E7F8328
30 status 9000,  len 40, buf_ptr 1E7E63A8
31 status 9000,  len DE, buf_ptr 1E7D2768
32 status 9000,  len DE, buf_ptr 1E7E8068
33 status 9000,  len DE, buf_ptr 1E7C97A8
34 status 9000,  len DE, buf_ptr 1E7ECF78
35 status 9000,  len 40, buf_ptr 1E7CEDE8
36 status 9000,  len 44, buf_ptr 1E7E7208
37 status 9000,  len DE, buf_ptr 1E7C1D78
38 status 9000,  len DE, buf_ptr 1E7C6C88
39 status 9000,  len DE, buf_ptr 1E7CF518
40 status 9000,  len DE, buf_ptr 1E7F2CE8
41 status 9000,  len DE, buf_ptr 1E7E5548
42 status 9000,  len 44, buf_ptr 1E7C9ED8
43 status 9000,  len DE, buf_ptr 1E7E8EC8
44 status 9000,  len DE, buf_ptr 1E7DBE58
45 status 9000,  len DE, buf_ptr 1E7EDDD8
46 status 9000,  len 40, buf_ptr 1E7D35C8
47 status 9000,  len 40, buf_ptr 1E7E3FB8
48 status 9000,  len 40, buf_ptr 1E7BD598
49 status 9000,  len DE, buf_ptr 1E7C0F18
50 status 9000,  len 40, buf_ptr 1E7DD3E8
51 status 9000,  len DE, buf_ptr 1E7D0378
52 status 9000,  len 40, buf_ptr 1E7D84D8
53 status 9000,  len 40, buf_ptr 1E7E46E8
54 status 9000,  len DE, buf_ptr 1E7F25B8
55 status 9000,  len DE, buf_ptr 1E7F3B48
56 status 9000,  len 40, buf_ptr 1E7C3A38
57 status 9000,  len 40, buf_ptr 1E7F50D8
58 status 9000,  len DE, buf_ptr 1E7CE6B8
59 status 9000,  len 40, buf_ptr 1E7DF0A8
60 status 9000,  len DE, buf_ptr 1E7D7678
61 status 9000,  len 40, buf_ptr 1E7C4FC8
0 status 0,  len DA, buf_ptr 1EB27292
1 status 0,  len DA, buf_ptr 1EB16892
2 status 0,  len DA, buf_ptr 1EB26DD2
3 status 0,  len 40, buf_ptr 1EC135E3
4 status 0,  len 40, buf_ptr 1EC135E3
5 status 0,  len 44, buf_ptr 1E607D3E
6 status 0,  len 44, buf_ptr 1E607D3E
7 status 0,  len DA, buf_ptr 1EB30CF2
8 status 0,  len DA, buf_ptr 1EB2F072
9 status 0,  len DA, buf_ptr 1EB3CAF2
10 status 0,  len DA, buf_ptr 1EB41BB2
11 status 0,  len DA, buf_ptr 1EB32712
12 status 0,  len DA, buf_ptr 1EB4AC92
13 status 0,  len DA, buf_ptr 1EB416F2
14 status 0,  len 252, buf_ptr 1EC14E26
15 status 0,  len 252, buf_ptr 1E607FC6
16 status 0,  len 252, buf_ptr 1EC14126
17 status 0,  len 252, buf_ptr 1EC157E6
18 status 0,  len 252, buf_ptr 1EC15B26
19 status 0,  len 252, buf_ptr 1E60AA06
20 status 0,  len DA, buf_ptr 1EB3FCD2
21 status 0,  len DA, buf_ptr 1EB38872
22 status 0,  len 252, buf_ptr 1E608646
23 status 0,  len 252, buf_ptr 1E608306
24 status 0,  len 252, buf_ptr 1EC154A6
25 status 0,  len DA, buf_ptr 1EB49272
27 status 0,  len DA, buf_ptr 1EB4A0B2
29 status 0,  len 252, buf_ptr 1EC14466
30 status 0,  len 252, buf_ptr 1E609D06
31 status 0,  len 252, buf_ptr 1E60A046
32 status 0,  len DA, buf_ptr 1EB21852
33 status 0,  len 252, buf_ptr 1EC15166
34 status 0,  len 252, buf_ptr 1E609686
35 status 0,  len 252, buf_ptr 1E60AD46
36 status 0,  len 252, buf_ptr 1E6099C6
37 status 0,  len 252, buf_ptr 1E60A386
38 status 0,  len 252, buf_ptr 1E60A6C6
39 status 0,  len DA, buf_ptr 1EB12152
40 status 0,  len DA, buf_ptr 1EB26B72
41 status 0,  len DA, buf_ptr 1EB358F2
42 status 0,  len DA, buf_ptr 1EB21F72
43 status 0,  len DA, buf_ptr 1EB060F2
44 status 0,  len DA, buf_ptr 1EB51772
45 status 0,  len DA, buf_ptr 1EB42792
46 status 0,  len DA, buf_ptr 1EB3F352
47 status 0,  len DA, buf_ptr 1EB261F2
48 status 0,  len DA, buf_ptr 1EB20552
49 status 0,  len DA, buf_ptr 1EB28CB2
50 status 0,  len DA, buf_ptr 1EB4BD32
51 status 0,  len DA, buf_ptr 1EB14032
52 status 0,  len DA, buf_ptr 1EB441B2
53 status 0,  len 252, buf_ptr 1EC14AE6
54 status 0,  len 252, buf_ptr 1EC147A6
55 status 0,  len 252, buf_ptr 1E608CC6
56 status 0,  len 252, buf_ptr 1EC14E26
57 status 0,  len 252, buf_ptr 1E607FC6
Interface Serial0/2/0:15
Hardware is HDLC32
HDLC32 resource allocated to this interface:
Slot 0, Vic_slot 2, Port 0
CRC on 1, idle flags 1, frame inverted 0, clocking 0
Channel-group number 15, hdlc32 channel number 0
Channel-group bitfield 0x10000, hdlc32 quad used 0x1
Channel HW state: 2
TX Ring:
data_ptr: 0x0, descriptor: 0x0
RX Ring:
data_ptr: 0x1EC65FC4, descriptor: 0x88800000
data_ptr: 0x1EC66484, descriptor: 0x88800000
data_ptr: 0x1EC666E4, descriptor: 0x88800000
data_ptr: 0x1EC66944, descriptor: 0x88800000
hdlc_chan hdlc_quad owner_idb chan chan_bitfield vic_slot port
0         1         88937B04  15   10000         2        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
-1        0         0         0    0             0        0
------------------ show user ------------------
------------------ show file systems ------------------
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   archive:
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     rw   null:
             -             -   network     rw   tftp:
        262144        228451     nvram     rw   nvram:
*    260177920     195690496      disk     rw   flash:#
             -             -    opaque     wo   syslog:
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -    opaque     ro   tar:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
------------------ show file descriptors ------------------
File Descriptors:
   FD  Position  Open  PID  Path
  No open file descriptors
------------------ dir nvram: ------------------
Directory of nvram:/
  230  -rw-       21481                      startup-config
  231  ----        1920                      private-config
  232  -rw-       21481                      underlying-config
    1  ----         107                      persistent-data
    2  -rw-         585                      IOS-Self-Sig#1.cer
    3  -rw-           0                      ifIndex-table
    4  -rw-         577                      IOS-Self-Sig#2.cer
    5  -rw-         720                      vlan.dat
    6  -rw-         107                      cca.xml
    7  -rw-         577                      IOS-Self-Sig#3.cer
    8  -rw-         577                      IOS-Self-Sig#4.cer
    9  -rw-         577                      IOS-Self-Sig#5.cer
   10  -rw-         589                      IOS-Self-Sig#6.cer
262144 bytes total (228451 bytes free)
------------------ show flash: all ------------------
-#- --length-- -----date/time------ path
1          780 May 19 2012 15:39:54 vlan.dat
2     39494320 May 17 2012 00:09:58 uc500-advipservicesk9-mz.151-2.T4
3            0 May 17 2012 00:10:38 phones
4            0 May 17 2012 00:10:40 phones/521_524
5       892511 May 17 2012 00:10:48 phones/521_524/cp524g-8-1-17.bin
6            0 May 17 2012 00:10:42 phones/50x-30x
7      3944218 May 17 2012 00:11:08 phones/50x-30x/spa50x-30x-7-4-8a.bin
8            0 May 17 2012 00:10:42 phones/525
9     10409472 May 17 2012 00:11:52 phones/525/spa525g-7-4-8.bin
10       21578 May 17 2012 00:13:48 UC560-FXO-K9-factory-8.2.0.cfg
11           0 May 17 2012 00:12:30 autoattendant
12       94503 May 17 2012 00:12:30 autoattendant/AA_SBCS_v01.aef
13       96166 May 17 2012 00:12:32 autoattendant/AA_SBCS_v02.aef
14      130488 May 17 2012 00:12:32 autoattendant/AA_SBCS_v03.aef
15       15891 May 17 2012 00:12:32 autoattendant/AA_transfer.aef
16           0 May 17 2012 00:12:40 cca
17         845 May 17 2012 00:12:40 cca/Key_Phoneloads.csv
18      113875 May 17 2012 00:12:42 cca/sccpphoneloadstable.csv
19         375 May 17 2012 00:12:42 cca/UC500_CCA_Dir_8.0.2.txt
20           0 May 17 2012 00:12:42 gui
21        3987 May 17 2012 00:12:42 gui/admin_user.html
22      677820 May 17 2012 00:12:46 gui/admin_user.js
23        1029 May 17 2012 00:12:46 gui/CiscoLogo.gif
24         635 May 17 2012 00:12:46 gui/CME_GUI_README.TXT
25         953 May 17 2012 00:12:46 gui/Delete.gif
26       16344 May 17 2012 00:12:48 gui/dom.js
27         864 May 17 2012 00:12:48 gui/downarrow.gif
28        6146 May 17 2012 00:12:48 gui/ephone_admin.html
29        4558 May 17 2012 00:12:48 gui/logohome.gif
30        3866 May 17 2012 00:12:48 gui/normal_user.html
31       78428 May 17 2012 00:12:50 gui/normal_user.js
32        1347 May 17 2012 00:12:50 gui/Plus.gif
33           0 May 17 2012 00:12:50 gui/sn
34       11513 May 17 2012 00:12:50 gui/sn/handshake.html
35      633459 May 17 2012 00:12:52 gui/sn/handshake.swf
36         843 May 17 2012 00:12:54 gui/sxiconad.gif
37         174 May 17 2012 00:12:54 gui/Tab.gif
38        2432 May 17 2012 00:12:54 gui/telephony_service.html
39         870 May 17 2012 00:12:54 gui/uparrow.gif
40        9968 May 17 2012 00:12:56 gui/xml-test.html
41        3412 May 17 2012 00:12:56 gui/xml.template
42       26658 May 17 2012 00:45:42 startup-config.bak
43           0 May 17 2012 00:13:16 sn
44           0 May 17 2012 00:13:16 sn/status
45           0 May 17 2012 00:13:16 sn/tmp
46           0 May 17 2012 00:14:04 its
47     1084416 May 17 2012 00:14:16 its/CME-locale-en_US-English-8.1.2.1.tar
48     1245184 May 17 2012 00:15:20 its/CME-locale-es_ES-Spanish-8.1.2.1.tar
49         102 May 19 2012 13:14:10 its/SEPDEFAULT.cnf
50        4196 May 18 2012 23:49:56 its/XMLDefault.cnf.xml
59         903 Aug 28 2013 19:36:14 its/united_states_7960-tones.xml
60        8777 Aug 28 2013 19:36:16 its/united_states_7960-font.xml
61        1481 May 26 2013 13:54:30 its/
133          0 May 17 2012 00:14:20 English_United_States
134    1084416 May 17 2012 00:14:38 English_United_States/CME-locale-en_US-English-8.1.2.1.tar
135      46958 May 17 2012 00:14:38 English_United_States/501-dictionary.xml
136      46958 May 17 2012 00:14:38 English_United_States/502-dictionary.xml
137      46958 May 17 2012 00:14:40 English_United_States/504-dictionary.xml
138      46958 May 17 2012 00:14:40 English_United_States/508-dictionary.xml
139      46958 May 17 2012 00:14:40 English_United_States/509-dictionary.xml
140      16180 May 17 2012 00:14:42 English_United_States/521-dictionary.xml
141      16180 May 17 2012 00:14:42 English_United_States/524-dictionary.xml
142      76288 May 17 2012 00:14:42 English_United_States/525G-dictionary.xml
143       1313 May 17 2012 00:14:42 English_United_States/525G-kate.xml
144        903 May 17 2012 00:14:42 English_United_States/525G-tones.xml
145      76288 May 17 2012 00:14:44 English_United_States/525G2-dictionary.xml
146       1313 May 17 2012 00:14:44 English_United_States/525G2-kate.xml
147        903 May 17 2012 00:14:44 English_United_States/525G2-tones.xml
148      55698 May 17 2012 00:14:44 English_United_States/7921-dictionary.xml
149     137616 May 17 2012 00:14:46 English_United_States/7921-font.dat
150       1723 May 17 2012 00:14:46 English_United_States/7921-kate.utf-8.xml
151       1729 May 17 2012 00:14:46 English_United_States/7921-kate.xml
152      19750 May 17 2012 00:14:46 English_United_States/7960-dictionary.xml
153       8777 May 17 2012 00:14:48 English_United_States/7960-font.xml
154       1313 May 17 2012 00:14:48 English_United_States/7960-kate.xml
155        903 May 17 2012 00:14:48 English_United_States/7960-tones.xml
156        665 May 17 2012 00:14:48 English_United_States/CME-locale-en_US-English-8.1.2.1.tar.cfg
157       2740 May 17 2012 00:14:48 English_United_States/SCCP-dictionary.xml
158      59183 May 17 2012 00:14:50 English_United_States/be-sccp.jar
159       1413 May 17 2012 00:14:50 English_United_States/g3-tones.xml
160      72136 May 17 2012 00:14:50 English_United_States/gp-sccp.jar
161      59183 May 17 2012 00:14:50 English_United_States/ipc-sccp.jar
162      59183 May 17 2012 00:14:52 English_United_States/mk-sccp.jar
163      69853 May 17 2012 00:14:52 English_United_States/rp-sccp.jar
164       2605 May 17 2012 00:14:52 English_United_States/tags_file
165      19318 May 17 2012 00:14:52 English_United_States/tc-sccp.jar
166      59183 May 17 2012 00:14:52 English_United_States/td-sccp.jar
167       2605 May 17 2012 00:14:54 English_United_States/utf8_tags_file
170     314268 Mar 04 2013 19:29:00 crashinfo_20130304-132837-CST
171      50017 Aug 28 2013 19:35:32 its/user_define_4_501-dictionary.xml
172      50017 Aug 28 2013 19:35:32 its/user_define_4_502-dictionary.xml
173      50017 Aug 28 2013 19:35:32 its/user_define_4_504-dictionary.xml
174      50017 Aug 28 2013 19:35:34 its/user_define_4_508-dictionary.xml
175      50017 Aug 28 2013 19:35:34 its/user_define_4_509-dictionary.xml
176      31780 Aug 28 2013 19:35:34 its/user_define_4_521-dictionary.xml
177      31780 Aug 28 2013 19:35:36 its/user_define_4_524-dictionary.xml
178      81670 Aug 28 2013 19:35:36 its/user_define_4_525G-dictionary.xml
179       1339 Aug 28 2013 19:35:36 its/user_define_4_525G-kate.xml
180       1095 Aug 28 2013 19:35:36 its/user_define_4_525G-tones.xml
181      81670 Aug 28 2013 19:35:38 its/user_define_4_525G2-dictionary.xml
182       1339 Aug 28 2013 19:35:38 its/user_define_4_525G2-kate.xml
183       1095 Aug 28 2013 19:35:38 its/user_define_4_525G2-tones.xml
184      27266 Aug 28 2013 19:35:38 its/user_define_4_7905-dictionary.xml
185      60430 Aug 28 2013 19:35:38 its/user_define_4_7921-dictionary.xml
186     137616 Aug 28 2013 19:35:40 its/user_define_4_7921-font.dat
187       1790 Aug 28 2013 19:35:40 its/user_define_4_7921-kate.utf-8.xml
188       1770 Aug 28 2013 19:35:40 its/user_define_4_7921-kate.xml
189      21054 Aug 28 2013 19:35:42 its/user_define_4_7960-dictionary.xml
190       8777 Aug 28 2013 19:35:42 its/user_define_4_7960-font.xml
191       1339 Aug 28 2013 19:35:42 its/user_define_4_7960-kate.xml
192       1095 Aug 28 2013 19:35:42 its/user_define_4_7960-tones.xml
193        690 Aug 28 2013 19:35:44 its/user_define_4_CME-locale-es_MX-Spanish-8.1.2.1.tar.cfg
194       2838 Aug 28 2013 19:35:44 its/user_define_4_SCCP-dictionary.xml
195      61858 Aug 28 2013 19:35:44 its/user_define_4_be-sccp.jar
196       1440 Aug 28 2013 19:35:44 its/user_define_4_g3-tones.xml
197      74890 Aug 28 2013 19:35:46 its/user_define_4_gp-sccp.jar
198      61946 Aug 28 2013 19:35:46 its/user_define_4_ipc-sccp.jar
199      61655 Aug 28 2013 19:35:46 its/user_define_4_mk-sccp.jar
200      69843 Aug 28 2013 19:35:48 its/user_define_4_rp-sccp.jar
201       2876 Aug 28 2013 19:35:48 its/user_define_4_tags_file
202      71724 Aug 28 2013 19:35:48 its/user_define_4_tc-sccp.jar
203      61946 Aug 28 2013 19:35:48 its/user_define_4_td-sccp.jar
204       2846 Aug 28 2013 19:35:50 its/user_define_4_utf8_tags_file
195690496 bytes available (64487424 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Manufacturer Name
   Model Number           UNIGEN FLASH
   Serial Number          UNIGEN      00210337
   Firmware Revision      090529
   Number of Heads        16
   Number of Cylinders    994
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          508928
ATA PARTITION 1 INFO
   Start Sector           32
   Number of Sectors      508896
   Size in Bytes          260554752
   File System Type       FAT16
   Number of FAT Sectors  249
   Sectors Per Cluster    8
   Number of Clusters     63520
   Number of Data Sectors 508160
   Base FAT Sector        205
   Base Root Sector       703
   Base Data Sector       735
ATA MONLIB INFO
   Image Monlib size      102972
   Disk Monlib Size       100616
   Disk Space Available   104448
   Name                   freddo-atafslib-m
   Start sector           2
   End sector             198
   Updated By             UC500-ADVIPSERVICESK9-M15.0(1)XA
   Version                2
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   8602B48C   408767348    80970456   327796892   326270516   324077204
      I/O   1E600000    27262976     7017120    20245856    20106064    20077852
------------------ show process memory ------------------
Processor Pool Total:  408767348 Used:   80967728 Free:  327799620
      I/O Pool Total:   27262976 Used:    7016608 Free:   20246368
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  207029452  131728164   65079256       2815  233899846 *Init*
   0   0      12052   76774796      12052         53         53 *Sched*
   0   0  419111024  424333752    1720652        140        126 *Dead*
   0   0          0          0    1772012          0          0 *MallocLite*
   1   0    3187192    1168160    2768476          0          0 Chunk Manager
   2   0        236        236       4116          0          0 Load Meter
   3   0          0          0       7184          0          0 faxmsp
   4   0  215499192  215435356      91472          0          0 EDDRI_MAIN
   5   0          0          0       7116          0          0 RO Notify Timers
   6   0       3404        304      10216          0          0 Check heaps
   7   0   74685824  111247308      87680         45          0 Pool Manager
   8   0          0          0       7116          0          0 DiscardQ Backgro
   9   0        236        236       7116          0          0 Timers
  10   0          0          0       4116          0          0 WATCH_AFS
  11   0          0          0       7116          0          0 License Client N
  12   0          0          0      25116          0          0 Crash writer
  13   0        352          0       7468          0          0 Exception contro
  14   0          0          0       7116          0          0 IPC Event Notifi
  15   0          0          0       7116          0          0 IPC Dynamic Cach
  16   0          0          0       7116          0          0 IPC Session Serv
  17   0          0          0       7116          0          0 IPC Zone Manager
  18   0          0          0       7116          0          0 IPC Periodic Tim
  19   0          0          0       7116          0          0 IPC Deferred Por
  20   0          0          0       7116          0          0 IPC Process leve
  21   0       1704          0       8820          0          0 IPC Seat Manager
  22   0          0          0       7116          0          0 IPC Seat RX Cont
  23   0          0          0       7116          0          0 IPC Seat TX Cont
  24   0          0          0       7116          0          0 IPC Keep Alive M
  25   0          0          0       7116          0          0 IPC Loadometer
  26   0      40464      20248      27332   17574479   17574479 ARP Input
  27   0      44328      44328       7116        353        353 ARP Background
  28   0        236        236       7116          0          0 ATM Idle Timer
  29   0          0          0       7116          0          0 ATM ASYNC PROC
  30   0          0          0       7116          0          0 AAA_SERVER_DEADT
  31   0          0          0      13116          0          0 Policy Manager
  32   0        236        236       7116          0          0 DDR Timers
  33   0      24540      83104      31656        129        129 Entity MIB API
  34   0     265608          0     275724      21140      21108 EEM ED Syslog
  35   0        892        892       7116          0          0 PrstVbl
  36   0        236        236       7116          0          0 Serial Backgroun
  37   0          0          0       4116          0          0 RMI RM Notify Wa
  38   0        236        236       7116          0          0 SMART
  39   0        236        236       7116          0          0 GraphIt
  40   0        236        236      13116          0          0 Dialer event
  41   0          0          0       7116          0          0 SERIAL A'detect
  42   0        236        236      13116          0          0 XML Proxy Client
  43   0          0          0       7116          0          0 Critical Bkgnd
  44   0      92708       3936      54648        316        316 Net Background
  45   0       2096       2096      13116          0          0 IDB Work
  46   0      35392        304      13116      41039      41039 Logger
  47   0        236       3788       7116          0          0 TTY Background
  48   0     150404      65588     157520          0          0 IF-MGR control p
  49   0          0          0       7116          0          0 IF-MGR event pro
  50   0          0          0       4116          0          0 Inode Table Dest
  51   0        236        236       7116          0          0 Fast Throttle Ti
  52   0          0       6132       7116         38         38 AggMgr Process
  53   0          0          0       7116          0          0 Transport Port A
  54   0          0          0       7116          0          0 HC Counter Timer
  55   0        236        236       7116          0          0 AUX
  56   0        236        236       7116          0          0 Eswilp Storm Con
  57   0    2738316      43164    1424648          2          2 ESWPPM
  58   0      39776        236       7116    1923014    1923014 SM Monitor
  59   0          0          0       4116          0          0 dev_device_inser
  60   0          0          0       4116          0          0 dev_device_remov
  61   0        236        236       7116        110        110 Netclock Backgro
  62   0      80452        236      87332          0          0 VNM DSPRM MAIN
  63   0        236        236       7116         24         24 FLEX DNLD MAIN
  64   0        236        236       7116          2          2 Service Module E
  65   0        304        304       7116          0          0 COLLECT STAT COU
  66   0       2204       2204       7116          0          0 Switch Link Moni
  67   0          0          0       7116          0          0 IGMP Snooping Pr
  68   0          0          0       7116      76360      76360 IGMP Snooping Re
  70   0          0          0       7116          0          0 Platform Compact
  71   0          0          0      10116          0          0 Crypto Device Up
  72   0          0          0       7116          1          1 Multi-ISA Event
  73   0          0          0       7116          0          0 Multi-ISA Cleanu
  74   0     442136     427944      21308          0          0 crypto engine pr
  75   0        236        236       7116          0          0 SEC BATCH
  76   0        236          0       4352          0          0 Async write proc
  77   0        236          0       4352          0          0 Async write proc
  78   0        236          0       4352          0          0 Async write proc
  79   0        236          0       4352          0          0 Async write proc
  80   0          0          0       4116          0          0 DFS flush period
  81   0        236        236       7116          0          0 PI MATM Aging Pr
  82   0       1096        236       7976          0          0 DTP Protocol
  83   0        236        236       7116          0          0 Dot1x Mgr Proces
  84   0          0          0       7116          0          0 EAP Framework
  85   0          0          0       7116          0          0 MAB Framework
  86   0        236        236      13116          0          0 Ethernet CFM
  87   0        236        236      13116          0          0 Ethernet Timer C
  88   0        236        236      13116          0          0 Ethernet Msec Ti
  89   0          0          0       7116          0          0 linktest
  90   0        236        236       9116          0          0 Dot11 Mgmt & Ass
  91   0        236        236      10116          0          0 Dot11 aaa proces
  92   0          0          0      10116          0          0 pmkid
  93   0        236        236      10116          0          0 Dot11 auth Dot1x
  94   0          0          0       7116          0          0 Dot11 Mac Auth
  95   0      10288        236      17168          0          0 AAA Server
  96   0          0          0       7116          0          0 AAA ACCT Proc
  97   0      49412          0      56528          0          0 ACCT Periodic Pr
  98   0          0          0       7116          0          0 AAA System Acct
  99   0      10376       3772      12844    1683430    1683430 CDP Protocol
100   0       5288        236      12168          0          0 AAA Dictionary R
101   0        236        236      10116          0          0 Ethernet OAM Pro
102   0        228          0      13344          0          0 CEF switching ba
103   0        228          0       4344          0          0 ADJ NSF process
104   0      21140        688      33568          3          3 ADJ resolve proc
105   0        236        236       7116          0          0 IPAM/ODAP Events
106   0      49384          0      62500          0          0 IPAM Manager
107   0        236        236      13116          0          0 IPAM Events
108   0     104040      32828      54276          0          0 IP ARP Adjacency
109   0      49384          0      56500          0          0 IP ARP Retry Age
110   0   54681708  806209824      90848   83713850   83713810 IP Input
111   0          0          0       7116          0          0 ICMP event handl
112   0        236        236       7116          0          0 PIM register asy
113   0        236        236       7116          0          0 TurboACL
114   0        236        236       7116          0          0 TurboACL chunk
115   0          0          0       7116          0          0 IPv6 ping proces
116   0        236        236       7116          0          0 PPP SIP
117   0        236        236       7116          0          0 PPP Bind
118   0        236        236      13116          0          0 PPP IP Route
119   0 4276264932 3622727020     532320  111420852  111420813 Skinny Msg Serve
120   0          0          0      13116          0          0 SSS Manager
121   0          0          0      13116          0          0 SSS Policy Manag
122   0          0          0       7116          0          0 SSS Feature Mana
123   0          0          0       7116          0          0 SSS Feature Time
124   0     147524        236      13352   50123777   50123777 Spanning Tree
125   0        236        236      13116          0          0 SSM connection m
126   0          0          0       7116          0          0 Authentication P
127   0          0          0       7116          0          0 Auth-proxy AAA B
128   0        236        236      10116          0          0 EAPoUDP Process
129   0        236        236      10116          0          0 IP Host Track Pr
130   0        236        236      13116          0          0 KRB5 AAA
131   0      10316        488      18996          0          0 CEF background p
132   0        224          0      13340          0          0 fib_fib_bfd_sb e
133   0      21836       4512      20212          0          0 CEF: IPv4 proces
134   0        228      20116       7344          0          0 ADJ background
135   0       2068        832       9184          0          0 L2MM
136   0          0          0       7116          0          0 MRD
137   0          0          0       7116     147810     147810 IGMPSN
138   0        236        236       4116          0          0 L2X Switching Ev
139   0        472        236       7352          0          0 Dot1x Supplicant
140   0        472        236       7352          0          0 Dot1x Supplicant
141   0        500        236       7380          0          0 Dot1x Supplicant
142   0        236        236       7116          0          0 RLM groups Proce
143   0 4052661780 4052662944       7116          0          0 Licensing Auto U
144   0          0          0       7188          0          0 SNMP Timers
145   0        236        236       7116          0          0 PPP Compress Inp
146   0        236        236       7116          0          0 PPP Compress Res
147   0          0          0       7116          0          0 Socket Timers
148   0        456    4156476      13116    2883919    2883919 TCP Timer
149   0    2341036      62308      13116          0          0 TCP Protocols
150   0        940          0      62056          0          0 COPS
151   0        236        236       7116          0          0 Flow Exporter Ti
152   0   42718676   16839640     126808      13007      13007 HTTP CORE
153   0          0          0       7116          0          0 IP Traceroute
154   0          0          0      13116          0          0 Skinny MOH Serve
155   0        472        236      10352          0          0 Multicast Offloa
156   0        228          0      13344          0          0 MFIB Master back
157   0          0          0       7116          1          1 RARP Input
158   0      26448      20176      32704          0          0 IP RIB Update
159   0      17860      21684      10648          0          0 IP Background
160   0      35596       3860      41852          0          0 IP Connected Rou
161   0        236       6236      10116          0          0 static
162   0          0          0      10116          0          0 IP IRDP
163   0          0          0       7116          0          0 IPv6 Inspect Tim
164   0          0          0       7116          0          0 MQC Flow Event B
165   0          0          0       7116          0          0 HQF Shaper Backg
166   0      13352        236      20232          0          0 RUDPV1 Main Proc
167   0      85252        236      26372          0          0 SCTP Main Proces
168   0          0          0      13116          0          0 VPDN call manage
169   0          0          0      13116          0          0 IPS Process
170   0      16816        236      29696          0          0 IPS Auto Update
171   0        372        236       7252          0          0 SDEE Management
172   0        236        236       7116          0          0 Inspect process
173   0 3648956032 3501533328    1295388      10395      10395 AFW_application_
174   0        236        236       7116          0          0 FW DP Inspect pr
175   0        236        236       7116          0          0 CCE DP URLF cach
176   0     570752          0      15528          2          2 SSH Event handle
177   0       1176        236       8056          0          0 URL filter proc
178   0          0          0       7116          0          0 Select Timers
179   0      76472        236      83352          0          0 HTTP Process
180   0       2188        236       9068          0          0 CIFS API Process
181   0      12576        236      19456          0          0 CIFS Proxy Proce
182   0     222820        640     215728          2          2 Crypto HW Proc
183   0       9180        236      16060          0          0 CCVPM_HDSPRM
184   0       1364        236       8244          0          0 CRM_CALL_UPDATE_
185  67    1333620    1327904      19508        406        390 Virtual Exec
186   0        236        236       7188          0          0 AAA Cached Serve
187   0        236        236       7116          0          0 ENABLE AAA
188   0          0          0       7116          0          0 EM Background Pr
189   0          0          0       7116          0          0 IDMGR CORE
190   0          0          0       7116          0          0 Key chain liveke
191   0        236        236       7116          0          0 LINE AAA
192   0      29172      29172       7116          0          0 LOCAL AAA
193   0       1088        236       7968          0          0 TPLUS
194   0        236        236       7116          0          0 VSP_MGR
195   0        940          0      26056          0          0 FW_TEST_TRP
196   0          0          0       7116          0          0 EPM MAIN PROCESS
197   0   25341444   25340204       8356       8018       8018 NIST rng proc
198   0     179888        476     188528          0          0 Crypto WUI
199   0        996        236       7876          0          0 LDAP process
200   0        236        236       7116          0          0 Crypto Support
201   0          0          0       7116          0          0 IPSECv6 PS Proc
202   0  232979232   70277152     288628    1297743    1297743 CCVPM_HTSP
203   0        236        236       7116          0          0 VPM_MWI_BACKGROU
204   0        436          0       7552          0          0 CCVPM_R2
205   0       3852          0      10968          0          0 IP TRUST Registe
206   0       5052          0      12168          0          0 EPHONE MWI Refre
207   0          0          0       7116          0          0 FB/KS Log HouseK
208   0        304        304       7116          0          0 EPHONE MWI BG Pr
209   0       8244          0      15360          0          0 Skinny HW confer
210   0     558476       4344     302980         14         14 FLEX DSPRM MAIN
211   0          0          0       7116          0          0 FLEX DSP KEEPALI
212   0        908        236      25788          0          0 CTI Front End Pr
213   0        236        236       7116          0          0 CTI Call Control
214   0        236        236       7116          0          0 CTI Line Monitor
215   0          0          0       7116          0          0 CME CTI Device M
216   0        304        304       7116          0          0 VOICE REG BG Pro
217   0          0          0       7116          0          0 Presence Process
218   0     223484       1536     229352          0          0 IP SLAs XOS Even
219   0        940          0      62056          0          0 http client proc
220   0          0          0       7184          0          0 DocMSP
221   0     254136          0     264252          0          0 QOS_MODULE_MAIN
222   0        284          0      25400          0          0 RPMS_PROC_MAIN
223   0          0          0      25116          0          0 VoIP AAA
224   0      23848        236      30728          0          0 Dialog Manager
225   0       3908       2404      15396          1          1 Crypto CA
226   0          0          0      13116          0          0 Crypto PKI-CRL
227   0          0          0      13116          0          0 encrypt proc
228   0 2088964924 2089527936       9220          0          0 crypto sw pk pro
229   0          0          0       7116          0          0 Crypto INT
230   0        236        708      13116          4          4 Crypto IKE Dispa
231   0       5260        876      18140          1          1 Crypto IKMP
232   0          0          0      10116          0          0 IPSEC manual key
233   0      30684       4652      39148          1          1 IPSEC key engine
234   0          0          0       7116          0          0 CRYPTO QoS proce
235   0      44020       3964      65172          0          0 Crypto ACL
236   0          0          0       7116          0          0 Crypto PAS Proc
237   0          0          0       7116          0          0 GDOI GM Process
238   0          0          0       7116          0          0 UNICAST REKEY
239   0          0          0       7116          0          0 UNICAST REKEY AC
240   0        236        236       7116          0          0 Environmental mo
241   0      52608      64772      20268          0          0 PM Callback
242   0        236        236       7116          0          0 Control-plane ho
243   0          0          0      10116          0          0 Licensing MIB pr
244   0        224          0       7340          0          0 DATA Transfer Pr
245   0        224          0       7340          0          0 DATA Collector
246   0    4032784   20318796       7116          0          0 AAA SEND STOP EV
247   0          0          0      13116          0          0 Test AAA Client
248   0       4080          0      14196          0          0 EEM ED Track
249   0       5904          0      16020          0          0 EEM ED Resource
250   0       4164          0      14280          0          0 EEM ED Routing
251   0        236        236       7116          0          0 RMON Recycle Pro
252   0        236        236       7116          0          0 RMON Deferred Se
253   0          0          0       7116          0          0 Syslog Traps
254   0          0          0       7116          0          0 Crypto cTCP proc
255   0      78660       5340      80276          0          0 VLAN Manager
256   0          0          0       7184          0          0 fax timers
257   0          0          0       7116          0          0 trunk conditioni
258   0       4660          0      11776          0          0 trunk conditioni
260   0          0          0       7116          0          0 CME Extension Mo
261   0     181888          0     189004          0          0 EEM Server
262   0      11560       1740      16936          0          0 EEM Policy Direc
263   0       4164          0      14280          0          0 EEM ED CLI
264   0       4080          0      14196          0          0 EEM ED Counter
265   0       4080          0      14196          0          0 EEM ED Interface
266   0       4080          0      14196          0          0 EEM ED IOSWD
267   0       4080          0      14244          0          0 EEM ED None
268   0       4080          0      14196          0          0 EEM ED OIR
269   0        224          0      13408          0          0 Collection proce
270   0       4448          0      14564          0          0 EEM ED Timer
271   0       4080          0      14196          0          0 EEM ED Ipsla
272   0       4080          0      14196          0          0 EEM ED SNMP Obje
273   0       4080          0      14196          0          0 EEM ED Test
274   0       4080          0      14196          0          0 EEM ED Config
275   0       4080          0      14196          0          0 EEM ED Env
276   0       4080          0      14196          0          0 EM ED GOLD
277   0       9132          0      19248          0          0 EEM ED Nf
278   0    5636552    5636552      13116      20875      20875 Syslog
279   0          0          0       7116          0          0 IP SLAs Ethernet
280   0          0          0       7116          0          0 VDC process
281   0       4080          0      14196          0          0 EEM ED RPC
282   0          0          0       7116    2133167    2133167 Net Input
283   0        236        236       7116          0          0 Compute load avg
284   0          0 1540027840       7116          0          0 Per-minute Jobs
285   0          0          0      10116          0          0 Per-Second Jobs
286   0       1744        236      14624          0          0 MRIB Process
287   0          0          0       9116          0          0 Key Proc
288   0        236        236       7116          0          0 TRP_PSEUDOTIMER
289   0        524        236       7404          0          0 Resource Monitor
290   0        236        236       7116          0          0 Resource Availab
291   0   55438712   53243796     239732          0          0 CC-API_VCM
292   0        236        236      13116          0          0 confmsp
293   0  832519140 1747595288     223148   15352995   15352995 DSMP
294   0 3174260108  808698092     749792      12019      12019 VTSP
295   0    3978996   30422624      10332      56458      56458 VOIP_RTCP
296   0     259328       1216      40300          0          0 Session Applicat
297   0     407868        236     420748          0          0 swmtp_msp
298   0      35304          0      60420          0          0 TSP
299   0        828          0      13944          0          0 lib_off_app
300   0        236        236       7116          0          0 Voice Player
301   0          0          0       7116          0          0 Media Record
302   0          0          0       7116          0          0 Resource Measure
303   0     912960        236     973840          0          0 CCH323_CT
304   0          0          0       7116          0          0 CCH323_DNS
305   0  855494200  923702756    2366724          8          8 CCSIP_SPI_CONTRO
306   0  190055096  189065604      13416     987205     987205 CCSIP_DNS
307   0  267094088  199469076     174756     189210     189210 CCSIP_UDP_SOCKET
308   0     265716        312     290256          0          0 CCSIP_TCP_SOCKET
309   0     267364        236     292244          0          0 CCSIP_TLS_SOCKET
310   0     460072          0     485188          0          0 RTPSPI
311   0       1400        236       8280        106        106 e1t1 Framer back
312   0    1775868    1682596      66260      10517      10517 DHCPD Receive
313   0      19312        236      32192          0          0 SCCP Telephony C
314   0   68585668   50608900     169876      90088      90088 ISDN
315   0        236        236      25116          0          0 ISDN Timer
316   0          0     134048       7116          0          0 ISDNMIB Backgrou
317   0          0    4031972       7116          0          0 CallMIB Backgrou
318   0          0          0       7116    2126437    2126437 ISDN From Driver
319   0          0          0      13116          0          0 DHCP Client
321   0       4256       4808       7116          0          0 IP NAT Ager
322   0          0          0       7116          0          0 IP NAT WLAN
323   0          0          0       7116          0          0 IP VFR proc
324   0      12068        152      17820          0          0 DNS Server
325   0        236          0       7352          0          0 DNS Server Input
326   0       7128       6180      14064         52         52 IP SNMP
327   0        936          0      14052          0          0 PDU DISPATCHER
328   0      11040       8124      16032          0          0 SNMP ENGINE
329   0       1184        236      14064          0          0 IP SNMPV6
330   0          0          0      13116          0          0 SNMP ConfCopyPro
331   0        236        236      13116          0          0 SNMP Traps
332   0     448896     370572     282748    2900298    2900296 SCCP Application
333   0      38476        288      51304          2          2 MLD
334   0          0          0      10116          0          0 IPv6 RIB Event H
335   0        236        236       7116          0          0 Skinny MOH Event
336   0     370000     288540      33916          0          0 Skinny Socket Se
337   0  365536700  365536540      13356          0          0 Web Write Housek
338   0       8036        236      13408     109207     109207 NTP
339   0      58396          0      10528    4367568    4367568 ISDN L2 Process
340   0          0          0       7116          5          5 ISDN L3 Timer Pr
341   0          0          0       7116    2126512    2126512 ISDN L2D SRQ Pro
343   0          0          0      13116          0          0 esmtp client soc
344   0          0          0       7116          0          0 esmtp server soc
345   0       1096          0      26212          0          0 Fax Onramp-VFC
346   0      13692        736      38832          0          0 LICENSE AGENT
347   0       5348      31224       7164        115        115 DHCPD Timer
348   0        224          0       7340          0          0 DHCPD Database
                                 87934692 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 14%/0%; one minute: 2%; five minutes: 2%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1          12         496         24  0.00%  0.00%  0.00%   0 Chunk Manager
   2        5320     2885867          1  0.00%  0.00%  0.00%   0 Load Meter
   3           0           1          0  0.00%  0.00%  0.00%   0 faxmsp
   4       15348     1912838          8  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   6    11573132     2176740       5316  0.00%  0.09%  0.06%   0 Check heaps
   7        2576       18802        137  0.00%  0.00%  0.00%   0 Pool Manager
   8           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   9           0           2          0  0.00%  0.00%  0.00%   0 Timers
  10          24        6966          3  0.00%  0.00%  0.00%   0 WATCH_AFS
  11           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  12           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  13           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  14        1444     2884501          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  15        1368      240376          5  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  18         400    14090450          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19         536    14090449          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  20           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  24         472     1442935          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  25         132     2885861          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  26     2320216    14656675        158  0.07%  0.02%  0.01%   0 ARP Input
  27        3836    15039711          0  0.00%  0.00%  0.00%   0 ARP Background
  28           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  29           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  30           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  31           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  32         160       14016         11  0.00%  0.00%  0.00%   0 DDR Timers
  33           8           2       4000  0.00%  0.00%  0.00%   0 Entity MIB API
  34         884       20772         42  0.00%  0.00%  0.00%   0 EEM ED Syslog
  35        2028          45      45066  0.00%  0.00%  0.00%   0 PrstVbl
  36           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  37           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  38           0           2          0  0.00%  0.00%  0.00%   0 SMART
  39         192    14429330          0  0.00%  0.00%  0.00%   0 GraphIt
  40           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  41           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  42           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  43           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  44       77868     1536527         50  0.00%  0.00%  0.00%   0 Net Background
  45           0           3          0  0.00%  0.00%  0.00%   0 IDB Work
  46          40       40199          0  0.00%  0.00%  0.00%   0 Logger
  47       11332    14422479          0  0.00%  0.00%  0.00%   0 TTY Background
  48       12608     1168844         10  0.00%  0.00%  0.00%   0 IF-MGR control p
  49         348       20108         17  0.00%  0.00%  0.00%   0 IF-MGR event pro
  50           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  51        4300     7225568          0  0.00%  0.00%  0.00%   0 Fast Throttle Ti
  52           0          28          0  0.00%  0.00%  0.00%   0 AggMgr Process
  53           0          42          0  0.00%  0.00%  0.00%   0 Transport Port A
  54       25272     2901801          8  0.00%  0.00%  0.00%   0 HC Counter Timer
  55           0           3          0  0.00%  0.00%  0.00%   0 AUX
  56           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  57         376          34      11058  0.00%  0.00%  0.00%   0 ESWPPM
  58       30188      961530         31  0.00%  0.00%  0.00%   0 SM Monitor
  59           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  60           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  61        1760    57717130          0  0.00%  0.00%  0.00%   0 Netclock Backgro
  62           0           2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  63          12         229         52  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
  64        3180     1442250          2  0.00%  0.00%  0.00%   0 Service Module E
  65     4673732    72143893         64  0.23%  0.16%  0.09%   0 COLLECT STAT COU
  66          20          22        909  0.00%  0.00%  0.00%   0 Switch Link Moni
  67           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  68        3104       75982         40  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  70           0           1          0  0.00%  0.00%  0.00%   0 Platform Compact
  71         572    14429345          0  0.00%  0.00%  0.00%   0 Crypto Device Up
  72           0           2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
  73           0           1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
  74          80          14       5714  0.00%  0.00%  0.00%   0 crypto engine pr
  75           0           2          0  0.00%  0.00%  0.00%   0 SEC BATCH
  76         244          24      10166  0.00%  0.00%  0.00%   0 Async write proc
  77           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
  78           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
  79           0           3          0  0.00%  0.00%  0.00%   0 Async write proc
  80        6420      240376         26  0.00%  0.00%  0.00%   0 DFS flush period
  81        1840    14422483          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  82           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  83           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  84           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
  85           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
  86           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  87        2112    92022722          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
  88       36132  1836602224          0  0.00%  0.00%  0.00%   0 Ethernet Msec Ti
  89        1892    14422498          0  0.00%  0.00%  0.00%   0 linktest
  90           0           2          0  0.00%  0.00%  0.00%   0 Dot11 Mgmt & Ass
  91           0           2          0  0.00%  0.00%  0.00%   0 Dot11 aaa proces
  92        4220      240376         17  0.00%  0.00%  0.00%   0 pmkid
  93           0           2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  94           0           1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  95           8         195         41  0.00%  0.00%  0.00%   0 AAA Server
  96           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  97           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  98           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  99      161368     2167311         74  0.00%  0.00%  0.00%   0 CDP Protocol
100           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
101           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
102           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
103           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
104           0           5          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
105           4           2       2000  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
106      100300   450311269          0  0.00%  0.00%  0.00%   0 IPAM Manager
107           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
108          84         609        137  0.00%  0.00%  0.00%   0 IP ARP Adjacency
109           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
110    17816764    65656602        271  0.39%  0.16%  0.15%   0 IP Input
111           0         231          0  0.00%  0.00%  0.00%   0 ICMP event handl
112           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
113           0           7          0  0.00%  0.00%  0.00%   0 TurboACL
114           0           2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
115           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
116           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
117           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
118           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
119    34793692   122070294        285  0.07%  0.24%  0.23%   0 Skinny Msg Serve
120           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
121           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
122           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
123        4780    56364628          0  0.00%  0.00%  0.00%   0 SSS Feature Time
124     1677212    28798967         58  0.00%  0.00%  0.00%   0 Spanning Tree
125           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
126           4       48098          0  0.00%  0.00%  0.00%   0 Authentication P
127           0           1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
128           0           2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
129           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
130           0           2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
131       12336      288502         42  0.00%  0.00%  0.00%   0 CEF background p
132           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
133       41604    15156384          2  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
134           0           5          0  0.00%  0.00%  0.00%   0 ADJ background
135           0          25          0  0.00%  0.00%  0.00%   0 L2MM
136           0           1          0  0.00%  0.00%  0.00%   0 MRD
137        8472       77573        109  0.00%  0.00%  0.00%   0 IGMPSN
138           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
139           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
140           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
141           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
142           0           2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
143     6840348      240376      28456  0.00%  0.03%  0.00%   0 Licensing Auto U
144           0           2          0  0.00%  0.00%  0.00%   0 SNMP Timers
145           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
146           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
147           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
148        3068     1503881          2  0.00%  0.00%  0.00%   0 TCP Timer
149          56         152        368  0.00%  0.00%  0.00%   0 TCP Protocols
150           0           1          0  0.00%  0.00%  0.00%   0 COPS
151           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
152        9788      145653         67  0.00%  0.00%  0.00%   0 HTTP CORE
153           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
154        3204    14422338          0  0.00%  0.00%  0.00%   0 Skinny MOH Serve
155           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
156           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
157           0           2          0  0.00%  0.00%  0.00%   0 RARP Input
158          20          17       1176  0.00%  0.00%  0.00%   0 IP RIB Update
159        3644      240479         15  0.00%  0.00%  0.00%   0 IP Background
160           0         179          0  0.00%  0.00%  0.00%   0 IP Connected Rou
161           0          15          0  0.00%  0.00%  0.00%   0 static
162           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
163           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
164           0           1          0  0.00%  0.00%  0.00%   0 MQC Flow Event B
165           0           2          0  0.00%  0.00%  0.00%   0 HQF Shaper Backg
166        4744    14422587          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
167           0           2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
168           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
169           0           1          0  0.00%  0.00%  0.00%   0 IPS Process
170           0           2          0  0.00%  0.00%  0.00%   0 IPS Auto Update
171           0           2          0  0.00%  0.00%  0.00%   0 SDEE Management
172         896    28179768          0  0.00%  0.00%  0.00%   0 Inspect process
173     2873364     9223553        311  0.00%  0.01%  0.00%   0 AFW_application_
174          80      930386          0  0.00%  0.00%  0.00%   0 FW DP Inspect pr
175         620    28179767          0  0.00%  0.00%  0.00%   0 CCE DP URLF cach
176         164        8017         20  0.00%  0.00%  0.00%   0 SSH Event handle
177           0           2          0  0.00%  0.00%  0.00%   0 URL filter proc
178           0           1          0  0.00%  0.00%  0.00%   0 Select Timers
179          28           2      14000  0.00%  0.00%  0.00%   0 HTTP Process
180           0           2          0  0.00%  0.00%  0.00%   0 CIFS API Process
181           0           2          0  0.00%  0.00%  0.00%   0 CIFS Proxy Proce
182           4           3       1333  0.00%  0.00%  0.00%   0 Crypto HW Proc
183         100           2      50000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
184          12      577175          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
185        1668         235       7097 13.35%  1.07%  0.22%  67 Virtual Exec
186           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
187           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
188           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
189           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
190           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
191           4          56         71  0.00%  0.00%  0.00%   0 LINE AAA
192         180        4038         44  0.00%  0.00%  0.00%   0 LOCAL AAA
193           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
194           0           2          0  0.00%  0.00%  0.00%   0 VSP_MGR
195           0           1          0  0.00%  0.00%  0.00%   0 FW_TEST_TRP
196           0           1          0  0.00%  0.00%  0.00%   0 EPM MAIN PROCESS
197          12       12027          0  0.00%  0.00%  0.00%   0 NIST rng proc
198           0           3          0  0.00%  0.00%  0.00%   0 Crypto WUI
199           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
200           0           2          0  0.00%  0.00%  0.00%   0 Crypto Support
201           0           1          0  0.00%  0.00%  0.00%   0 IPSECv6 PS Proc
202      295760     5890152         50  0.00%  0.00%  0.00%   0 CCVPM_HTSP
203           0           2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
204           0           1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
205           0          71          0  0.00%  0.00%  0.00%   0 IP TRUST Registe
206           0           1          0  0.00%  0.00%  0.00%   0 EPHONE MWI Refre
207           0       16033          0  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
208           0           2          0  0.00%  0.00%  0.00%   0 EPHONE MWI BG Pr
209           0           1          0  0.00%  0.00%  0.00%   0 Skinny HW confer
210      123372    15941981          7  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
211       10376     5303683          1  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
212           0           2          0  0.00%  0.00%  0.00%   0 CTI Front End Pr
213           0           2          0  0.00%  0.00%  0.00%   0 CTI Call Control
214           0           2          0  0.00%  0.00%  0.00%   0 CTI Line Monitor
215           0           1          0  0.00%  0.00%  0.00%   0 CME CTI Device M
216       10088      480896         20  0.00%  0.00%  0.00%   0 VOICE REG BG Pro
217           0           1          0  0.00%  0.00%  0.00%   0 Presence Process
218        1100     5484416          0  0.07%  0.01%  0.00%   0 IP SLAs XOS Even
219           0           1          0  0.00%  0.00%  0.00%   0 http client proc
220           0           1          0  0.00%  0.00%  0.00%   0 DocMSP
221           0           1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
222           0           1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
223           0           1          0  0.00%  0.00%  0.00%   0 VoIP AAA
224           0           2          0  0.00%  0.00%  0.00%   0 Dialog Manager
225           0           4          0  0.00%  0.00%  0.00%   0 Crypto CA
226           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
227           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
228     1778472      140688      12641  0.00%  0.00%  0.00%   0 crypto sw pk pro
229           0           1          0  0.00%  0.00%  0.00%   0 Crypto INT
230           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKE Dispa
231           0           3          0  0.00%  0.00%  0.00%   0 Crypto IKMP
232           0           1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
233        8196      721128         11  0.00%  0.00%  0.00%   0 IPSEC key engine
234           0           1          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
235           0          10          0  0.00%  0.00%  0.00%   0 Crypto ACL
236           0           1          0  0.00%  0.00%  0.00%   0 Crypto PAS Proc
237           0           1          0  0.00%  0.00%  0.00%   0 GDOI GM Process
238           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY
239           0           1          0  0.00%  0.00%  0.00%   0 UNICAST REKEY AC
240        7676     2899468          2  0.00%  0.00%  0.00%   0 Environmental mo
241         468     8267924          0  0.00%  0.00%  0.00%   0 PM Callback
242           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
243           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
244           0           1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
245           0           1          0  0.00%  0.00%  0.00%   0 DATA Collector
246        2884       29770         96  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
247           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
248           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Track
249           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Resource
250           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Routing
251        1932     1442250          1  0.00%  0.00%  0.00%   0 RMON Recycle Pro
252           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
253           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
254          52      450917          0  0.00%  0.00%  0.00%   0 Crypto cTCP proc
255          24           2      12000  0.00%  0.00%  0.00%   0 VLAN Manager
256           4        4010          0  0.00%  0.00%  0.00%   0 fax timers
257        2708    14422409          0  0.00%  0.00%  0.00%   0 trunk conditioni
258           0           1          0  0.00%  0.00%  0.00%   0 trunk conditioni
260         308    14429345          0  0.00%  0.00%  0.00%   0 CME Extension Mo
261          32         751         42  0.00%  0.00%  0.00%   0 EEM Server
262           0           2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
263           0           2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
264           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
265           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
266           0           3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
267           4           3       1333  0.00%  0.00%  0.00%   0 EEM ED None
268           0           3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
269           0           6          0  0.00%  0.00%  0.00%   0 Collection proce
270          20      361014          0  0.00%  0.00%  0.00%   0 EEM ED Timer
271           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
272           0           3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
273           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Test
274           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Config
275           0           3          0  0.00%  0.00%  0.00%   0 EEM ED Env
276           0           3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
277           0           2          0  0.00%  0.00%  0.00%   0 EEM ED Nf
278         108       19906          5  0.00%  0.00%  0.00%   0 Syslog
279           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
280        2332     2884501          0  0.00%  0.00%  0.00%   0 VDC process
281           0           3          0  0.00%  0.00%  0.00%   0 EEM ED RPC
282       67780     2100845         32  0.00%  0.00%  0.00%   0 Net Input
283       11476     2886746          3  0.00%  0.00%  0.00%   0 Compute load avg
284     2893248      245057      11806  0.31%  0.03%  0.00%   0 Per-minute Jobs
285        3080    14430728          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
286           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
287           0           2          0  0.00%  0.00%  0.00%   0 Key Proc
288         144    14429776          0  0.00%  0.00%  0.00%   0 TRP_PSEUDOTIMER
289        3036      216249         14  0.00%  0.00%  0.00%   0 Resource Monitor
290           0           2          0  0.00%  0.00%  0.00%   0 Resource Availab
291       16384      848444         19  0.00%  0.00%  0.00%   0 CC-API_VCM
292           0           2          0  0.00%  0.00%  0.00%   0 confmsp
293     1694428     4802932        352  0.00%  0.00%  0.00%   0 DSMP
294      666204     7050962         94  0.00%  0.01%  0.00%   0 VTSP
295       13080      120672        108  0.00%  0.00%  0.00%   0 VOIP_RTCP
296           4           4       1000  0.00%  0.00%  0.00%   0 Session Applicat
297           4           2       2000  0.00%  0.00%  0.00%   0 swmtp_msp
298        9628       66157        145  0.00%  0.00%  0.00%   0 TSP
299           0           1          0  0.00%  0.00%  0.00%   0 lib_off_app
300           0           2          0  0.00%  0.00%  0.00%   0 Voice Player
301           0           1          0  0.00%  0.00%  0.00%   0 Media Record
302           0           1          0  0.00%  0.00%  0.00%   0 Resource Measure
303          12           2       6000  0.00%  0.00%  0.00%   0 CCH323_CT
304           0           1          0  0.00%  0.00%  0.00%   0 CCH323_DNS
305      245064      795255        308  0.00%  0.00%  0.00%   0 CCSIP_SPI_CONTRO
306       25184      500777         50  0.00%  0.00%  0.00%   0 CCSIP_DNS
307      420236      587287        715  0.00%  0.00%  0.00%   0 CCSIP_UDP_SOCKET
308           0           2          0  0.00%  0.00%  0.00%   0 CCSIP_TCP_SOCKET
309           4           4       1000  0.00%  0.00%  0.00%   0 CCSIP_TLS_SOCKET
310        2916      240380         12  0.00%  0.00%  0.00%   0 RTPSPI
311         960    57717375          0  0.00%  0.00%  0.00%   0 e1t1 Framer back
312       18596      247469         75  0.00%  0.00%  0.00%   0 DHCPD Receive
313           0          29          0  0.00%  0.00%  0.00%   0 SCCP Telephony C
314       44440       86481        513  0.00%  0.00%  0.00%   0 ISDN
315           0         112          0  0.00%  0.00%  0.00%   0 ISDN Timer
316          12        8136          1  0.00%  0.00%  0.00%   0 ISDNMIB Backgrou
317           0       22244          0  0.00%  0.00%  0.00%   0 CallMIB Backgrou
318       77656     4249512         18  0.00%  0.00%  0.00%   0 ISDN From Driver
319        2116    14422499          0  0.00%  0.00%  0.00%   0 DHCP Client
321         784    28179769          0  0.00%  0.00%  0.00%   0 IP NAT Ager
322           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
323          16        1423         11  0.00%  0.00%  0.00%   0 IP VFR proc
324        3796    14422495          0  0.00%  0.00%  0.00%   0 DNS Server
325           0           1          0  0.00%  0.00%  0.00%   0 DNS Server Input
326          16          54        296  0.00%  0.00%  0.00%   0 IP SNMP
327           4          27        148  0.00%  0.00%  0.00%   0 PDU DISPATCHER
328          52          30       1733  0.00%  0.00%  0.00%   0 SNMP ENGINE
329           0           2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
330           0           1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
331           0           2          0  0.00%  0.00%  0.00%   0 SNMP Traps
332     1474056     1974003        746  0.00%  0.01%  0.00%   0 SCCP Application
333        1648    57719257          0  0.00%  0.00%  0.00%   0 MLD
334           0           3          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
335           0           2          0  0.00%  0.00%  0.00%   0 Skinny MOH Event
336        6668       17147        388  0.00%  0.00%  0.00%   0 Skinny Socket Se
337      637192       38636      16492  0.00%  0.00%  0.10%   0 Web Write Housek
338       15472    14484381          1  0.00%  0.00%  0.00%   0 NTP
339      215664     5541256         38  0.00%  0.00%  0.00%   0 ISDN L2 Process
340         636       38995         16  0.00%  0.00%  0.00%   0 ISDN L3 Timer Pr
341       99180     4248067         23  0.00%  0.00%  0.00%   0 ISDN L2D SRQ Pro
343        2852    28844965          0  0.00%  0.00%  0.00%   0 esmtp client soc
344           0           2          0  0.00%  0.00%  0.00%   0 esmtp server soc
345           0           1          0  0.00%  0.00%  0.00%   0 Fax Onramp-VFC
346           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
347           4      120360          0  0.00%  0.00%  0.00%   0 DHCPD Timer
348        1036      240375          4  0.00%  0.00%  0.00%   0 DHCPD Database
------------------ show process cpu history ------------------
Ni.Pbx   01:46:42 PM Tuesday Feb 11 2014 CST
      1111
      444422222               11111     22222
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10 ****
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
       2 12 113   1  1   11 1  2 112 12 21 11  11  1 23   3 23 1
      219105675422922931257242162230370419586223522562722612135984
  100
   90
   80
   70
   60
   50
   40         *                                       *
   30         *                *                      *   *  *
   20  *  * ***   *  *   **    *   * ** ** **   *  * **   * ** *
   10  ******##   *  *   ** *  * **# ** *#**#  **  **#*  ** ##*#*
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
      35344311      1  1 12234252551111 1   11 11 11        11       11  1
      708228948777880680725051441465001829940082081585877777209785977018718797
  100
   90
   80
   70
   60                             *
   50  *                       * **
   40 ******                ** * **
   30 ******              * ** * **
   20 *******             **********               *
   10 ************************************* **********************************
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show diag ------------------
Slot 0:
UC500 Mainboard 1GE, 3 GE Switching, MOH, Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
Hardware Crypto Engine Details:
  The CHIP id is 0x0
  The SEC revision no is 0x1
EEPROM contents at hardware discovery:
Chassis MAC Address      : 6400.*.*
PCB Serial Number        : FOC15*
Hardware Revision        : 1.0
Processor type           : CA
Part Number              : 73-*-02
Board Revision           : C0
Deviation Number         : 116176
Fab Version              : 02
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
MAC Address block size   : 32
Chassis Serial Number    : FGL1*
Product (FRU) Number     : UC560-FXO-K9
Version Identifier       : V01
Top Assy. Part Number    : 800-*-01
EEPROM format version 4
EEPROM contents (hex):
  0x00: 04 FF C3 06 64 00 F1 A9 11 E0 C1 8B 46 4F 43 31
  0x10: 35 32 35 36 46 52 53 40 06 6D 41 01 00 09 CA 82
  0x20: 49 30 1B 02 42 43 30 88 00 01 C5 D0 02 02 03 00
  0x30: 81 00 00 00 00 04 00 43 00 20 C2 8B 46 47 4C 31
  0x40: 35 32 39 31 32 53 54 CB 92 55 43 35 36 30 2D 46
  0x50: 58 4F 2D 4B 39 20 20 20 20 20 20 89 56 30 31 00
  0x60: D9 04 40 C1 C2 CB C0 46 03 20 00 7E B8 01 FF FF
  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FXO Voice IO Card:
PCB Serial Number        : FOC152*
Part Number              : 73-12323-02
Board Revision           : B0
Deviation Number         : 0
Fab Version              : 02
RMA History              : 00
Top Assy. Part Number    : 800-32468-01
Product (FRU) Number     : VOICE IO CARD
  0x00: 04 FF C1 8B 46 4F 43 31 35 32 32 34 32 43 33 40
  0x10: 06 6F 41 01 00 82 49 30 23 02 42 42 30 88 00 00
  0x20: 00 00 02 02 03 00 81 00 00 00 00 04 00 C0 46 03
  0x30: 20 00 7E D4 01 CB 8D 56 4F 49 43 45 20 49 4F 20
  0x40: 43 41 52 44 FF FF FF FF FF FF FF FF FF FF FF FF
  0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision        : 4.0
Part Number              : 73-8541-05
Board Revision           : C0
Fab Version              : 04
PCB Serial Number        : FOC15262G5C
RMA History              : 00
Processor type           : 00
Product (FRU) Number     : PVDM2-64
  0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 43 30
  0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 35 32 36
  0x20: 32 47 35 43 03 00 81 00 00 00 00 04 00 09 00 CB
  0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
  0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision           : C0
Fab Version              : 04
PCB Serial Number        : FOC15262G2A
RMA History              : 00
Processor type           : 00
  0x20: 32 47 32 41 03 00 81 00 00 00 00 04 00 09 00 CB
VIC Slot 0:
3rd generation - FXS DID Voice daughter card (4 port)
Longitudinal Calibration : 01 10 10 8D A6 10 10 8A
                           57 10 10 8B 74 10 10 8A
                           6F
Product (FRU) Number     : VIC3-4FXS/DID
PCB Serial Number        :
  0x00: 04 FF 40 05 1B D3 11 01 10 10 8D A6 10 10 8A 57
  0x10: 10 10 8B 74 10 10 8A 6F CB 8D 56 49 43 33 2D 34
  0x20: 46 58 53 2F 44 49 44 89 56 30 31 20 C1 8B 20 20
  0x30: 20 20 20 20 20 20 20 20 20 FF FF FF FF FF FF FF
  0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
VIC Slot 1:
2nd generation - FXO Voice daughter card (4 port)
Product (FRU) Number     : VIC2-4FXO
Version Identifier       : V03
PCB Serial Number        :
  0x00: 04 FF 40 00 4C CB 89 56 49 43 32 2D 34 46 58 4F
  0x10: 89 56 30 33 20 C1 8B 20 20 20 20 20 20 20 20 20
  0x20: 20 20 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
HWIC Slot 2:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision        : 0.0
Top Assy. Part Number    : 800-22628-05
Board Revision           : E0
Fab Version              : 04
PCB Serial Number        : FOC15240V99
RMA History              : 00
Product (FRU) Number     : VWIC2-1MFT-T1/E1
  0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
  0x10: 42 45 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
  0x20: 35 32 34 30 56 39 39 03 00 81 00 00 00 00 04 00
  0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
  0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
HWIC Slot 3:
Hardware Revision        : 5.0
Top Assy. Part Number    : 800-33585-01
Board Revision           : D0
Deviation Number         : 0-0
Fab Version              : 04
PCB Serial Number        : FOC16294S0B
RMA History              : 00
Version Identifier       : V04
CLEI Code                : CNUIAXJAAC
  0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 83 31 01
  0x10: 42 44 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
  0x20: 36 32 39 34 53 30 42 03 00 81 00 00 00 00 04 00
  0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 34 20
  0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 43 FF FF FF FF
VIC Slot 4:
One port MOH Voice Interface
Built-in 3 ports Gige Ethernet Switch
Hardware: Marvell 88E6131 Chip   Revision: 6
Onboard Service Engine: 0
------------------ show platform ------------------
CPLD registers:
HW rev               : 0
Motherboard CPLD rev : 19
SW load reg          : 0x2
Reset reason         : 0x0
Dev Reset 1          : 0xFD
Dev Reset 2          : 0x4
HW Present           : 0x3E
Hard reset           : 0x0
Soft reset           : 0x0
LED_1                : 0x0
LED_2                : 0x0
Misc Cntl1           : 0xB0
Misc Cntl2           : 0x0
TDM PLL cntl         : 0x51
TDM PLL status       : 0x90
Temp Relay reg       : 0x1B
Temp Switch1 reg     : 0x1B
Temp Switch2 reg     : 0x23
Temp Switch3 reg     : 0x29
PWM Slow reg         : 0x7
PWM Medium Slow reg  : 0x9
PWM Medium Fast reg  : 0xC
PWM Fast reg         : 0xF
Fan Tach reg         : 0x27
FRIO rev             : 8
FRIO status          : 0x3
FRIO wic_enable      : 0x0
FRIO CPLD rev        : 9
UART registers:
RxBuf                : 0x0
IER                  : 0xD
IIR                  : 0xC1
LCR                  : 0x7
MCR                  : 0x3
LSR                  : 0x60
MSR                  : 0x0
SR                   : 0x0
UART2 registers:
RxBuf                : 0x0
IER                  : 0x5
IIR                  : 0xC1
LCR                  : 0x3
MCR                  : 0x3
LSR                  : 0x60
MSR                  : 0x11
SR                   : 0x0
MPC8300 Register Dump: Registers start address 0xF0000000
SPR - Special Purpose registers:
msr                  :              0x00009032
svr                  : [SPR - 0286] 0x80C40021
pvr                  : [SPR - 0287] 0x80861011
hid0                 : [SPR - 1008] 0xC000C000
hid1                 : [SPR - 1009] 0x0A000000
hid2                 : [SPR - 1011] 0x00040000
ctr                  : [SPR - 0009] 0x8156C2BC
dec                  : [SPR - 0022] 0xDA542659
tbl                  : [SPR - 0268] 0x25ABB6CA
tbu                  : [SPR - 0269] 0x00039AC2
mbar                 : [SPR - 0311] 0x00000000
ibat0u               : [SPR - 0528] 0xFF8000FF
ibat0l               : [SPR - 0529] 0xFF800001
ibat1u               : [SPR - 0530] 0x80001FFF
ibat1l               : [SPR - 0531] 0x00000001
ibat2u               : [SPR - 0532] 0x90001FFF
ibat2l               : [SPR - 0533] 0x10000001
ibat3u               : [SPR - 0534] 0x00000000
ibat3l               : [SPR - 0535] 0x00000000
ibat4u               : [SPR - 0560] 0x00000000
ibat4l               : [SPR - 0561] 0x00000000
ibat5u               : [SPR - 0562] 0x00000000
ibat5l               : [SPR - 0563] 0x00000000
ibat6u               : [SPR - 0564] 0x00000000
ibat6l               : [SPR - 0565] 0x00000000
ibat7u               : [SPR - 0566] 0x00000000
ibat7l               : [SPR - 0567] 0x00000000
dbat0u               : [SPR - 0536] 0x80001FFF
dbat0l               : [SPR - 0537] 0x0000000A
dbat1u               : [SPR - 0538] 0x90001FFF
dbat1l               : [SPR - 0539] 0x1000000A
dbat2u               : [SPR - 0540] 0x00000000
dbat2l               : [SPR - 0541] 0x00000000
dbat3u               : [SPR - 0542] 0x00000000
dbat3l               : [SPR - 0543] 0x00000000
dbat4u               : [SPR - 0568] 0x10001FFF
dbat4l               : [SPR - 0569] 0x1000000A
dbat5u               : [SPR - 0570] 0x00000000
dbat5l               : [SPR - 0571] 0x00000000
dbat6u               : [SPR - 0572] 0x70001FFF
dbat6l               : [SPR - 0573] 0x7000002A
dbat7u               : [SPR - 0574] 0xF0001FFF
dbat7l               : [SPR - 0575] 0xF000002A
SYS_CONF  - System Configuration registers:
immrbar              : [0xF0000000] 0xF0000000
lblawbar0            : [0xF0000020] 0xF0000000
lblawar0             : [0xF0000024] 0x8000001B
lblawbar1            : [0xF0000028] 0x00000000
lblawar1             : [0xF000002C] 0x00000000
lblawbar2            : [0xF0000030] 0x00000000
lblawar2             : [0xF0000034] 0x00000000
lblawbar3            : [0xF0000038] 0x00000000
lblawar3             : [0xF000003C] 0x00000000
pcilawbar0           : [0xF0000060] 0x70000000
pcilawar0            : [0xF0000064] 0x8000001B
pcilawbar1           : [0xF0000068] 0x00000000
pcilawar1            : [0xF000006C] 0x00000000
ddrlawbar0           : [0xF00000A0] 0x00000000
ddrlawar0            : [0xF00000A4] 0x8000001C
spridr               : [0xF0000108] 0x80C40021
PIT  - Periodic Interval Timer (PIT) registers:
ptcnr                : [0xF0000400] 0x00000081
ptldr                : [0xF0000404] 0x00112A88
ptpsr                : [0xF0000408] 0x00000000
ptctr                : [0xF000040C] 0x00060F74
ptevr                : [0xF0000410] 0x00000000
IPIC  - Integrated Programable Interrupt Controllerregisters:
sicfr                : [0xF0000700] 0x41000000
sivcr                : [0xF0000704] 0x00000000
sipnr_h              : [0xF0000708] 0x00000000
sipnr_l              : [0xF000070C] 0x00000000
simsr_h              : [0xF0000720] 0xFC0000E0
simsr_l              : [0xF0000724] 0x60300800
sicnr                : [0xF0000728] 0x00000000
sepnr_l              : [0xF000072C] 0x00000000
semsr                : [0xF0000738] 0x2D008000
secnr                : [0xF000073C] 0x00000000
sersr                : [0xF0000740] 0x00000000
sermr                : [0xF0000744] 0xFFFE0000
sercr                : [0xF0000748] 0x00000000
Reset  - Reset Module registers:
rcwlr                : [0xF0000900] 0x2905000C
rcwhr                : [0xF0000904] 0xA460D802
rsr                  : [0xF0000910] 0x00000000
rmr                  : [0xF0000914] 0x00000001
rpr                  : [0xF0000918] 0x00000000
rcr                  : [0xF000091C] 0x00000000
rcer                 : [0xF0000920] 0x00000000
Clock  - Clock Module registers:
spmr                 : [0xF0000A00] 0x2905000C
occr                 : [0xF0000A04] 0x8000FFFC
sccr                 : [0xF0000A08] 0x5FFFFFFF
QE PORTS INT  - QE Ports Interrupts:
cepier               : [0xF0000C0C] 0x00000000
cepimr               : [0xF0000C10] 0x80200000
cepicr               : [0xF0000C14] 0x00200000
gp2ier               : [0xF0000D0C] 0xDF100E40
gp2imr               : [0xF0000D10] 0x20000000
gp2icr               : [0xF0000D14] 0x00000000
QE GPIOS  - General Purpose I/O Ports:
gp1dir               : [0xF0000C00] 0x28000000
gp1odr               : [0xF0000C04] 0x00000000
gp2dir               : [0xF0000D00] 0x5D000200
gp2odr               : [0xF0000D04] 0x00000000
sicrl                : [0xF0000114] 0x00000000
sicrh                : [0xF0000118] 0x1FFC0000
DDRMC - DDR Memory Controller :
cs0_bnds             : [0xF0002000] 0x0000000F
cs1_bnds             : [0xF0002008] 0x0010001F
cs2_bnds             : [0xF0002010] 0x00000000
cs3_bnds             : [0xF0002018] 0x00000000
cs0_config           : [0xF0002080] 0x80010102
cs1_config           : [0xF0002084] 0x80010102
cs2_config           : [0xF0002088] 0x00000000
cs3_config           : [0xF000208C] 0x00000000
timing_cfg_0         : [0xF0002104] 0x00260802
timing_cfg_1         : [0xF0002108] 0x37357322
timing_cfg_2         : [0xF000210C] 0x129048C6
timing_cfg3          : [0xF0002100] 0x00000000
ddr_sdram_cfg        : [0xF0002110] 0xC3000008
ddr_sdram_cfg_2      : [0xF0002114] 0x00001000
ddr_sdram_mode       : [0xF0002118] 0x044A0432
ddr_sdram_mode_2     : [0xF000211C] 0x00000000
ddr_sdram_md_cntl    : [0xF0002120] 0x00000000
ddr_sdram_interval   : [0xF0002124] 0x03D90100
ddr_data_init        : [0xF0002128] 0x00000000
ddr_sdram_clk_cntl   : [0xF0002130] 0x02000000
ddrcdr               : [0xF0000128] 0x00080001
I2C - Inter-IC Bus 1:
i2c[0].i2cadr        : [0xF0003000] 0x0000007E
i2c[0].i2cfdr        : [0xF0003004] 0x00000006
i2c[0].i2ccr         : [0xF0003008] 0x00000000
i2c[0].i2csr         : [0xF000300C] 0x00000081
i2c[0].i2cdr         : [0xF0003010] 0x00000000
i2c[0].i2cdfsrr      : [0xF0003014] 0x00000010
I2C - Inter-IC Bus 2:
i2c[1].i2cadr        : [0xF0003100] 0x00000000
i2c[1].i2cfdr        : [0xF0003104] 0x00000030
i2c[1].i2ccr         : [0xF0003108] 0x00000000
i2c[1].i2csr         : [0xF000310C] 0x00000081
i2c[1].i2cdr         : [0xF0003110] 0x00000000
i2c[1].i2cdfsrr      : [0xF0003114] 0x00000010
LBC - Local Bus Controller :
br0                  : [0xF0005000] 0xFF801001
or0                  : [0xF0005004] 0xFF800F41
br1                  : [0xF0005008] 0x00000000
or1                  : [0xF000500C] 0x00000000
br2                  : [0xF0005010] 0x00000000
or2                  : [0xF0005014] 0x00000000
br3                  : [0xF0005018] 0xF2000801
or3                  : [0xF000501C] 0xFFFF8FF7
br4                  : [0xF0005020] 0xF1001081
or4                  : [0xF0005024] 0xFFFF8100
br5                  : [0xF0005028] 0xF3001001
or5                  : [0xF000502C] 0xFFFF8F41
br6                  : [0xF0005030] 0x00000000
or6                  : [0xF0005034] 0x00000000
br7                  : [0xF0005038] 0x00000000
or7                  : [0xF000503C] 0x00000000
mar                  : [0xF0005068] 0x00000000
mamr                 : [0xF0005070] 0x08040000
mbmr                 : [0xF0005074] 0x00000000
mcmr                 : [0xF0005078] 0x00000000
mrtpr                : [0xF0005084] 0x00000000
lsdmr                : [0xF0005094] 0x00000000
lurt                 : [0xF00050A0] 0x00000000
lsrt                 : [0xF00050A4] 0x00000000
lbcr                 : [0xF00050D0] 0x00000000
lcrr                 : [0xF00050D4] 0x80000008
PCI  - PCI Bridge registers:
pot[0].potar         : [0xF0008400] 0x00070000
pot[0].pobar         : [0xF0008408] 0x00070000
pot[0].pocmr         : [0xF0008410] 0x801F8000
pot[1].potar         : [0xF0008418] 0x00078000
pot[1].pobar         : [0xF0008420] 0x00078000
pot[1].pocmr         : [0xF0008428] 0x800F8000
pot[2].potar         : [0xF0008430] 0x00000000
pot[2].pobar         : [0xF0008438] 0x00000000
pot[2].pocmr         : [0xF0008440] 0x00000000
pot[3].potar         : [0xF0008448] 0x00000000
pot[3].pobar         : [0xF0008450] 0x00000000
pot[3].pocmr         : [0xF0008458] 0x00000000
pot[4].potar         : [0xF0008460] 0x00000000
pot[4].pobar         : [0xF0008468] 0x00000000
pot[4].pocmr         : [0xF0008470] 0x00000000
pot[5].potar         : [0xF0008478] 0x00000000
pot[5].pobar         : [0xF0008480] 0x00000000
pot[5].pocmr         : [0xF0008488] 0x00000000
gcr                  : [0xF0008520] 0x00000001
ecr                  : [0xF0008524] 0x00000000
gsr                  : [0xF0008528] 0x00000001
pitar0               : [0xF0008568] 0x00000000
pibar0               : [0xF0008570] 0x00000000
piwar0               : [0xF0008578] 0xE005501D
pitar1               : [0xF0008550] 0x00000000
pibar1               : [0xF0008558] 0x000C0000
piwar1               : [0xF0008560] 0xA005501D
pitar2               : [0xF0008538] 0x00000000
pibar2               : [0xF0008540] 0x00000000
piwar2               : [0xF0008548] 0x00000000
Interrupt Throttling Statistics:
________________________________
Throttle Count   = 00000000   Timer Count      = 00000000
Netint usec      = 00100000   Netint Mask usec = 00001000
Active           =        0   Configured       =        1
Longest IRQ usec = 00004426
Interrupt Statistics:
Vector          Count                    Handler PC          Name
9          0x00000098          0x80050658          16552 Con/Aux Interrupt
10          0x0000456A          0x80422510          16552 CUE line Interrupt
11          0x00000000          0x83A4D93C          SEC Interrupt Handler
18          0x00000000          0x80552D28          Freddo HWIC mgmt interrupts
20          0x00000000          0x80552DB0          Freddo HWIC error interrupts
21          0x00000015          0x800A4244          ESW interrupt
23          0x1620ED85          0x80552E38          FIO WIC/HWIC net interrupts
32          0x00000000          0x80066994          pqii_pro tsec1 tx interrupt
33          0x00000000          0x80066840          pqii_pro tsec1 rx interrupt
34          0x00000001          0x80066840          pqii_pro tsec1 error interrupt
35          0x149BDD0E          0x80066994          pqii_pro tsec2 tx interrupt
36          0x0F02057D          0x80066840          pqii_pro tsec2 rx interrupt
37          0x00000000          0x80066840          pqii_pro tsec2 error interrupt
65          0xD703B8AF          0x80026384          M8300_TIMER_INTERRUPT
66          0x00000000          0x80030880          Host/PCI Bridge Interrupt
74          0x00000000          0x80027C80          M8300 GPIO1 ports
75          0x00000000          0x80027D14          M8300 GPIO2 ports
84          0x00000000          0x80026CB4          Timebase Reference Interrupt
MoH Register values:
POWER                : 0x0000009F
MODE                 : 0x00000012
TRANSMIT PGA         : 0x00000040
RECEIVE PGA          : 0x000000A0
HIGH DTMF            : 0x00000000
LOW DTMF             : 0x00000000
AUX Register         : 0x00000000
------------------ show pci hardware ------------------
------------------ show pci controller ------------------
------------------ show service-module ------------------
------------------ service-module Integrated-Service-Engine0/0 status ------------------
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 8.0.6
CUE is on UC500UC500
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
E1 0/2/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (733 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
------------------ show controllers j1 ------------------
------------------ show crypto engine configuration ------------------
        crypto engine name:  Virtual Private Network (VPN) Module
        crypto engine type:  hardware
                     State:  Enabled
              Product Name:  Onboard-VPN
                FW Version:  1
              Time running:  4294967 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                   AES CBC:  Yes (128,192,256)
                  AES CNTR:  No
     Maximum buffer length:  4096
          Maximum DH index:  0030
          Maximum SA index:  0030
        Maximum Flow index:  0060
      Maximum RSA key size:  0000
        crypto lib version:  20.0.0
------------------ show crypto engine accelerator statistic ------------------
Device:   Onboard VPN
:Statistics for encryption device since the last clear
of counters 4294967 seconds ago
              0 packets in                           0 packets out
              0 bytes in                             0 bytes out
              0 paks/sec in                          0 paks/sec out
              0 Kbits/sec in                         0 Kbits/sec out
              0 packets decrypted                    0 packets encrypted
              0 bytes before decrypt                 0 bytes encrypted
              0 bytes decrypted                      0 bytes after encrypt
              0 packets decompressed                 0 packets compressed
              0 bytes before decomp                  0 bytes before comp
              0 bytes after decomp                   0 bytes after comp
              0 packets bypass decompr               0 packets bypass compres
              0 bytes bypass decompres               0 bytes bypass compressi
              0 packets not decompress               0 packets not compressed
              0 bytes not decompressed               0 bytes not compressed
                  1.0:1 compression ratio                1.0:1 overall
Last 5 minutes:
              0 bits/sec in                          0 bits/sec out
              0 bytes decrypted                      0 bytes encrypted
              0 Kbits/sec decrypted                  0 Kbits/sec encrypted
Errors:
Total Number of Packet Drops = 0
Pad Error                    = 0
Data Error                   = 0
Packet Error                 = 0
Null IP Error                = 0
Hardware Error               = 0
CP Unavailable               = 0
HP Unavailable               = 0
AH Seq Failure               = 0
Link Down Error              = 0
ESP Seq Failure              = 0
AH Auth Failure              = 0
ESP Auth Failure             = 0
Queue Full Error             = 0
API Request Error            = 0
Invalid Flow Error           = 0
Buffer Unavailable           = 0
QOS Queue Full Error         = 0
Packet too Big Error         = 0
AH Replay Check Failure      = 0
Too Many Particles Error     = 0
ESP Replay Check Failure     = 0
Input Queue Full Error       = 0
Output Queue Full Error      = 0
Pre-batch Queue Full Error   = 0
Post-batch Queue Full Error  = 0
BATCHING Statistics:
Batching Allowed
Batching currently Inactive
No of times batching turned on        = 0
No of times batching turned off       = 0
No of Flush Done                      = 0
Flush Timer in Milli Seconds          = 8
Disable Timer in Seconds              = 20
Threshold Crypto Paks/Sec
  to enable batching                  = 4000
PRE-BATCHING Enabled
Pre-batch count, max_count            = 0, 16
Packets queued to pre-batch queue     = 0
Packets flushed from pre-batch queue  = 0
The Pre-batch Queue Information
The Queuesize is                      = 256
The no entries currently being used   = 0
The Read Index is                     = 0
The Write Index is                    = 0
The entries in use are between Read and Write Index
POST-BATCHING Enabled
Post-batch count, max_count           = 0, 16
Packets queued to post-batch queue    = 0
Packets flushed from post-batch queue = 0
The Post-batch Queue Information
SEC MFIFO Statistics:
Channel 0 allocated times             = 0
Channel 1 allocated times             = 0
Channel 2 allocated times             = 0
Channel 3 allocated times             = 0
Channel 0 freed times                 = 0
Channel 1 freed times                 = 0
Channel 2 freed times                 = 0
Channel 3 freed times                 = 0
Sec MFIFO flush count                 = 0
Sec MFIFO interrupt count             = 0
Sec MFIFO put back count              = 0
Sec MFIFO Timer flush count           = 0
Sec MFIFO Timer put back count        = 0
Sec alloc workq count                 = 0
Sec free workq count                  = 64
------------------ show crypto engine accel ring packet ------------------
Device:   Onboard VPN
------------------ show crypto engine accel ring pool ------------------
Device:   Onboard VPN
Location: Onboard: 0The Crypto Packet Queue Information
The Queuesize is                      = 512
The no entries currently being used   = 512
The entries are
Entry 1  -  0x1EA69660
Entry 2  -  0x1EA69750
Entry 3  -  0x1EA69840
Entry 4  -  0x1EA69930
Entry 5  -  0x1EA69A20
Entry 6  -  0x1EA69B10
Entry 7  -  0x1EA69C00
Entry 8  -  0x1EA69CF0
Entry 9  -  0x1EA69DE0
Entry 10  -  0x1EA69ED0
Entry 11  -  0x1EA69FC0
Entry 12  -  0x1EA6A0B0
Entry 13  -  0x1EA6A1A0
Entry 14  -  0x1EA6A290
Entry 15  -  0x1EA6A380
Entry 16  -  0x1EA6A470
Entry 17  -  0x1EA6A560
Entry 18  -  0x1EA6A650
Entry 19  -  0x1EA6A740
Entry 20  -  0x1EA6A830
Entry 21  -  0x1EA6A920
Entry 22  -  0x1EA6AA10
Entry 23  -  0x1EA6AB00
Entry 24  -  0x1EA6ABF0
Entry 25  -  0x1EA6ACE0
Entry 26  -  0x1EA6ADD0
Entry 27  -  0x1EA6AEC0
Entry 28  -  0x1EA6AFB0
Entry 29  -  0x1EA6B0A0
Entry 30  -  0x1EA6B190
Entry 31  -  0x1EA6B280
Entry 32  -  0x1EA6B370
Entry 33  -  0x1EA6B460
Entry 34  -  0x1EA6B550
Entry 35  -  0x1EA6B640
Entry 36  -  0x1EA6B730
Entry 37  -  0x1EA6B820
Entry 38  -  0x1EA6B910
Entry 39  -  0x1EA6BA00
Entry 40  -  0x1EA6BAF0
Entry 41  -  0x1EA6BBE0
Entry 42  -  0x1EA6BCD0
Entry 43  -  0x1EA6BDC0
Entry 44  -  0x1EA6BEB0
Entry 45  -  0x1EA6BFA0
Entry 46  -  0x1EA6C090
Entry 47  -  0x1EA6C180
Entry 48  -  0x1EA6C270
Entry 49  -  0x1EA6C360
Entry 50  -  0x1EA6C450
Entry 51  -  0x1EA6C540
Entry 52  -  0x1EA6C630
Entry 53  -  0x1EA6C720
Entry 54  -  0x1EA6C810
Entry 55  -  0x1EA6C900
Entry 56  -  0x1EA6C9F0
Entry 57  -  0x1EA6CAE0
Entry 58  -  0x1EA6CBD0
Entry 59  -  0x1EA6CCC0
Entry 60  -  0x1EA6CDB0
Entry 61  -  0x1EA6CEA0
Entry 62  -  0x1EA6CF90
Entry 63  -  0x1EA6D080
Entry 64  -  0x1EA6D170
Entry 65  -  0x1EA6D260
Entry 66  -  0x1EA6D350
Entry 67  -  0x1EA6D440
Entry 68  -  0x1EA6D530
Entry 69  -  0x1EA6D620
Entry 70  -  0x1EA6D710
Entry 71  -  0x1EA6D800
Entry 72  -  0x1EA6D8F0
Entry 73  -  0x1EA6D9E0
Entry 74  -  0x1EA6DAD0
Entry 75  -  0x1EA6DBC0
Entry 76  -  0x1EA6DCB0
Entry 77  -  0x1EA6DDA0
Entry 78  -  0x1EA6DE90
Entry 79  -  0x1EA6DF80
Entry 80  -  0x1EA6E070
Entry 81  -  0x1EA6E160
Entry 82  -  0x1EA6E250
Entry 83  -  0x1EA6E340
Entry 84  -  0x1EA6E430
Entry 85  -  0x1EA6E520
Entry 86  -  0x1EA6E610
Entry 87  -  0x1EA6E700
Entry 88  -  0x1EA6E7F0
Entry 89  -  0x1EA6E8E0
Entry 90  -  0x1EA6E9D0
Entry 91  -  0x1EA6EAC0
Entry 92  -  0x1EA6EBB0
Entry 93  -  0x1EA6ECA0
Entry 94  -  0x1EA6ED90
Entry 95  -  0x1EA6EE80
Entry 96  -  0x1EA6EF70
Entry 97  -  0x1EA6F060
Entry 98  -  0x1EA6F150
Entry 99  -  0x1EA6F240
Entry 100  -  0x1EA6F330
Entry 101  -  0x1EA6F420
Entry 102  -  0x1EA6F510
Entry 103  -  0x1EA6F600
Entry 104  -  0x1EA6F6F0
Entry 105  -  0x1EA6F7E0
Entry 106  -  0x1EA6F8D0
Entry 107  -  0x1EA6F9C0
Entry 108  -  0x1EA6FAB0
Entry 109  -  0x1EA6FBA0
Entry 110  -  0x1EA6FC90
Entry 111  -  0x1EA6FD80
Entry 112  -  0x1EA6FE70
Entry 113  -  0x1EA6FF60
Entry 114  -  0x1EA70050
Entry 115  -  0x1EA70140
Entry 116  -  0x1EA70230
Entry 117  -  0x1EA70320
Entry 118  -  0x1EA70410
Entry 119  -  0x1EA70500
Entry 120  -  0x1EA705F0
Entry 121  -  0x1EA706E0
Entry 122  -  0x1EA707D0
Entry 123  -  0x1EA708C0
Entry 124  -  0x1EA709B0
Entry 125  -  0x1EA70AA0
Entry 126  -  0x1EA70B90
Entry 127  -  0x1EA70C80
Entry 128  -  0x1EA70D70
Entry 129  -  0x1EA70E60
Entry 130  -  0x1EA70F50
Entry 131  -  0x1EA71040
Entry 132  -  0x1EA71130
Entry 133  -  0x1EA71220
Entry 134  -  0x1EA71310
Entry 135  -  0x1EA71400
Entry 136  -  0x1EA714F0
Entry 137  -  0x1EA715E0
Entry 138  -  0x1EA716D0
Entry 139  -  0x1EA717C0
Entry 140  -  0x1EA718B0
Entry 141  -  0x1EA719A0
Entry 142  -  0x1EA71A90
Entry 143  -  0x1EA71B80
Entry 144  -  0x1EA71C70
Entry 145  -  0x1EA71D60
Entry 146  -  0x1EA71E50
Entry 147  -  0x1EA71F40
Entry 148  -  0x1EA72030
Entry 149  -  0x1EA72120
Entry 150  -  0x1EA72210
Entry 151  -  0x1EA72300
Entry 152  -  0x1EA723F0
Entry 153  -  0x1EA724E0
Entry 154  -  0x1EA725D0
Entry 155  -  0x1EA726C0
Entry 156  -  0x1EA727B0
Entry 157  -  0x1EA728A0
Entry 158  -  0x1EA72990
Entry 159  -  0x1EA72A80
Entry 160  -  0x1EA72B70
Entry 161  -  0x1EA72C60
Entry 162  -  0x1EA72D50
Entry 163  -  0x1EA72E40
Entry 164  -  0x1EA72F30
Entry 165  -  0x1EA73020
Entry 166  -  0x1EA73110
Entry 167  -  0x1EA73200
Entry 168  -  0x1EA732F0
Entry 169  -  0x1EA733E0
Entry 170  -  0x1EA734D0
Entry 171  -  0x1EA735C0
Entry 172  -  0x1EA736B0
Entry 173  -  0x1EA737A0
Entry 174  -  0x1EA73890
Entry 175  -  0x1EA73980
Entry 176  -  0x1EA73A70
Entry 177  -  0x1EA73B60
Entry 178  -  0x1EA73C50
Entry 179  -  0x1EA73D40
Entry 180  -  0x1EA73E30
Entry 181  -  0x1EA73F20
Entry 182  -  0x1EA74010
Entry 183  -  0x1EA74100
Entry 184  -  0x1EA741F0
Entry 185  -  0x1EA742E0
Entry 186  -  0x1EA743D0
Entry 187  -  0x1EA744C0
Entry 188  -  0x1EA745B0
Entry 189  -  0x1EA746A0
Entry 190  -  0x1EA74790
Entry 191  -  0x1EA74880
Entry 192  -  0x1EA74970
Entry 193  -  0x1EA74A60
Entry 194  -  0x1EA74B50
Entry 195  -  0x1EA74C40
Entry 196  -  0x1EA74D30
Entry 197  -  0x1EA74E20
Entry 198  -  0x1EA74F10
Entry 199  -  0x1EA75000
Entry 200  -  0x1EA750F0
Entry 201  -  0x1EA751E0
Entry 202  -  0x1EA752D0
Entry 203  -  0x1EA753C0
Entry 204  -  0x1EA754B0
Entry 205  -  0x1EA755A0
Entry 206  -  0x1EA75690
Entry 207  -  0x1EA75780
Entry 208  -  0x1EA75870
Entry 209  -  0x1EA75960
Entry 210  -  0x1EA75A50
Entry 211  -  0x1EA75B40
Entry 212  -  0x1EA75C30
Entry 213  -  0x1EA75D20
Entry 214  -  0x1EA75E10
Entry 215  -  0x1EA75F00
Entry 216  -  0x1EA75FF0
Entry 217  -  0x1EA760E0
Entry 218  -  0x1EA761D0
Entry 219  -  0x1EA762C0
Entry 220  -  0x1EA763B0
Entry 221  -  0x1EA764A0
Entry 222  -  0x1EA76590
Entry 223  -  0x1EA76680
Entry 224  -  0x1EA76770
Entry 225  -  0x1EA76860
Entry 226  -  0x1EA76950
Entry 227  -  0x1EA76A40
Entry 228  -  0x1EA76B30
Entry 229  -  0x1EA76C20
Entry 230  -  0x1EA76D10
Entry 231  -  0x1EA76E00
Entry 232  -  0x1EA76EF0
Entry 233  -  0x1EA76FE0
Entry 234  -  0x1EA770D0
Entry 235  -  0x1EA771C0
Entry 236  -  0x1EA772B0
Entry 237  -  0x1EA773A0
Entry 238  -  0x1EA77490
Entry 239  -  0x1EA77580
Entry 240  -  0x1EA77670
Entry 241  -  0x1EA77760
Entry 242  -  0x1EA77850
Entry 243  -  0x1EA77940
Entry 244  -  0x1EA77A30
Entry 245  -  0x1EA77B20
Entry 246  -  0x1EA77C10
Entry 247  -  0x1EA77D00
Entry 248  -  0x1EA77DF0
Entry 249  -  0x1EA77EE0
Entry 250  -  0x1EA77FD0
Entry 251  -  0x1EA780C0
Entry 252  -  0x1EA781B0
Entry 253  -  0x1EA782A0
Entry 254  -  0x1EA78390
Entry 255  -  0x1EA78480
Entry 256  -  0x1EA78570
Entry 257  -  0x1EA78660
Entry 258  -  0x1EA78750
Entry 259  -  0x1EA78840
Entry 260  -  0x1EA78930
Entry 261  -  0x1EA78A20
Entry 262  -  0x1EA78B10
Entry 263  -  0x1EA78C00
Entry 264  -  0x1EA78CF0
Entry 265  -  0x1EA78DE0
Entry 266  -  0x1EA78ED0
Entry 267  -  0x1EA78FC0
Entry 268  -  0x1EA790B0
Entry 269  -  0x1EA791A0
Entry 270  -  0x1EA79290
Entry 271  -  0x1EA79380
Entry 272  -  0x1EA79470
Entry 273  -  0x1EA79560
Entry 274  -  0x1EA79650
Entry 275  -  0x1EA79740
Entry 276  -  0x1EA79830
Entry 277  -  0x1EA79920
Entry 278  -  0x1EA79A10
Entry 279  -  0x1EA79B00
Entry 280  -  0x1EA79BF0
Entry 281  -  0x1EA79CE0
Entry 282  -  0x1EA79DD0
Entry 283  -  0x1EA79EC0
Entry 284  -  0x1EA79FB0
Entry 285  -  0x1EA7A0A0
Entry 286  -  0x1EA7A190
Entry 287  -  0x1EA7A280
Entry 288  -  0x1EA7A370
Entry 289  -  0x1EA7A460
Entry 290  -  0x1EA7A550
Entry 291  -  0x1EA7A640
Entry 292  -  0x1EA7A730
Entry 293  -  0x1EA7A820
Entry 294  -  0x1EA7A910
Entry 295  -  0x1EA7AA00
Entry 296  -  0x1EA7AAF0
Entry 297  -  0x1EA7ABE0
Entry 298  -  0x1EA7ACD0
Entry 299  -  0x1EA7ADC0
Entry 300  -  0x1EA7AEB0
Entry 301  -  0x1EA7AFA0
Entry 302  -  0x1EA7B090
Entry 303  -  0x1EA7B180
Entry 304  -  0x1EA7B270
Entry 305  -  0x1EA7B360
Entry 306  -  0x1EA7B450
Entry 307  -  0x1EA7B540
Entry 308  -  0x1EA7B630
Entry 309  -  0x1EA7B720
Entry 310  -  0x1EA7B810
Entry 311  -  0x1EA7B900
Entry 312  -  0x1EA7B9F0
Entry 313  -  0x1EA7BAE0
Entry 314  -  0x1EA7BBD0
Entry 315  -  0x1EA7BCC0
Entry 316  -  0x1EA7BDB0
Entry 317  -  0x1EA7BEA0
Entry 318  -  0x1EA7BF90
Entry 319  -  0x1EA7C080
Entry 320  -  0x1EA7C170
Entry 321  -  0x1EA7C260
Entry 322  -  0x1EA7C350
Entry 323  -  0x1EA7C440
Entry 324  -  0x1EA7C530
Entry 325  -  0x1EA7C620
Entry 326  -  0x1EA7C710
Entry 327  -  0x1EA7C800
Entry 328  -  0x1EA7C8F0
Entry 329  -  0x1EA7C9E0
Entry 330  -  0x1EA7CAD0
Entry 331  -  0x1EA7CBC0
Entry 332  -  0x1EA7CCB0
Entry 333  -  0x1EA7CDA0
Entry 334  -  0x1EA7CE90
Entry 335  -  0x1EA7CF80
Entry 336  -  0x1EA7D070
Entry 337  -  0x1EA7D160
Entry 338  -  0x1EA7D250
Entry 339  -  0x1EA7D340
Entry 340  -  0x1EA7D430
Entry 341  -  0x1EA7D520
Entry 342  -  0x1EA7D610
Entry 343  -  0x1EA7D700
Entry 344  -  0x1EA7D7F0
Entry 345  -  0x1EA7D8E0
Entry 346  -  0x1EA7D9D0
Entry 347  -  0x1EA7DAC0
Entry 348  -  0x1EA7DBB0
Entry 349  -  0x1EA7DCA0
Entry 350  -  0x1EA7DD90
Entry 351  -  0x1EA7DE80
Entry 352  -  0x1EA7DF70
Entry 353  -  0x1EA7E060
Entry 354  -  0x1EA7E150
Entry 355  -  0x1EA7E240
Entry 356  -  0x1EA7E330
Entry 357  -  0x1EA7E420
Entry 358  -  0x1EA7E510
Entry 359  -  0x1EA7E600
Entry 360  -  0x1EA7E6F0
Entry 361  -  0x1EA7E7E0
Entry 362  -  0x1EA7E8D0
Entry 363  -  0x1EA7E9C0
Entry 364  -  0x1EA7EAB0
Entry 365  -  0x1EA7EBA0
Entry 366  -  0x1EA7EC90
Entry 367  -  0x1EA7ED80
Entry 368  -  0x1EA7EE70
Entry 369  -  0x1EA7EF60
Entry 370  -  0x1EA7F050
Entry 371  -  0x1EA7F140
Entry 372  -  0x1EA7F230
Entry 373  -  0x1EA7F320
Entry 374  -  0x1EA7F410
Entry 375  -  0x1EA7F500
Entry 376  -  0x1EA7F5F0
Entry 377  -  0x1EA7F6E0
Entry 378  -  0x1EA7F7D0
Entry 379  -  0x1EA7F8C0
Entry 380  -  0x1EA7F9B0
Entry 381  -  0x1EA7FAA0
Entry 382  -  0x1EA7FB90
Entry 383  -  0x1EA7FC80
Entry 384  -  0x1EA7FD70
Entry 385  -  0x1EA7FE60
Entry 386  -  0x1EA7FF50
Entry 387  -  0x1EA80040
Entry 388  -  0x1EA80130
Entry 389  -  0x1EA80220
Entry 390  -  0x1EA80310
Entry 391  -  0x1EA80400
Entry 392  -  0x1EA804F0
Entry 393  -  0x1EA805E0
Entry 394  -  0x1EA806D0
Entry 395  -  0x1EA807C0
Entry 396  -  0x1EA808B0
Entry 397  -  0x1EA809A0
Entry 398  -  0x1EA80A90
Entry 399  -  0x1EA80B80
Entry 400  -  0x1EA80C70
Entry 401  -  0x1EA80D60
Entry 402  -  0x1EA80E50
Entry 403  -  0x1EA80F40
Entry 404  -  0x1EA81030
Entry 405  -  0x1EA81120
Entry 406  -  0x1EA81210
Entry 407  -  0x1EA81300
Entry 408  -  0x1EA813F0
Entry 409  -  0x1EA814E0
Entry 410  -  0x1EA815D0
Entry 411  -  0x1EA816C0
Entry 412  -  0x1EA817B0
Entry 413  -  0x1EA818A0
Entry 414  -  0x1EA81990
Entry 415  -  0x1EA81A80
Entry 416  -  0x1EA81B70
Entry 417  -  0x1EA81C60
Entry 418  -  0x1EA81D50
Entry 419  -  0x1EA81E40
Entry 420  -  0x1EA81F30
Entry 421  -  0x1EA82020
Entry 422  -  0x1EA82110
Entry 423  -  0x1EA82200
Entry 424  -  0x1EA822F0
Entry 425  -  0x1EA823E0
Entry 426  -  0x1EA824D0
Entry 427  -  0x1EA825C0
Entry 428  -  0x1EA826B0
Entry 429  -  0x1EA827A0
Entry 430  -  0x1EA82890
Entry 431  -  0x1EA82980
Entry 432  -  0x1EA82A70
Entry 433  -  0x1EA82B60
Entry 434  -  0x1EA82C50
Entry 435  -  0x1EA82D40
Entry 436  -  0x1EA82E30
Entry 437  -  0x1EA82F20
Entry 438  -  0x1EA83010
Entry 439  -  0x1EA83100
Entry 440  -  0x1EA831F0
Entry 441  -  0x1EA832E0
Entry 442  -  0x1EA833D0
Entry 443  -  0x1EA834C0
Entry 444  -  0x1EA835B0
Entry 445  -  0x1EA836A0
Entry 446  -  0x1EA83790
Entry 447  -  0x1EA83880
Entry 448  -  0x1EA83970
Entry 449  -  0x1EA83A60
Entry 450  -  0x1EA83B50
Entry 451  -  0x1EA83C40
Entry 452  -  0x1EA83D30
Entry 453  -  0x1EA83E20
Entry 454  -  0x1EA83F10
Entry 455  -  0x1EA84000
Entry 456  -  0x1EA840F0
Entry 457  -  0x1EA841E0
Entry 458  -  0x1EA842D0
Entry 459  -  0x1EA843C0
Entry 460  -  0x1EA844B0
Entry 461  -  0x1EA845A0
Entry 462  -  0x1EA84690
Entry 463  -  0x1EA84780
Entry 464  -  0x1EA84870
Entry 465  -  0x1EA84960
Entry 466  -  0x1EA84A50
Entry 467  -  0x1EA84B40
Entry 468  -  0x1EA84C30
Entry 469  -  0x1EA84D20
Entry 470  -  0x1EA84E10
Entry 471  -  0x1EA84F00
Entry 472  -  0x1EA84FF0
Entry 473  -  0x1EA850E0
Entry 474  -  0x1EA851D0
Entry 475  -  0x1EA852C0
Entry 476  -  0x1EA853B0
Entry 477  -  0x1EA854A0
Entry 478  -  0x1EA85590
Entry 479  -  0x1EA85680
Entry 480  -  0x1EA85770
Entry 481  -  0x1EA85860
Entry 482  -  0x1EA85950
Entry 483  -  0x1EA85A40
Entry 484  -  0x1EA85B30
Entry 485  -  0x1EA85C20
Entry 486  -  0x1EA85D10
Entry 487  -  0x1EA85E00
Entry 488  -  0x1EA85EF0
Entry 489  -  0x1EA85FE0
Entry 490  -  0x1EA860D0
Entry 491  -  0x1EA861C0
Entry 492  -  0x1EA862B0
Entry 493  -  0x1EA863A0
Entry 494  -  0x1EA86490
Entry 495  -  0x1EA86580
Entry 496  -  0x1EA86670
Entry 497  -  0x1EA86760
Entry 498  -  0x1EA86850
Entry 499  -  0x1EA86940
Entry 500  -  0x1EA86A30
Entry 501  -  0x1EA86B20
Entry 502  -  0x1EA86C10
Entry 503  -  0x1EA86D00
Entry 504  -  0x1EA86DF0
Entry 505  -  0x1EA86EE0
Entry 506  -  0x1EA86FD0
Entry 507  -  0x1EA870C0
Entry 508  -  0x1EA871B0
Entry 509  -  0x1EA872A0
Entry 510  -  0x1EA87390
Entry 511  -  0x1EA87480
Entry 512  -  0x1EA87570
------------------ show crypto engine accel ring control ------------------
Device:   Onboard VPN
The Queuesize is                      = 32
------------------ show dot11 associations all-client ------------------
------------------ show ip nbar version ------------------
NBAR software version:  7
1   base                 Mv: 2
2   ftp                  Mv: 3
3   http                 Mv: 14
      Iv:               kazaa2 - 8
      Iv:              youtube - 1
      Iv:                  msn - 1
      Iv:                yahoo - 1
4   static               Mv: 7
5   secure-http          Mv: 1
      Iv:                  aim - 1
6   netbios              Mv: 1
      Iv:                 cifs - 1
7   socks                Mv: 1
      Iv:                yahoo - 1
      Iv:                  msn - 1
      Iv:                  aim - 1
      Iv:           bittorrent - 4
8   nntp                 Mv: 1
      Iv:                yahoo - 1
9   tftp                 Mv: 1
10  exchange             Mv: 1
11  vdolive              Mv: 1
12  sqlnet               Mv: 1
13  rcmd                 Mv: 1
14  netshow              Mv: 1
15  sunrpc               Mv: 2
16  streamwork           Mv: 1
17  citrix               Mv: 11
18  fasttrack            Mv: 2
19  gnutella             Mv: 4
20  kazaa2               Mv: 8
      Iv:                 http - 13
21  custom-protocols     Mv: 1
22  rtsp                 Mv: 5
23  rtp                  Mv: 6
      Iv:   telepresence-media - 1
24  mgcp                 Mv: 2
25  skinny               Mv: 2
      Iv:          cisco-phone - 1
26  h323                 Mv: 1
27  sip                  Mv: 2
      Iv:          cisco-phone - 1
      Iv: telepresence-control - 1
28  rtcp                 Mv: 3
29  edonkey              Mv: 5
30  winmx                Mv: 4
31  bittorrent           Mv: 4
      Iv:                socks - 1
      Iv:                  wow - 1
32  directconnect        Mv: 3
33  smtp                 Mv: 1
34  dns                  Mv: 1
35  hl7                  Mv: 1
36  fix                  Mv: 1
37  msn                  Mv: 1
      Iv:                socks - 1
      Iv:                 http - 13
38  yahoo                Mv: 1
      Iv:                socks - 1
      Iv:                 http - 13
      Iv:                 nntp - 1
39  mapi                 Mv: 1
40  aim                  Mv: 1
      Iv:          secure-http - 1
      Iv:                socks - 1
41  cifs                 Mv: 1
      Iv:              netbios - 1
42  cisco-phone          Mv: 1
      Iv:                  sip - 2
      Iv:               skinny - 2
43  youtube              Mv: 1
      Iv:                 http - 12
44  skype                Mv: 3
45  wow                  Mv: 1
      Iv:           bittorrent - 4
46  microsoftds          Mv: 1
      Iv:                 cifs - 1
47  telepresence-media   Mv: 1
      Iv:                  rtp - 6
      Iv:                 rtcp - 3
48  telepresence-control Mv: 1
      Iv:                 rtcp - 3
      Iv:          cisco-phone - 1
      Iv:                  sip - 2
49  sap                  Mv: 1
{} Mv: , {Nv: ; }
            {Iv:    - }
------------------ show webvpn session context all ------------------
------------------ show webvpn stats detail ------------------
User session statistics:
    Active user sessions     : 0          AAA pending reqs         : 0
    Peak user sessions       : 0          Peak time                : never
    Active user TCP conns    : 0          Terminated user sessions : 0
    Session alloc failures   : 0          Authentication failures  : 0
    VPN session timeout      : 0          VPN idle timeout         : 0
    User cleared VPN sessions: 0          Exceeded ctx user limit  : 0
    Exceeded total user limit: 0
    Client process rcvd pkts : 0          Server process rcvd pkts : 0
    Client process sent pkts : 0          Server process sent pkts : 0
    Client CEF received pkts : 0          Server CEF received pkts : 0
    Client CEF rcv punt pkts : 0          Server CEF rcv punt pkts : 0
    Client CEF sent pkts     : 0          Server CEF sent pkts     : 0
    Client CEF sent punt pkts: 0          Server CEF sent punt pkts: 0
    SSLVPN appl bufs inuse   : 0          SSLVPN eng  bufs inuse   : 0
    Active server TCP conns  : 0
Mangling statistics:
    Relative urls            : 0          Absolute urls            : 0
    Non-http(s) absolute urls: 0          Non-standard path urls   : 0
    Interesting tags         : 0          Uninteresting tags       : 0
    Interesting attributes   : 0          Uninteresting attributes : 0
    Embedded script statement: 0          Embedded style statement : 0
    Inline scripts           : 0          Inline styles            : 0
    HTML comments            : 0          HTTP/1.0 requests        : 0
    HTTP/1.1 requests        : 0          Unknown HTTP version     : 0
    GET requests             : 0          POST requests            : 0
    CONNECT requests         : 0          Other request methods    : 0
    Through requests         : 0          Gateway requests         : 0
    Pipelined requests       : 0          Req with header size >1K : 0
    Processed req hdr bytes  : 0          Processed req body bytes : 0
    HTTP/1.0 responses       : 0          HTTP/1.1 responses       : 0
    HTML responses           : 0          CSS responses            : 0
    XML responses            : 0          JS responses             : 0
    Other content type resp  : 0          Chunked encoding resp    : 0
    Resp with encoded content: 0          Resp with content length : 0
    Close after response     : 0          Resp with header size >1K: 0
    Processed resp hdr size  : 0          Processed resp body bytes: 0
    Backend https response   : 0          Chunked encoding requests: 0
HTTP Authentication stats :
    Successful NTLM Auth     : 0          Failed NTLM Auth         : 0
    Successful Basic Auth    : 0          Failed Basic Auth        : 0
    Unsupported Auth         : 0          Unsup Basic HTTP Method  : 0
    NTLM srv kp alive disabld: 0          NTLM Negotiation Error   : 0
    Oversize NTLM Type3 cred : 0          Internal Error           : 0
    Num 401 responses        : 0          Num non-401 responses    : 0
    Num Basic forms served   : 0          Num NTLM forms served    : 0
    Num Basic Auth sent      : 0          Num NTLM Auth sent       : 0
CIFS statistics:
  SMB related Per Context:
    TCP VC's                 : 0          UDP VC's                 : 0
    Active VC's              : 0          Active Contexts          : 0
    Aborted Conns            : 0
  NetBIOS related Per Context:
    Name Queries             : 0          Name Replies             : 0
    NB DGM Requests          : 0          NB DGM Replies           : 0
    NB TCP Connect Fails     : 0          NB Name Resolution Fails : 0
  SMB related Global:
    Sessions in use          : 0          Mbufs in use             : 0
    Mbuf Chains in use       : 0          Active VC's              : 0
    Active Contexts          : 0          Browse Errors            : 0
    Empty Browser List       : 0          NetServEnum Errors       : 0
    Empty Server List        : 0          NBNS Config Errors       : 0
    NetShareEnum Errors      : 0
  HTTP related Per Context:
    Requests                 : 0          Request Bytes RX         : 0
    Request Packets RX       : 0          Response Bytes TX        : 0
    Response Packets TX      : 0          Active Connections       : 0
    Active CIFS context      : 0          Requests Dropped         : 0
  HTTP related Global:
    Server User data         : 0          CIFS User data           : 0
    Net Handles              : 0          Active CIFS context      : 0
    Authentication Fails     : 0          Operations Aborted       : 0
    Timers Expired           : 0          Pending Close            : 0
    Net Handles Pending SMB  : 0          File Open Fails          : 0
    Browse Network Ops       : 0          Browse Network Fails     : 0
    Browse Domain Ops        : 0          Browse Domain Fails      : 0
    Browse Server Ops        : 0          Browse Server Fails      : 0
    Browse Share Ops         : 0          Browse Share Fails       : 0
    Browse Dir Ops           : 0          Browse Network Fails     : 0
    File Read Ops            : 0          File Read Fails          : 0
    File Write Ops           : 0          File Write Fails         : 0
    Folder Create Ops        : 0          Folder Create Fails      : 0
    File Delete Ops          : 0          File Delete Fails        : 0
    File Rename Ops          : 0          File Rename Fails        : 0
    URL List Access OK       : 0          URL List Access Fails    : 0
Socket statistics:
    Sockets in use           : 1          Sock Usr Blocks in use   : 1
    Sock Data Buffers in use : 0          Sock Buf desc in use     : 0
    Select timers in use     : 1          Sock Select Timeouts     : 0
    Sock Tx Blocked          : 0          Sock Tx Unblocked        : 0
    Sock Rx Blocked          : 0          Sock Rx Unblocked        : 0
    Sock UDP Connects        : 0          Sock UDP Disconnects     : 0
    Sock Premature Close     : 0          Sock Pipe Errors         : 0
    Sock Select Timeout Errs : 0
Port Forward statistics:
  Client                                Server
    proc pkts                : 0          proc pkts                 : 0
    proc bytes               : 0          proc bytes                : 0
    cef pkts                 : 0          cef pkts                  : 0
    cef bytes                : 0          cef bytes                 : 0
WEBVPN Citrix statistics:
Connections serviced : 0
               Server                   Client
  Packets in  : 0                        0
  Packets out : 0                        0
  Bytes in    : 0                        0
  Bytes out   : 0                        0
ACL statistics:
    Permit web request       : 0          Deny web request         : 0
    Permit cifs request      : 0          Deny cifs request        : 0
    Permit without ACL       : 0          Deny without match ACL   : 0
    Permit with match ACL    : 0          Deny with match ACL      : 0
Single Sign On statistics:
    Auth Requests            : 0          Pending Auth Requests    : 0
    Successful Requests      : 0          Failed Requests          : 0
    Retranmissions           : 0          DNS Errors               : 0
    Connection Errors        : 0          Request Timeouts         : 0
    Unknown Responses        : 0
URL-rewrite splitter statistics:
    Direct access request    : 0          Redirect request         : 0
    Internal request         : 0
Tunnel Statistics:
    Active connections       : 0
    Peak connections         : 0          Peak time                : never
    Connect succeed          : 0          Connect failed           : 0
    Reconnect succeed        : 0          Reconnect failed         : 0
    SVCIP install IOS succeed: 0          SVCIP install IOS failed : 0
    SVCIP clear IOS succeed  : 0          SVCIP clear IOS failed   : 0
    SVCIP install TCP succeed: 0          SVCIP install TCP failed : 0
    DPD timeout              : 0
  Client
    in  CSTP frames          : 0          in  CSTP control         : 0
    in  CSTP data            : 0          in  CSTP bytes           : 0
    in  CSTP Addr Reqs       : 0          in  CSTP DPD Reqs        : 0
    in  CSTP DPD Resps       : 0          in  CSTP Msg Reqs        : 0
    out CSTP frames          : 0          out CSTP control         : 0
    out CSTP data            : 0          out CSTP bytes           : 0
    out CSTP Addr Resps      : 0          out CSTP DPD Reqs        : 0
    out CSTP DPD Resps       : 0          out CSTP Msg Reqs        : 0
    in  CDTP frames          : 0          in  CDTP control         : 0
    in  CDTP data            : 0          in  CDTP bytes           : 0
    out CDTP frames          : 0          out CDTP control         : 0
    out CDTP data            : 0          out CDTP bytes           : 0
    cef in  CSTP data frames : 0          cef in  CSTP data bytes  : 0
    cef out CSTP data frames : 0          cef out CSTP data bytes  : 0
    cef in  CDTP data frames : 0          cef in  CDTP data bytes  : 0
    cef out CDTP data frames : 0          cef out CDTP data bytes  : 0
  Server
    In  IP pkts              : 0          In  IP bytes             : 0
    In  congested pkts       : 0          In  bad pkts             : 0
    In  forwarded pkts       : 0          In  non fwded pkts       : 0
    Out IP pkts              : 0          Out IP bytes             : 0
    Out bad pkts             : 0          Out filtered pkts        : 0
    Out non forwaded pkts    : 0          Out forwarded pkts       : 0
------------------ show webvpn stats context all ------------------
------------------ show webvpn nbns context all ------------------
------------------ show webvpn stats cifs ------------------
CIFS statistics:
    Aborted Conns            : 0
  SMB related Global:
------------------ show webvpn stats sock ------------------
Socket statistics:
------------------ show raw reclaimed ------------------
RAW LEAK REPORT:
ORPHAN    :  0       raw buffers reclaimed
TSP       :  0       raw buffers reclaimed
VTSP      :  4913    raw buffers reclaimed
H323      :  0       raw buffers reclaimed
SIP       :  0       raw buffers reclaimed
CCAPI     :  418     raw buffers reclaimed
VOATM     :  0       raw buffers reclaimed
XGCP      :  0       raw buffers reclaimed
CAS       :  0       raw buffers reclaimed
IVR       :  331     raw buffers reclaimed
SSAPP     :  0       raw buffers reclaimed
Last Audit Session is at 13:45:55 CST Tue Feb 11 2014
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 09:12:51 CST May 15 2012
Key name: TP-self-signed-196*0
Key type: RSA KEYS
Storage Device: private-config
Usage: General Purpose Key
Key is not exportable.
Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00BAC92D
  9
  1BC8AA2D BB06DFF3 8DCC7FF6 74F65E35 82082571 159288B2 D542E223 7B020301 0001
% Key pair was generated at: 13:07:50 CST Feb 11 2014
Key name: TP-self-signed-196*.server
Key type: RSA KEYS
Temporary key
Usage: Encryption Key
Key Data:
  307C300D 06092A86 4*1D3B
  DC103B60 24479144 44A8*20301 0001
------------------ show buffers ------------------
Buffer elements:
     956 in free list (500 max allowed)
     872675071 hits, 0 misses, 1118 created
Public buffer pools:
Small buffers, 104 bytes (total 92, permanent 50, peak 206 @ 7w0d):
     56 in free list (20 min, 150 max allowed)
     171474326 hits, 21067 misses, 50424 trims, 50466 created
     48 failures (0 no memory)
Middle buffers, 600 bytes (total 89, permanent 25, peak 130 @ 7w0d):
     67 in free list (10 min, 150 max allowed)
     161240348 hits, 115 misses, 266 trims, 330 created
     0 failures (0 no memory)
Big buffers, 1536 bytes (total 195, permanent 50, peak 247 @ 7w0d):
     150 in free list (5 min, 150 max allowed)
     113287306 hits, 96312 misses, 288791 trims, 288936 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 100 max allowed)
     51471 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 0, permanent 0):
     0 in free list (0 min, 4 max allowed)
Interface buffer pools:
Onboard DSPRM Pool buffers, 264 bytes (total 300, permanent 300):
     0 in free list (0 min, 300 max allowed)
     300 hits, 0 fallbacks
     300 max cache size, 300 in cache
     43909339 hits in cache, 0 misses in cache
Syslog ED Pool buffers, 600 bytes (total 132, permanent 132):
     100 in free list (132 min, 132 max allowed)
     21140 hits, 0 misses
SEC Eng Packet buffers, 1700 bytes (total 512, permanent 512):
     0 in free list (0 min, 512 max allowed)
     512 hits, 0 fallbacks
     512 max cache size, 512 in cache
     0 hits in cache, 0 misses in cache
IPC buffers, 4096 bytes (total 2, permanent 2):
     1 in free list (1 min, 8 max allowed)
     1 hits, 0 fallbacks, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 384, permanent 384):
     384 hits, 0 misses, 0 trims, 0 created
     384 max cache size, 384 in cache
C5510 Header Pool buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 509 in cache
     43028508 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
     128 in free list (128 min, 1024 max allowed)
     256 hits, 0 misses, 0 trims, 0 created
     256 max cache size, 256 in cache
Normal buffers, 1536 bytes (total 512, permanent 512):
     128 max cache size, 128 in cache
Private particle pools:
HQF buffers, 0 bytes (total 2000, permanent 2000):
     2000 in free list (500 min, 2000 max allowed)
SEC Eng Particle Header buffers, 256 bytes (total 512, permanent 512):
pp00 buffers, 512 bytes (total 1536, permanent 1536):
     0 in free list (0 min, 1536 max allowed)
     1536 hits, 0 fallbacks
     1536 max cache size, 1024 in cache
     185374916 hits in cache, 0 misses in cache
Serial0/2/0:15 buffers, 512 bytes (total 8, permanent 8):
     0 in free list (0 min, 8 max allowed)
     8 hits, 0 fallbacks
     8 max cache size, 4 in cache
     2126443 hits in cache, 0 misses in cache
SEC Eng Particle buffers, 1700 bytes (total 512, permanent 512):
     512 hits, 0 misses
GigabitEthernet0/0 buffers, 1744 bytes (total 384, permanent 384):
     0 in free list (0 min, 384 max allowed)
     384 hits, 0 fallbacks
GigabitEthernet0/1 buffers, 1744 bytes (total 384, permanent 384):
     384 max cache size, 256 in cache
     256866315 hits in cache, 0 misses in cache
------------------ show buffers usage ------------------
Statistics for the Small pool
Caller pc    : 0x8005CC68 count:       38
Resource User:   IP Input count:       38
Input IDB    :       Vl20 count:        2
Number of Buffers used by packets generated by system:   54
Number of Buffers used by incoming packets:              38
Statistics for the Middle pool
Output IDB   :      Gi0/1 count:       18
Caller pc    : 0x82004B80 count:       19
Resource User: Virtual Ex count:       19
Caller pc    : 0x8005CC68 count:        2
Resource User:   IP Input count:        2
Number of Buffers used by packets generated by system:   87
Number of Buffers used by incoming packets:               2
Statistics for the Big pool
Caller pc    : 0x82004B80 count:       41
Resource User: Skinny Msg count:       39
Caller pc    : 0x81C8FC40 count:        4
Resource User:   IP Input count:        4
Resource User: SCCP Appli count:        2
Number of Buffers used by packets generated by system:  195
Number of Buffers used by incoming packets:               0
Statistics for the VeryBig pool
Number of Buffers used by packets generated by system:   10
Statistics for the Large pool
Number of Buffers used by packets generated by system:    0
Statistics for the Huge pool
Statistics for the Onboard DSPRM Pool pool
Number of Buffers used by packets generated by system:  300
Statistics for the Syslog ED Pool pool
Caller pc    : 0x81879AD0 count:       32
Resource User: EEM ED Sys count:       32
Number of Buffers used by packets generated by system:  132
Statistics for the SEC Eng Packet pool
Number of Buffers used by packets generated by system:  512
Statistics for the IPC pool
Caller pc    : 0x803EF408 count:        1
Resource User:       Init count:        1
Number of Buffers used by packets generated by system:    2
Statistics for the Header pool
Number of Buffers used by packets generated by system:  384
Statistics for the FS Header pool
Caller pc    : 0x80038268 count:      526
Resource User:       Init count:      536
Caller pc    : 0x802ECD38 count:        1
Caller pc    : 0x81A0D27C count:        8
Caller pc    : 0x802812A8 count:        1
Number of Buffers used by packets generated by system:  553
Statistics for the C5510 Header Pool pool
Input IDB    :        ED0 count:        3
Output IDB   :      Gi0/1 count:        3
Caller pc    : 0x8066DA18 count:        3
Resource User:       Init count:        3
Number of Buffers used by packets generated by system:  768
Statistics for the SW Crypto Header pool
Caller pc    : 0x836757D8 count:        1
Statistics for the Crypto Fragmentation Header pool
Caller pc    : 0x837CEAA8 count:        1
------------------ show license udi ------------------
Device#            PID                              SN                    UDI
*0              UC560-FXO-K9          F*     UC560-FXO-K9:FGL*2ST
------------------ show license feature ------------------
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
uc-user                  yes          yes         no             yes      no
------------------ show license file ------------------
License Store: Primary License Storage
  Store Index: 0
    License: 11 uc-user 1.0 LONG NORMAL STANDALONE EXCL 16_KEYS INFINITE_KEYS
             NEVER NEVER NiL SLM_CODE CL_ND_LCK NiL *1QMQRUQFCUQ8EMT400 NiL Ni
             L NiL 5_MINS UC560-FXO-K9FGL152912ST
             I> WG3ETWxc*Zm2HmD1qFfsyTAzuio66t6Xk5y8xo1
             lbVhvoh/FZfy5iRY3oE=
    Comment:
       Hash: NQQSzpNq*CBEOz+omxRg=
  Store Index: 1
    License: 11 uc-user 1.0 LONG NORMAL STANDALONE EXCL 64_KEYS INFINITE_KEYS
             L NiL 5_MINS
    Comment:
       Hash: /hCVNg*CrVoCr/d8c=
License Store: Built-In License Storage
  Store Index: 0
    License: 11 uc-user 1.0 LONG TRIAL DISABLED 1440 DISABLED STANDALONE ADD 1
             04_KEYS I*
    Comment:
       Hash: xyMqRaxB*6RSXsgNsJFk=
------------------ show license detail ------------------
Index: 1           Feature: uc-user                           Version: 1.0
License Type: Permanent
License State: Active, In Use
Lock type: Node locked
Vendor info: UC560-FXO-K9FG*2ST
License Addition: Exclusive
License Generation version: 0x8100000
License Count: 64/64/0  (Active/In-use/Violation)
License Priority: Medium
Store Index: 1
Store Name: Primary License Storage
Index: 2           Feature: uc-user                           Version: 1.0
License State: Inactive
Vendor info: UC560-FXO-K9FGL*2ST
License Count: 16/0/0  (Active/In-use/Violation)
Store Index: 0
Index: 3           Feature: uc-user                           Version: 1.0
License Type: Evaluation
    Evaluation total period: 8  weeks 4  days
    Evaluation period left: 8  weeks 4  days
    Period used: 0  minute  0  second
Lock type: Non Node locked
Vendor info:
License Addition: Additive
License Count: 104/0/0  (Active/In-use/Violation)
License Priority: None
Store Index: 0
Store Name: Built-In License Storage
------------------ show license status ------------------
License Type Supported
permanent               Non-expiring node locked license
extension               Expiring node locked license
evaluation              Expiring non node locked license
evalRightToUse          Right to use evaluation non node locked license
rightToUse              Right to use non node locked license
License Operation Supported
install    Install license
clear      Clear license
annotate   Comment license
save       Save license
Modify     Modify license
revoke     Revoke license
call-home  License call-home
Call-home Operation Supported
show pak   Display license pak via call-home
install    Install license via call-home
revoke     Revoke license via call-home
resend     Fetch license via call-home
Device status
Device Credential type: DEVICE
Device Credential Verification: PASS
Rehost Type: HARDWARE
SWIFT url status
Swift URL set to default value : https://tools.cisco.com/SWIFT/Licensing
------------------ show license statistics ------------------
Administrative statistics
Install success count:   0
Install failure count:   0
Install duplicate count: 0
Comment add count:       0
Comment delete count:    0
Clear count:             0
Save count:              0
Save cred count:         0
Client statistics
Request success count:   3
Request failure count:   0
Release count:           2
Global Notify count:     0
------------------ show inventory ------------------
NAME: "UC560-FXO-K9 Chassis", DESCR: "UC560-FXO-K9 Chassis"
PID: UC560-FXO-K9      , VID: V01, SN: F*ST
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 in DaughterCard Slot 2", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FO*99
NAME: "2nd generation four port FXO voice interface daughtercard in DaughterCard Slot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FO*B
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x1E600000  0x1FFFFFFF    27262976  Iomem  R/W    iomem
0x80000000  0x9E5FFFFF   509607936  Local  R/W    main
0x800200F0  0x83C693BB    63214284  IText  R/O    main:text
0x83C693BC  0x859B36B3    30712568  IData  R/W    main:data
0x859B36B4  0x8602B48B     6782424  IBss   R/W    main:bss
0x8602B48C  0x9E5FFFFF   408767348  Local  R/W    main:heap
Free Region Manager:
------------------ Mempool statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   8602B48C   408767348    81024928   327742420   326270516   324021908
      I/O   1E600000    27262976     7017120    20245856    20106064    20077852
-------------- Top 100 allocator pc summary -----------
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x831079DC     895584      24  HTTP CP
0x8155AFB4     545320      36  Virtual Exec
0x8155F89C     104576     402  HTTP CP
0x80FC834C      65588       1  coi_tree_chunk
0x817F5748      20512       1  allegro libretto init
0x8031A5EC      16296      14  *Packet Header*
0x82D23C90      10052       1  RMI RO-RU Chun
0x81EE5C34      10052       1  NAT Address Chunks
0x83A8A33C       8608       8  allegro libretto init
0x8155D28C       7872       2  HTTP CP
0x831078F0       5148      24  HTTP CP
0x82CD2B84       4764       1  Memory RO RU I
0x8168BE14       4700       1  Virtual Exec
0x83C60B2C       2260      10  TCP Command
0x814F8C04       1428       1  Connection
0x82D23BC0       1084      10  SDB String
0x815310F4        532       4  TTY timer block
0x8152A0B0        476       1  HTTP CP
0x83C48E88        356       1  Virtual Exec
0x8154E728        308       1  HTTP CP
0x823CFB04        300       2  SWIDB_SB: NETBIOS Info
0x83C55BE4        236       1  docmsp active docmsp sessions RBTree
0x83903934        196       1  CryptoSS:RegisteredApps
0x83859FE8        176       1  show session chunk buffer
0x83859F80        176       1  show session ike sa chunk buffer
0x82D6AC98        172       1  VdcMib Element
0x83859FB4        172       1  show session ipsec flow chunk buffer
0x81D1BDD4        164       1  MRIB route entry
0x83443ED4        164       1  MRIB route entry
0x82D23D30        152       2  MRIB IPv4 Init Process
0x81BC6564        148       1  HTTP
0x836CAE04        144       1  AAA Cursor
0x81BDFD88        136       1  HTTP
0x81BB9DB0        136       1  HTTP
0x82D6B4C8        124       1  VdcMib subif Data
0x8156E1C0        112       1  Parser Mode
0x81D1BD90        108       1  MRIB IPv4 Init Process
0x83443E90        108       1  MRIB IPv6 Init Process
0x81BB95E0        100       1  HTTP
0x836631F4         84       1  crypto_handle_table
0x814C77B4         76       1  AAA MI SG NAME
0x815551BC         76       1  Parser Linkage
0x8156E22C         76       1  Parser Mode Q1
0x8156E250         76       1  Parser Mode Q2
0x82A5079C         76       1  SNMP IDB
Allocator PC Summary for: I/O
    PC          Total   Count  Name
0x8031A640      11648      14  *Packet Data*
------------------ show dmvpn detail ------------------
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
# Ent --> Number of NHRP entries with same NBMA peer
NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
UpDn Time --> Up or Down Time for a Tunnel
------------------ show crypto ipsec client ezvpn ------------------
Easy VPN Remote Phase: 8
------------------ show ip nat statistics ------------------
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0, occurred 7w0d ago
Outside interfaces:
  GigabitEthernet0/0
Inside interfaces:
  Integrated-Service-Engine0/0, Vlan1, Vlan20, Vlan90, Vlan100
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface GigabitEthernet0/0 refcount 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
------------------ show ip nat translations ------------------
------------------ show crypto map ------------------
No crypto maps found.
------------------ show access-list ------------------
Standard IP access list 1
    10 permit 172.16.180.0, wildcard bits 0.0.0.255
    20 permit 192.168.10.0, wildcard bits 0.0.0.255
    30 permit 10.1.10.0, wildcard bits 0.0.0.3
    40 permit *.*.180.0, wildcard bits 0.0.0.255
Standard IP access list 2
    10 permit 192.168.10.0, wildcard bits 0.0.0.255
    20 permit 172.16.180.0, wildcard bits 0.0.0.255
Standard IP access list 3
    10 permit **.146.52
    20 permit **.196.11
    30 deny   any
Extended IP access list 100
    10 deny ip 192.168.10.0 0.0.0.255 any
    20 deny ip host 255.255.255.255 any
    30 deny ip 127.0.0.0 0.255.255.255 any
    40 permit ip any any
------------------ show crypto isakmp policy ------------------
Default IKE policy
Protection suite of priority 65507
encryption algorithm:          AES - Advanced Encryption Standard (128 bit keys).
hash algorithm:                    Secure Hash Standard
authentication method:          Rivest-Shamir-Adleman Signature
Diffie-Hellman group:          #5 (1536 bit)
lifetime:                    86400 seconds, no volume limit
Protection suite of priority 65508
authentication method:          Pre-Shared Key
Protection suite of priority 65509
hash algorithm:                    Message Digest 5
Protection suite of priority 65510
Protection suite of priority 65511
encryption algorithm:          Three key triple DES
Diffie-Hellman group:          #2 (1024 bit)
Protection suite of priority 65512
Protection suite of priority 65513
Protection suite of priority 65514
------------------ show crypto ipsec transform ------------------
Transform set #$!default_transform_set_1: { esp-aes esp-sha-hmac  }
   will negotiate = { Transport,  },
Transform set #$!default_transform_set_0: { esp-3des esp-sha-hmac  }
------------------ show crypto ipsec profile ------------------
------------------ show crypto isakmp sa ------------------
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
IPv6 Crypto ISAKMP SA
------------------ show crypto engine connection active ------------------
Crypto Engine Connections
   ID  Type    Algorithm           Encrypt  Decrypt LastSeqN IP-Address
------------------ show crypto ipsec sa ------------------
No SAs found
Kevin Monteiro
Level 7
Level 7
Hi Jose,
Can you make me understand the call flow:
ip-phone>>1750(CentralOffice)>>>sip>>>uc560>>fxo/siptrunk>>pstn
In which direction is the call failing?
Capture the output of failed call.
debug ccsip messages
debug voip ccapi inout
let me know.
Kevin
Yes of course,  the call arrives to the 1750 from central office via SIP,  from here the call is passed  using de fso ports of the 1750 to a fxo port of the ucm  ( this is done this way because  the licence of the ucm only allows a sip trunk , used to a voip provider)
So the call arrives to the ucm using one fxo port.
The problem is when  the cue or somebody  takes this call the call finishes.
thanks!
