Local Directory
Hi, I have a question regarding Local Directory and possibility to somehow transfer all contacts from Exchange public folders or Outlook contacts?
paolo bevilacqua
For that you would need a macro, script or something that exports your application contacts in CME configuration text form.
David Trad
Hi Aleksandar,
Can you not export then to a csv file and then use CCA to import them?
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi, thank you for your anwsers, I looked for import option in CCA but I couldn't find any. When I go to
COnfigure->Telephony->Users&Extensions->Local Directory , I can just filter, delete and add new directory numbers. When I choose add it is just row by row adding. Where can I find this import from csv option?
